AT&T U-verse HDTV - Page 125 - AVS Forum | Home Theater Discussions And Reviews
post #3721 of 4254 Old 09-26-2011, 11:58 PM
Defcon's Avatar
Quoted: 1174 Post(s)
Liked: 620
I have comcast right now and just signed up for Uverse - turbo max (24 down), U300, $100 gift card, free install, hd fee - total came to $108 for first six months. I think that's a pretty standard deal, right ? It's a lot less than I was paying for Comcast.
- is ATT good about renewing my current pricing with the same discounts after the promo period? This is the most important thing.
- do Internet speeds suffer with tv, e.g. I have multiple hd recordings?
- are the speeds reliable? I'm lucky to be in an area where Comcast is not over subscribed.
- I'm getting free install, should I switch to self install if it will save me money?
- I bought my own cable modem, it increased my speeds a lot and saved the rental fee. should I do the same for Uverse and if so which device is recommended?
Defcon is offline
post #3722 of 4254 Old 09-27-2011, 06:35 AM
Harley_Dude's Avatar
Answers below
- is ATT good about renewing my current pricing with the same discounts after the promo period? This is the most important thing. Doubt you could renegotiate after 6 months but you could at the end of the year. The $100 gift card should be taken into consideration for your overall spend on the service for months 7-12.
- do Internet speeds suffer with tv, e.g. I have multiple hd recordings? I don't really notice any degradation of Internet speeds when recording 3 HD shows at once but some have reported they lost a little off of the top end on the 24M tier. Set up several recordings and hit speedtest.net to see what you think.
- are the speeds reliable? I'm lucky to be in an area where Comcast is not over subscribed. The Internet service is very reliable. One of the best services in the U-verse bundle.
- I'm getting free install, should I switch to self install if it will save me money? How much can you save over free? There is no self install if you want TV and that is what makes it automatically free.
- I bought my own cable modem, it increased my speeds a lot and saved the rental fee. should I do the same for Uverse and if so which device is recommended? Those gray market cable boxes are popular for skirting cable profiles but U-verse is a little more sophisticated on how the connection is managed. You won't be able to get a higher speed by bringing your own box and for TV customers, you must lease the box. Trust me that this works in your favor if your box ever goes bad.
Harley_Dude is offline
post #3723 of 4254 Old 09-27-2011, 09:03 AM
bonscott87's Avatar
Harley got you good answers, couple of my comments below.
Yep, that's a pretty good deal. What you get in terms of gift cards (I got $200) all depends on what promotions they are running at the time.
I've heard they are pretty good about it but won't know for sure myself for another few months.
Very reliable. Best Internet I've ever had. You get all the speed you pay for.
There isn't anything you can buy yourself. Remember that Uverse isn't like cable, it's a form of DSL so your cable modem you bought won't work. Plus as Harley noted, you have to use their box for TV. It's more then a modem, it does Internet, phone and TV. I wasn't aware they even charged a monthly lease fee, I don't.
Scott
bonscott87 is offline
post #3724 of 4254 Old 09-27-2011, 11:10 AM
Defcon's Avatar
Liked: 620
Thanks guys. I looked into buying the RG and it costs 149, monthly rental fee is $4, so it's not worth it.
How do you tell if it's going to be 3 HD or 2 HD streams? It's the same bandwidth for all TV users, right?
Defcon is offline
post #3725 of 4254 Old 09-27-2011, 12:31 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
I don't think they know until it's actually installed and the line is tested.
Not quite sure if I understand the question correctly, but all of the channels are sent out at the same bitrate for everyone. So it's not like if your line is lower quality, you'll get a lower bitrate. You'll just be limited to two streams.
Jeremy W is offline
post #3726 of 4254 Old 09-27-2011, 01:33 PM
bonscott87's Avatar
As Jeremy said you won't know until you get it installed. You can go to the Uverse forums and see what people get in your area for an idea of the max you can get. But how much you personally get typically depends on 1) How far away you are from the VRAD and 2) What max provisioning they do in your market.
For me I'm provisioned for 3 HD/1 SD *however* I could do a 4th HD on another TV, just can only do 3 HD on the main HD DVR at a time. It's expected for us to get a full 4 HD at some point in the future.
