Pre-CES Show announcements starting to roll in - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-04-2007, 10:01 AM - Thread Starter
Rich Peterson's Avatar
Quoted: 140 Post(s)
Liked: 163
Rich Peterson is offline
post #2 of 10 Old 01-04-2007, 04:29 PM
jginaz's Avatar
Wireless Plasma? Did Nicoli Tesla design the power delivery
Jay
jginaz is offline
post #3 of 10 Old 01-04-2007, 05:08 PM
Ken H's Avatar
Jay
No, Enrico Fermi.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #4 of 10 Old 01-04-2007, 05:57 PM
dm145's Avatar
Quoted: 75 Post(s)
Liked: 43
Originally Posted by Rich Peterson View Post
Here are links to several pre-CES articles:
Samsung to unveil large LCD TVs
Article is about DLP not LCD
dm145 is offline
post #5 of 10 Old 01-04-2007, 06:38 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 79
"At the electronics show, held annually in Las Vegas, Samsung will also introduce a wireless plasma TV that will be able to receive HDTV programming sent from an HD DVD or Blu-ray player or set-top box."
TVOD is offline
post #6 of 10 Old 01-04-2007, 07:37 PM - Thread Starter
Quoted: 140 Post(s)
Liked: 163
Corrected. (I cut and pasted the title directly from the title of the web page so it seems CNET had an error that they have since correctd. If you follow the link it even says LCD in the address line of the browser..)
post #7 of 10 Old 01-04-2007, 10:02 PM
donyoop's Avatar
Originally Posted by Ken H View Post
No, Enrico Fermi.
Don't listen to Ken. Fermi is all the rage in Detroit with their utility Detroit Edison. Tesla had the original patent on wireless delivery of power I believe in 1917 or 1918; his lab was in Colorado Springs.
Don
donyoop is offline
post #8 of 10 Old 01-05-2007, 02:21 AM
Marcus Carr's Avatar
Quoted: 56 Post(s)
Liked: 100
LG To Launch HD DVD and Blu-ray Dual Format Player in Q1
And just to make things more confusing:
Warner Bros to Release Dual [Blu-ray Disc/HD-DVD]
YOU ARE READING AVS FORUM
Marcus Carr is offline
post #9 of 10 Old 01-05-2007, 06:15 AM
drhill's Avatar
Quoted: 28 Post(s)
Liked: 24
Wouldn't it be ironic if the dual format disc didn't work on the dual format player?
drhill is offline
post #10 of 10 Old 01-06-2007, 01:53 PM
DSperber's Avatar
Quoted: 227 Post(s)
Liked: 186
For those of you who've been following this technology (Smyth Virtual Surround, aka SVS) for several years as I have, it's similar in concept to Dolby Headphone in its attempt to produce multi-channel surround sensation through ordinary headphones.
However it works differently (and vastly better, so I've heard and read), and also differs in that its source is already-decoded discrete multi-channel analog rather than the encoded DD5.1/DTS or newer digital datastream. The decoder is presumed to be external and the analog outputs of the decoder are fed to the inputs of the SVS box which has matching analog outputs for optional "relay" connection to your receiver, as well as L/R analog outputs for feeding to your headphone amp. The SVS box thus appears between the multi-channel analog source and your multi-channel analog receiver (if you have one) with no digital inputs or outputs of its own.
Having the decoder external to the SVS box insulates Smyth from (a) having to pay royalties to the owner of the codec, and (b) having to have firmware/software updates every time a new high-end HD audio codec appears or is updated. Relying on the discrete analog result of external decoding is clearly the optimal approach for them.
Smyth-Research is planning to have their high-end SVS box available very soon. And they've licensed the technology to Yamaha, which has a much less expensive box presumably also being available soon.
Smyth-Research has a booth at CES, SandVenetian Zeno 4805, and you should try to make it your business to visit if you're going to be there, for a demo. I was supposed to be going to CES but unfortunately have had to cancel. They'll be using Stax Omega headphones and amp.
I'm guessing (but am not sure) that you might also see the Yamaha box demoed at their HD/home theater CES booth, Central 12128.
Please provide feedback of SVS on the forum if you do go to CES and go to either of the SVS demos. I'm kicking myself for not being able to be there for the second year in a row.
DSperber is offline
Reply HDTV Programming
