Broadcast HD movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-04-2007, 04:18 PM - Thread Starter
Cillusion's Avatar
Was curious if the movies that are broadcast in HD just upconverted dvds, or if they have been remastered?
Cillusion is offline
post #2 of 10 Old 01-04-2007, 04:27 PM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
Depends. Most are in HD. Some networks like TNT-HD broadcast their SD movies stretched to fill an HD screen and will have a silly "hall of mirrors" look. It's rare that you'll see a movie that was a widescreen SD master and upconverted to HD although this was more common years ago.
You can't broadcast DVDs for various technical reasons.
NOW: my post on AVS Forum.
NEXT: someone else's post on AVS Forum.
scowl is offline
post #3 of 10 Old 01-04-2007, 04:35 PM
bfoster's Avatar
Most movis are made with film, which has far greater resolution than HD. Most are telecined to HD.
bfoster is offline
post #4 of 10 Old 01-04-2007, 04:55 PM
Ken H's Avatar
Anything in widescreen OTA will be HD.
As for cable/DBS, many HD channels upconvert SD, which will appear as 4:3 aspect ratio in the 16:9 image area.
Others upconvert & stretch, like as noted, TNT.
They do not use upconverted DVD, period.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 10 Old 01-04-2007, 05:20 PM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
There are still some exceptions. PBS regularly shows upconverted widescreen features on their HD channel. Fox will throw a widescreen football game at you if you're unlucky. Um, those are the only ones I can think of off hand.
scowl is offline
post #6 of 10 Old 01-04-2007, 05:37 PM
Ken H's Avatar
You are 100% correct, but I thought we were referring to movies?
Ken H is offline
post #7 of 10 Old 01-04-2007, 06:13 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 79
Usually the HD movies are transferred on one of these or it's 4K sibling:
TVOD is offline
post #8 of 10 Old 01-04-2007, 06:16 PM
Ken H's Avatar
Go 4K, or go home....
Ken H is offline
post #9 of 10 Old 01-04-2007, 06:22 PM
TVOD's Avatar
Quoted: 75 Post(s)
Liked: 79
TVOD is offline
post #10 of 10 Old 01-05-2007, 11:09 AM
scowl's Avatar
Quoted: 122 Post(s)
Liked: 39
I'm sure I've seen British made-for-TV movies in SD widescreen on PBS, mostly costume dramas and documentaries.
scowl is offline
Reply HDTV Programming
