DirecTV 2007 New HD Channels - First Wave anticipation thread. - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 1793 Old 09-18-2007, 09:59 AM
RAVEN56706's Avatar
Originally Posted by pcpapant View Post
Yup -- mentioned that a few posts ago.
that you did and for that you are da man
2011 SUPERBOWL CHAMPIONS- New York Giants!!!
Gamertag: GENERAL CUPKAKE
RAVEN56706 is offline
post #182 of 1793 Old 09-18-2007, 10:01 AM
talbain's Avatar
Originally Posted by justjoe View Post
Even with the sd channel removed from the line-up, pressing 622 still brings up the sd channel on the h-20. That being said, I leave the sd channel in the line-up because it has the interactive feature. Any reason why interactive cant be used on an hd channel?
interactive works just fine on the nfl sunday ticket hd channels
edit: though now that i think about it, i'm not sure if you can access your fantasy teams from any channel other than 701 (sd)
---Mr. Met---
J-E-T-S-JETS JETS JETS!!!!!!! --- LETS GO DE-VILS!!!!!!! --- LETS GO METS!!!!!!! --- LETS GO NETS!!!!!!!
talbain is offline
post #183 of 1793 Old 09-18-2007, 10:25 AM - Thread Starter
mx6bfast's Avatar
Originally Posted by chibul View Post
Just had a recorded call about making sure I had the right equipment. Nice.
They have been doing those for months. Your last name must start with Z.
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #184 of 1793 Old 09-18-2007, 10:30 AM
chibul's Avatar
G, actually.
I'm a little nervous about my transponders/having two 103 satellites...hopefully someone can help me out there. (previous post)
chibul is offline
post #185 of 1793 Old 09-18-2007, 10:34 AM
Cavemanhead's Avatar
I've heard that Direct TV HD is refferred to as "HD-Lite" because of the compression and hence poor PQ. Is this still the case now, or is this issue resolved?
Cavemanhead is offline
post #186 of 1793 Old 09-18-2007, 10:46 AM
Snuffy101's Avatar
G, actually.
103(a) is believed to be spot-beams for local channels to various markets, mine are all zeros. 103(b) is for the new HD channels (16 transponders) which should give pretty good signal levels by now. Maybe tomorrow they will be on-air.
Snuffy
Snuffy101 is offline
post #187 of 1793 Old 09-18-2007, 10:53 AM
richard korsgren's Avatar
Question...I'm not as knowledgable on this stuff. I went to test my satellite signal for 103, and I have two 103s - 103(a) and 103(b). 103(a) is bad - the majority are N/A, with a few 0s and a couple of 65s. 103(b) is better, with Transponders 1-16 ranging from 82-96.
Your 103-a is not 'bad'. Your 103-b is probably high enough in signal strength to give you good programming. All signals in the 90's (103-b) is excellent but, I believe, you will be just fine on the new HD channels. We all will know soon.
richard korsgren is offline
post #188 of 1793 Old 09-18-2007, 10:54 AM
hengnv's Avatar
If you are referring to MPEG-4 as the compression, you don't have to worry about quality. I'm receiving my local channels in MPEG-4 for a while now and they look as good as the channels that are using MPEG-2.
hengnv is offline
post #189 of 1793 Old 09-18-2007, 10:55 AM
Always judge for yourself. Comments made here are mostly opinions and should be viewed as such. I find the HD channels (stations) are far from 'poor'.
post #190 of 1793 Old 09-18-2007, 11:02 AM
trgraphics's Avatar
So, midnight tonight and we should see the results of the new sat?
trgraphics is offline
post #191 of 1793 Old 09-18-2007, 11:06 AM
antzona's Avatar
According to the rep I just spoke to, the channels will be up at 6am eastern.
antzona is offline
post #192 of 1793 Old 09-18-2007, 11:15 AM - Thread Starter
mx6bfast's Avatar
We need some clarification here.
Are you saying your mpeg-4 local channels from D* look as good as the mpeg-2 channels from D*?
Or your D* HD locals look as good as your local OTA stations that are in mpeg-2?
I hope you mean the 2nd one.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #193 of 1793 Old 09-18-2007, 11:21 AM
RAVEN56706's Avatar
just got the same answer.... channels will be up at 6am eastern...
post #194 of 1793 Old 09-18-2007, 11:23 AM
dschuman's Avatar
If you are in Cherry Hill NJ you are most likely out of the YES/NY market. You would have to "move" to get YES via a spot.[/quote]
OK - so the magic question. I am moving to Virginia from NH and have been "living" on Long Island for quite a few years. I get the spot beam MPEG4 NYC locals. When I physically move to VA, but am still "living" on Long Island in the eyes of some unnamed satellite company because no one has told them anything to the contrary, will I still get the NYC MPEG4 locals? Is the spot beam a physical limitation or is it based upon where you "live"?
dschuman is offline
post #195 of 1793 Old 09-18-2007, 11:24 AM
jmj713's Avatar
When can we see the guide updated with the new channels and upcoming programming? I'm gonna be asleep at 6 AM but would love to DVR something to check out before work.
jmj713 is offline
post #196 of 1793 Old 09-18-2007, 11:27 AM
Alan Gordon's Avatar
6:00 A.M. EDT.
