Time Warner Cable HDTV - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 66Likes
post #271 of 9543 Old 08-23-2006, 03:56 PM
kevinivey's Avatar
We were one of the first SDV areas, and they have added 0 new channels.
kevinivey is offline
post #272 of 9543 Old 08-23-2006, 04:58 PM
scruffy7's Avatar
wasn't Universal HD added at the same time we went SDV?
scruffy7 is offline
post #273 of 9543 Old 08-24-2006, 03:07 AM
kevinivey's Avatar
i believe it was before
post #274 of 9543 Old 08-24-2006, 06:13 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 112
Interesting. I skimmed some of the posts a while back, including those of the area TWC rep, in the local forums for your area. Believe Austin, Texas, is another test area. Wonder what your local TWC rep has to say about possible new HD, and what channels are included in the switched-video testing. Understand from the posts there that tuning the SV is indistinguishable from non-SV tuning. -- John
John Mason is offline
post #275 of 9543 Old 08-24-2006, 07:25 AM
scruffy7's Avatar
http://www.avsforum.com/avs-vb/showt...&&#post6655377
not that it matters much, it was so long ago anyway and there's been nothing since.
scruffy7 is offline
post #276 of 9543 Old 08-24-2006, 01:33 PM
Riverside_Guy's Avatar
Indeed it does seem switched video is the holy grail... although I'm sure it's a bit more complicated than that. I'm no engineer, but I've been around the block enough to think I won't see seeing this until fall 07 at the earliest. Right now, I'm most anxious for them to get beyond 2.5.070 with a fix for the "no trick plays" bug with external drives so I can get an external drive into the flow.
Time Warner NYC (Man North Head End) - 8742HD DVR ODN 5.2.0_9
Riverside_Guy is offline
post #277 of 9543 Old 08-24-2006, 01:56 PM
archiguy's Avatar
Quoted: 3866 Post(s)
Liked: 3957
I've spoken with a high-up exec at our local TWC here in Charlotte and he tells me that, along with Los Angeles, we have the tightest bandwidth situation in the country. That means no new HD content until they implement switched video, but he gave me no timetable for that. But, curiously, they seem to be able to add any bandwidth-hogging analog SD channels that come knocking at the door (especially Spanish language channels).
It's been well over 2 1/2 years, probably closer to 3, since they added any new HD channels here. It's disgraceful.
archiguy is offline
post #278 of 9543 Old 08-24-2006, 02:09 PM
dc10forlife's Avatar
I've heard the same thing about the alleged lack of bandwidth and do not believe it. For one, UHD was added then taken away.
In any event, besides switched video, the expanded basic tier is moving into digital ("digital conversion"), saving a huge amount of bandwidth. If 50 channels are moved from analog to digital, those same fifty channels will now only occupy 10. The remaining 40 can easily hold 2 hd stations each, perhaps 3 with rate shaping. Thats room for 80-120 additional HD stations.
dc10forlife is offline
post #279 of 9543 Old 08-24-2006, 04:18 PM
ReplayJanitor's Avatar
when they do digital conversion, I'm pretty sure it's a digital simulcast, which means it takes up more bandwidth, not less, but increases picture quality on SD channels for digital costumers. it'll be 2-3 more years until TWC and other cablecos starting knocking channels off the analog tier.
ReplayJanitor is offline
post #280 of 9543 Old 08-24-2006, 04:39 PM
dj9
dj9's Avatar
Are you kidding? The digital channels are compressed at such a low bitrate that an amplified analog signal looks so much better...
dj9 is offline
post #281 of 9543 Old 08-24-2006, 04:47 PM
VisionOn's Avatar
Liked: 2349
well we've got switched digital and you still have more HD than we do! Yes we have UniversalWasteofSpaceHD, but you had both UPN and WBHD.
"We have two systems (Raleigh, N.C., and Austin, Texas) in full production with a varied number of channels and it's going quite well. But our findings have told us to pay attention to the plan and be careful about the spectrum. The results have produced 60 percent gains in efficiency, and as time passes, we'll gain even more efficiency," LaJoie said.
Thanks Mike LaJoie, CTO of Time Warner Cable. It really helped.