Scott
post #3727 of 4254 Old 09-29-2011, 06:25 AM
Good rule of thumb is that if you qualify for 24M of Internet, you get the 4HD streams (3 recording, 1 on another TV). The people that qualify for 18M of Internet typically get 3HD streams (2 recording and 1 on any TV) but there can be some variance on that.
post #3728 of 4254 Old 09-29-2011, 09:52 AM
dabrooks's Avatar
Yeah, I have the 18MB service (turned down when trying to upgrade to 24) and can record 3 HD at one time.
Dan
Satisfied U-verse and DirecTV customer
dabrooks is offline
post #3729 of 4254 Old 10-05-2011, 05:27 PM
Defcon's Avatar
Liked: 620
I have the Turbo Max (24Mbps) with a 3HD/1SD profile. The tech told me I should get 4HD but for some reason its not enabled in my area.
Why is the Uverse guide and UI so slow? e.g. I can't press down in the guide 3-4 times and have it catch up, and it frequently misses keys. Hitting the dvr key takes a while for it to come up.
Defcon is offline
post #3730 of 4254 Old 10-05-2011, 07:18 PM
MTSIndy's Avatar
Motorola or Cisco boxes? Response isn't always speedy, but in my 2-yr experience with U-verse Motorola boxes, both the DVR and set top boxes are a bit slow anytime there is an upgrade or if they have just been reset. Try a hard reset (just unplug the DVR or set top box), let it boot up, and see if it's a bit quicker after 5 or 10 minutes. These things are powered -- or should we say under-powered -- by WindowsCE. Not a lot of speed, but they are pretty reliable for weeks on end without a reboot.
MTSIndy is offline
post #3731 of 4254 Old 10-05-2011, 07:45 PM
jebo_4jc's Avatar
I'm suddenly having some pretty severe connection issues in st Louis the past couple nights. It's like my whole connection is having issues, tv and internet. Am I alone here?
jebo_4jc is offline
post #3732 of 4254 Old 10-06-2011, 05:38 AM
dabrooks's Avatar
Supposedly there are some upgrades being performed that require reboots of the gateway to resolve. Apparently hasn't happened to me yet as I'm not having any issues.
Dan
dabrooks is offline
post #3733 of 4254 Old 10-06-2011, 12:42 PM
Defcon's Avatar
Liked: 620
Motorola VIP1216. I initially had the 160GB hard disk, tech swapped it out for a 250GB, which he said makes it identical to a VIP1225 box.
Will try a reset when I'm home.
Defcon is offline
post #3734 of 4254 Old 10-24-2011, 07:27 PM
nubreed's Avatar
Hey Harley_Dude is there any news on AT&T making any significant improvements on its Uverse HD picture quality?
nubreed is offline
post #3735 of 4254 Old 10-25-2011, 04:43 AM
Liked: 777
Lol
slowbiscuit is offline
post #3736 of 4254 Old 10-25-2011, 11:20 AM
nubreed's Avatar
Originally Posted by slowbiscuit View Post
Lol
Well I figured with that being the number one complaint on here about Uverse, they must have plan on addressing the HD picture quality.
nubreed is offline
post #3737 of 4254 Old 10-25-2011, 12:09 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
U-verse doesn't target their product at the people who post here. And there's not a whole lot they can do about their PQ.
Jeremy W is offline
post #3738 of 4254 Old 10-25-2011, 12:40 PM
CKNA's Avatar
Quoted: 14 Post(s)
It is being addresed as much as possible.They are in the process of upgrading their encoders to the latest Motorla SE-6600. Top VHO's have been upgraded to those for OTA channels and I can already see improvement. My local channels look exactly now as off air. Of course if OTA channels look like crap, nothing will improve it.
Also they are starting to put those encoders on national HD channels. It will take few months to complete.
CKNA is offline
post #3739 of 4254 Old 10-26-2011, 02:00 AM
Johns12's Avatar
I had U-verse installed three weeks ago. Many problems with the installation.
3 Tvs, internet, and 2 phone lines. After the initial installation, the tech was going through the remote with my wife and me, and the picture on the tv in the kitchen started to freeze. He had already been at the house for over 5 hours. He said call back and ask for him, he will come out and fix it (it was after 7pm).