Sorry...
~Alan
All comments are my own. Unless specifically stated, my views do NOT represent the views
of Alan Gordon, Alan Gordon Enterprises, Alan Gordon, Inc., or Alan Gordon Amalgamated.
Alan Gordon is offline
post #197 of 1793 Old 09-18-2007, 12:02 PM
Utahred1981's Avatar
Is there any way for me to find out if my local HD channels are mpeg2 or mpeg4?
Utahred1981 is offline
post #198 of 1793 Old 09-18-2007, 12:04 PM
John4924's Avatar
If you get them from D* in HD, then they are mpeg4
John4924 is offline
post #199 of 1793 Old 09-18-2007, 12:10 PM
Electrico's Avatar
Originally Posted by RoyGBiv View Post
Interesting that people are reporting their highest values for the transponder signals today. For me it is actually lower. I went to check after seeing that the first 3 transponders now had signals. My recollection is that when I checked on Sunday I was getting all readings in the 90's. Now most of my readings are in the low to mid 80's.
I hope they are not finished "tweaking" the signal, as doing so has made my reception worse.
SMK
The cat still has four legs. Secondly you are sweating spongy bullets Go back and try to recall the weather last Sunday VS this AM.
Furthermore before ALL 16 TPS were active the satellite SS was zero. Now ALL 16 TPS are up plus 103b has a satellite SS reading. Last night I got a 95% ave. SS. TPS 17 and 22 had 100% SS. Add that sat. 103b SS was 97%
on TP1. I am still getting very close to those SS's including a 97% SS on TPS1 for 103b. Chill out SMK!
Electrico is offline
post #200 of 1793 Old 09-18-2007, 12:13 PM
scdiver's Avatar
I have been following this thread since the beginning and only now will I ask a stupid question.
I live in southern California and I am getting 0 signal strength on 103 (b). I can see the transponders are turned on, but every time I check the signal strength is ZERO! Other sats are between 80 and 95. Any suggestions, or should I wait till tomorrow morning?
Jeff
scdiver is offline
post #201 of 1793 Old 09-18-2007, 12:14 PM
..wishing Directv would provide us with Hallmark Movies. This channel will go HD in 3-4 months. Also hoping Hallmark Channel will go HD. We watch many excellent, original shows on this channel. And their commercials are outstanding.
post #202 of 1793 Old 09-18-2007, 12:17 PM
Jeff
If you are receiving programming from other sats (and your signals are where you say), you should be getting good numbers on 103 (B). Check your system from beginning to end. You should be getting numbers on 103 (b) all day today, Tuesday.
post #203 of 1793 Old 09-18-2007, 12:19 PM
talbain's Avatar
my general policy of any hd = good hd would be tested with these additions...
---Mr. Met---
talbain is offline
post #204 of 1793 Old 09-18-2007, 12:21 PM
scdiver's Avatar
Richard,
That is what I thought. I will reconnect all cables and triple chaeck everything. I find it very concerning that I have not seen anything on 103 (b).
scdiver is offline
post #205 of 1793 Old 09-18-2007, 12:22 PM
John4924's Avatar
Jeff
First, do you have the BBCs installed?
Second, if you have a multiswitch, it needs to be the Zinwell WB68
http://www.solidsignal.com/prod_display.asp?prod=WB68
I would start with these two first.
Cheers,
John
John4924 is offline
post #206 of 1793 Old 09-18-2007, 12:22 PM
TulsaCoker's Avatar
Quoted: 35 Post(s)
Liked: 55
Unless your in LA or NYC which has both for DSN
Panasonic (65GT30)
Yamaha (RX-V3900)
Oppo (BDP-103)
Klipsch (RF-7, RC-7, KG4.5, RC-3II)
SVS SB12-NSD, Klipsch RW-12
TulsaCoker is offline
post #207 of 1793 Old 09-18-2007, 12:25 PM
I am not impressed with mpeg4 so far then...my off air locals still look better
post #208 of 1793 Old 09-18-2007, 12:28 PM
scdiver's Avatar
Cheers,
John
John,
I do have BBC's installed and I do have the WB68 installed. I have checked 499 to make sure that the BBC's are working.
scdiver is offline
post #209 of 1793 Old 09-18-2007, 12:29 PM
antiqueradioman's Avatar
The WB616 Zinwell is also okay to use
antiqueradioman is offline
post #210 of 1793 Old 09-18-2007, 12:30 PM
John4924's Avatar
I can say from my personal view here in New Orleans that the D* mpeg4 feeds look every bit as good as my OTA feeds. And as a side benefit, the mpeg4 feeds take up less room on my DVR
However, I will always keep my OTA feeds hooked up, because we do get some heavy downpours here in the Big Easy, and rain fade from the sat is real!
John4924 is offline
Closed Thread HDTV Programming