VisionOn is offline
post #282 of 9543 Old 08-25-2006, 04:26 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 112
TWC in NYC duplicated its analog delivery with QAM digital several years ago, along with additional digital-only channels. And yes, unless the analogs are dropped (not enough have been), more cable bandwidth is needed for the duplicate 'digital simulcast' channels. NYC TWC, with a large 860-MHz system, has claimed lack of bandwidth for its slow HD additions for years now.
Spent some time comparing analog channels with the digital versions a few years back, concluding that most of the time the digitals did look better than the analog. But also suspect that squeezing 8-10 SD channels into each cable frequency slot, compared with the original satellite (C-band, etc.) downlinks to the head end, both original analog or digital signals suffer PQ-wise. TWC here, and other systems, use rate shaping , which includes PQ-diminishing requantization , to 'squeeze' signals. -- John
post #283 of 9543 Old 08-25-2006, 07:06 AM
EricM407's Avatar
Are they contractually obligated to carry the both the East/West versions of HBO and Showtime? We don't have StarzHD or MaxHD here, and if it's a bandwidth issue, I'd really rather have some new channels instead of the duplicate of HBO/SHO showing what was on a couple hours ago. Especially since it's usually not even a movie, but just the 25th rebroadcast of Weeds or Entourage.
EricM407 is offline
post #284 of 9543 Old 08-31-2006, 02:01 PM
Marc Alexander's Avatar
Quoted: 2625 Post(s)
Liked: 2489
Here in Southern California, HD PQ has gone from bad to worse. The rate shaping requantization has made HDnet and TNT HD almost unwatchable. I can no longer accept HD that looks like a Madacy DVD (massive blocking).
I'm moving back to E*. My father has E* and the same TV I have and E* HD-lite blows away what I am currently getting from TWC. I had been with TWC specifically for FSN HD for the Lakers in HD. The PQ on FSN HD has never been great to say the least, and Dish's expanded HD channel lineup made the decision to switch easy.
Marc Alexander is offline
post #285 of 9543 Old 08-31-2006, 02:25 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 222
I thought Mark Cuban does not allow rate shaping.
Gary J is offline
post #286 of 9543 Old 08-31-2006, 02:27 PM
archiguy's Avatar
Liked: 3957
It's done by the cable company. He has no more control over that then he does over HDLite on D* and E*, which is to say, none. He sells them the content and they do with it as they wish.
archiguy is offline
post #287 of 9543 Old 08-31-2006, 07:10 PM - Thread Starter
AndyHDTV's Avatar
TWC in San Diego will be getting Starz-HD & Cinemax-HD.
http://hdtv.forsandiego.com/messages...tml?1157068156
Email Melinda Witmer at TWC Corporate, the SENIOR VICE PRESIDENT & CHIEF PROGRAMMING OFFICER if you want more HD Channels!!!
Melinda.Witmer@twcable.com
AndyHDTV is offline
post #288 of 9543 Old 09-01-2006, 08:42 AM
squeak49's Avatar
I didn't think TWC had national carriage agreements for Starz-HD and Cinemax-HD?? It figures that TWC will start adding content right after I commit to changing providers. But no regrets still. How long have we heard that ESPN2HD is "real close"???
It'll be interesting to see if any other locales add these channels.
squeak49 is offline
post #289 of 9543 Old 09-01-2006, 11:04 AM
mrkrispy's Avatar
more subscription based HD and yet still no WB (or rather the CW) in HD. Pretty pathetic.
mrkrispy is offline
post #290 of 9543 Old 09-01-2006, 11:09 AM
avjeff's Avatar
TWC San Diego is sucking a little lately. No WB HD, no CW HD, no MHD, no Universal HD. Yet Cox Cable just 15 miles north has them. I'm happy with the picture quality I get on TWC, and even their customer service is quite good. But they are slacking big time in keeping up with HD. I mean give us UHD please. And WB is a local, there is no reason they should be denying us that. Dish is looking better and better.
avjeff is offline
post #291 of 9543 Old 09-01-2006, 12:36 PM
The sad thing is that the WB and TWC are sister companies under Time Warner. You'd think they could work out a deal.
post #292 of 9543 Old 09-01-2006, 12:59 PM
Daryl L's Avatar
Quoted: 521 Post(s)
Liked: 343
But it depends on who owns the local WB station wether a carriage deal is struck. Not between Warner and TWC.