The next day, all the tv's started freezing. I also noticed that my second phone line was never hooked up and now doesn't work. I called AT&T and they said the soonest they could fix the phone was two weeks. The tech for the tv problems could come the next day.
The next day the same tech came out. He was a very nice guy. He was going to replace all ends on the coax cables and try to find a splitter that he thought was hidden somewhere that may be causing the problems. When he left, the picture was still freezing, but not as much.
The next day a called and had another service tech come out. Within an hour he had the tv's working. He changed the ends of the coax in the walls as well as did something on the box outside.
Since then, the picture has been fine. Another tech came out on Oct 18, to fix the phone line. That is now working fine.
In regards to picture quality. I had Dish before this. The general picture is very good, about the same quality as Dish. Football can be a problem, but it depends on the channel and the day. Some games had noticeable pixelation, but others where fine. Tennis has been fine. In general, the picture is ok for me.
I did recalibrate the TVs to optimize the picture. The tv guide is good and not too slow for me. I like the features it has. The Dish guide was slow and changing channels on the Dish took forever. Channel changes are quicker with U-verse. Internet has also been ok. I am in Connecticut.
Johns12 is offline
post #3740 of 4254 Old 10-26-2011, 08:14 AM
dabrooks's Avatar
That response is totally idiotic. You have no clue as to what AT&T is or isn't doing, nor the tech plans going forward. To suggest that compression technology is static denies the improvements made to same over the past 20 years.
Dan
dabrooks is offline
post #3741 of 4254 Old 10-26-2011, 08:39 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
I'm basing my opinion on what they've done in the past. And all of their past moves have shown an almost complete lack of regard for HD PQ.
I never suggested any such thing. I said there's not a whole lot they can do, and that is true. Sure they can upgrade their encoders, but the improvement will be marginal. Compression technology hasn't gotten that much better in the past few years. It's not like they'll suddenly be sending flawless MPEG4 video.
Jeremy W is offline
post #3742 of 4254 Old 10-28-2011, 11:35 AM
blueyzfr6's Avatar
I'm trying to find out if U-Verse is going to offer the ability to watch my DVR from a computer. The guy is saying yes you can, but he doesn't know what I'm talking about. I don't want to drop $250 on a Slingbox and 2 months down the road I can watch my DVR from my phone or a PC. I hate people that don't understand english
end of rant
blueyzfr6 is offline
post #3743 of 4254 Old 10-28-2011, 11:49 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
As far as I know, they haven't announced anything like that.
Jeremy W is offline
post #3744 of 4254 Old 10-28-2011, 12:47 PM
end of rant
You can watch selected content today on your phone or tablet over 3G/WiFi. There are some updates coming to that feature that greatly expand its capabilities, I can't give details but stay tuned. That said, I am a long time SlingBox user and nothing any provider ever gives you for remote streaming is going to be anywhere near as feature rich.
post #3745 of 4254 Old 10-28-2011, 12:54 PM
MTSIndy's Avatar
But that's content from U-verse's online library, not from your DVR. The web remote access app for U-verse only lets you view the list of recordings on your DVR, schedule recordings, and access the program guide.
MTSIndy is offline
post #3746 of 4254 Old 10-28-2011, 01:29 PM
Yes, that is what I meant by selected content. There is more to come in the near future.
post #3747 of 4254 Old 10-28-2011, 07:12 PM
blueyzfr6's Avatar
I don't want to spend $250 on a Slingbox and have it be useless in a couple months
post #3748 of 4254 Old 10-28-2011, 09:14 PM
Tom Wellman's Avatar
Quoted: 28 Post(s)
Liked: 41
Why would it be useless in a couple of months?
And the FOUL!
Tom Wellman is offline
post #3749 of 4254 Old 10-28-2011, 09:23 PM
Ken H's Avatar
http://www.ebay.com/sch/i.html?_from...All-Categories
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #3750 of 4254 Old 10-29-2011, 08:23 AM
blueyzfr6's Avatar
If U-Verse offers the same service, where I can watch my DVR from a pc
Reply HDTV Programming