Heck, I don't even have a local WB network in my viewing area. WLFL WB22 in Raleigh NC is the closest and by FCC guidelines their not considered as being in our viewing area. Even if they were, Sinclair owns the station and they ain't giving TWC HD. We're stuck with the Cable only WB network (becoming CW). Fat chance they'll be going HD in the near future. (luckly my local UPN stations going CW but their still only analog digitized SD digital and still MONO AUDIO)
LG OLED55E6P UHD TV
Samsung UBD-K8500 UHD BD Player
Denon AVR-S710W Atmos AV Receiver
Samsung SMT-H3272 HDC DVR Cable Box
Roku Premium Plus 4k/HDR Streaming Media Box
Daryl L is offline
post #293 of 9543 Old 09-01-2006, 01:59 PM
Harley_Dude's Avatar
Sinclair owns TWO of the local San Antonio affiliates so we have to do without Fox or WB in HD on our TWC service.
Harley_Dude is offline
post #294 of 9543 Old 09-01-2006, 02:47 PM
Daryl L's Avatar
Quoted: 521 Post(s)
Liked: 343
I am sincerely sorry. That sux.
LG OLED55E6P UHD TV
Daryl L is offline
post #295 of 9543 Old 09-02-2006, 05:15 AM
pen15nv's Avatar
Yep, when I was in Greensboro, NC last year, where Sinclair owns UPN and ABC, we got neither of those in HD (plus the local WB hadn't started broadcasting in HD). Think about it...no HD superbowl, or BCS.
pen15nv is offline
post #296 of 9543 Old 09-02-2006, 02:01 PM
mikea28's Avatar
what's the deal with sinclair? why do they suck so much?
Westinghouse 42w2 1.00 | TiVo HD 1TB | Sony DVP-NS70H | Panasonic SA-XR55 | Paradigm Monitor 9 & CC-350 v1 | Harmony 676 | Vista MCE HTPC
mikea28 is offline
post #297 of 9543 Old 09-02-2006, 04:38 PM
bennyt's Avatar
does sinclair own any of the local charlotte stations?
XBL: Badd Omen
bennyt is offline
post #298 of 9543 Old 09-02-2006, 04:44 PM
Gary J's Avatar
Quoted: 422 Post(s)
Liked: 222
Their stations are on their website.
Gary J is offline
post #299 of 9543 Old 09-03-2006, 07:24 AM
It's not that they suck so much as they just won't allow TWC to send out thier local feeds in HD. Sinclair believes that TWC should pay them for that priviledge since it cost them so much to upgrade. TWC believes that Sinclair should be able to recoup their government mandated capital upgrades via advertising revenues. SO, it's John Doe consumer that gets screwed while they have a stare-off.
post #300 of 9543 Old 09-03-2006, 10:30 AM
gparris's Avatar
Quoted: 44 Post(s)
Liked: 33
In Milwaukeeland, our local UPN and WB channels started broadcasting awhile ago in HD and TWC did not want to pay the "ransom" for carriage.
So now, CW has allowed carriage with this Sinclair O&O station, even though it still has affliations with Time Warner (and CBS) and we are screwed with HD local service...once again.
You know, what with all the increases in my cable bill, add-on charges and tiers, it would be great of TWC asked us or even required us, if we want to pay for this HD carriage, just like we do ordering the HD package or some premium channel.
If this meant the NBC, etc. affiiates started to want some cash, so be it.
Satellite companies charge for locals, so with HD channel locals, until 2009 (when it becomes must-carry because it is only digital delivery), I don't see why not - at least for now.
This would be great for some to be able to finally get these HD stations, as it is difficult, if not impossible (for apartment and condo dwellers especially) than getting HD OTA, too.
Honestly, if I wanted OTA for HD locals like Sinclair keeps pushing (are you listening, both of you - TWC and Sinclair?), I would not be subscribing to cable service...they just don't "get it".
gparris is offline
Reply HDTV Programming
