DirecTV HDTV - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 514Likes
post #361 of 16937 Old 09-26-2007, 03:29 PM
aviators99's Avatar
Originally Posted by Actuary555 View Post
Do you have to subscribe to the hd package to get these new HD channels?
Related, but opposite question:
What about those (very few) of us who have the HD package, but not any basic tier? Will we get the channels? I can't test it, because I don't have an Mpeg4 receiver yet.
aviators99 is offline
post #362 of 16937 Old 09-26-2007, 03:36 PM
AFH
AFH's Avatar
Originally Posted by JadeTree View Post
D* doesn't carry CW in HD on the satellite, doesn't mean that you can not get it from OTA. Get a good HD antenna, connect it to you D* HD receiver, and you could get the program if it is available through OTA in your market.
Check http://www.antennaweb.org website for you local HD broadcast and check which antenna is suit for your location.
I live 30 miles from Seattle, and I get CW in HD through OTA.
Whether Directv carries the CW depends on the market you live in. All you have to do is go to their site and enter your zip code to find out what HD locals are available in your area thru Directv. Directv said a couple of months ago that with the launch of D10 and D11 that they'll add the remaining nets (like CW) in markets that currently don't have the CW but they have the other 4.
"I'm going to call them scallywags" - Ollie
Xbox Live: Stunt1on1
AFH is offline
post #363 of 16937 Old 09-26-2007, 03:39 PM
rad
rad's Avatar
Quoted: 27 Post(s)
So there is no way of getting the new satellite channels and ota together in one line? I must now have a separate line for OTA?
Not currently. There is a new switch called the SWM that will allow for diplexing and only one cable needed for the DBS side. It's being tested now and hoped for release in the next month or so.
rad is offline
post #364 of 16937 Old 09-26-2007, 03:41 PM
skywalkr2's Avatar
Did you notice that in the release from Direct TV that they say they have 21 new channels today, but they count Versus and Golf as two separate channels?
skywalkr2 is offline
post #365 of 16937 Old 09-26-2007, 03:42 PM - Thread Starter
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Versus/Golf is counted as a single channel.
CPanther95 is offline
post #366 of 16937 Old 09-26-2007, 03:43 PM
rp2955's Avatar
Issue with not getting the remaining HD channels has been solved. I noticed some of my transponders showing low numbers, some even showing 0's on the 103(b. I had previously had an OTA diplexed into my line. I thought I had gotten rid of the only diplexer behind my H20 unit a couple of nights ago. Just went out to my dish and noticed another diplexer. I removed that diplexer and put in a quick and dirty splitter to join the two lines. Now I am getting 90+ on all transponders and all HD channels. I am sure the splitter isn't the "best" route...but best I could do given cable is split at diplexer and dish is aways down my fence.
rp2955 is offline
post #367 of 16937 Old 09-26-2007, 03:45 PM
SJKurtzke's Avatar
Is anyone else getting TBSHD as 720p?
I have Native mode on and all the other channels seem to be changing formats fine (1080i for CNNHD, 480i for PBS-SD, 720p for ESPNHD, etc)
SJKurtzke is offline
post #368 of 16937 Old 09-26-2007, 03:47 PM
skywalkr2's Avatar
I just looked at their announcement and they only had 21 logos shown and two of those were golf/versus. However they only had one logo for Starz HD... so maybe that's the difference.
post #369 of 16937 Old 09-26-2007, 03:48 PM
foxeng's Avatar
Quoted: 184 Post(s)
Liked: 74
[quote=killerdoberman;11734102]
Originally Posted by isyp View Post
And I believe Congress has backed out the origial date from 2009 to 2011 to go full HD as the standard. That is...Congress' idea of HD.
WRONG. There is NO mandate of ANY KIND that ANYTHING has to be HD.
The law states that by Feb 17, 2009 all analog OTA MUST cease and be digital with the SAME SD resolution as analog. HD is optional. Cable has to support legacy analog sets until 2012. Again HD is optional. That is the law. End of story.
All opinions expressed (unless otherwise noted) are the posters and NOT the posters employers. The poster in NO WAY is/will speak for his employers. "Arguing with an engineer is like mud wrestling with a pig. After a couple of hours, you realize the pig likes it"
foxeng is offline
post #370 of 16937 Old 09-26-2007, 03:49 PM - Thread Starter
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Yep - 21 logos - Separate Golf and Versus logos, but a single Starz logo instead of separate E & W.
post #371 of 16937 Old 09-26-2007, 03:51 PM
paule123's Avatar
Quoted: 12 Post(s)
Originally Posted by galoot View Post
i guess what i'm reall getting at is the channels appear 9/10's widescreen with small black bars on ech side. what's up with that?
I noticed the same thing when I got my HR20 a couple months ago. I forgot what I did to fix it... I'm not at home now to check... I think maybe the D* receiver is not properly set to 16:9 display ratio ?
FWIW, here was my question on DBSTalk:
http://www.dbstalk.com/showthread.php?t=89503
paule123 is offline
post #372 of 16937 Old 09-26-2007, 03:52 PM
richard korsgren's Avatar
You will only get the newer MPEG4 HD channels with the newer MPEG4 H20 receiver, 5 lnb dish and subscription to HD channels. You will then get the newest HD channels if they are in your tier of SD programming.
richard korsgren is offline
post #373 of 16937 Old 09-26-2007, 03:55 PM
[quote=foxeng;11737643]
It will be several years before 50 percent of the population is viewing HD content.
post #374 of 16937 Old 09-26-2007, 04:05 PM
..watching travel shows on PBSHD..getting ready to watch 'WAR' by Ken Burns at 8 tonite. PBSHD shows may only be in MPEG2 but, in my opinion, I see none of these MPEG4 channels beating PBS for quality on the screen. At best, a few may look as good. Smithsonian, by far, great content and great HD. I hope NatGeoHD can do as good as Smithsonian.
post #375 of 16937 Old 09-26-2007, 04:06 PM
AAF
AAF's Avatar
What does the Weather Channel produce in HD? Is it only the big map graphic shots?
When seconds count, the police are only minutes away.
AAF is offline
post #376 of 16937 Old 09-26-2007, 04:13 PM
twelvepbrs's Avatar
Have you tried putting the BBC before the first diplexer? it worked for my cable service, not sure about OTA though, but I'd imagine that cable uses even higher frequencies than OTA so maybe just give it a try if it's not too hard.
We get CW-HD via D* in Los Angeles
twelvepbrs is offline
post #377 of 16937 Old 09-26-2007, 04:17 PM
foxeng's Avatar
Quoted: 184 Post(s)
Liked: 74
The issue is with the new 5 LNB dish is it uses many of the OTA frequencies to get the Ka band to the receiver. You can't have two signals trying to use the same frequency at the same time. It is highly doubtful you will ever be able to diplex OTA and the sat signals as long as this method is used.
foxeng is offline
post #378 of 16937 Old 09-26-2007, 04:36 PM
toboggan's Avatar
How could a company possibly piss off their customer base by launching more HD? Easy, leave out ESPN and HBO thus making sure a good portion of your customer base that cannot get the 119 or 110 don't get these channels. Instead, I have 5 Starz and a bunch of channels not showing more than a few hours of HD daily. Great plan morons.
SEVENTY channels and two of the most popular ones with HOURS and HOURS of true HD content are not included. UGH@!
toboggan is offline
post #379 of 16937 Old 09-26-2007, 04:38 PM
Snuffy101's Avatar
It appears the some channels are zooming the SD 4:3 frame while cropping the top and bottom. For some reason thew are not filling the 16:9 frame horizontally, leaving about 5% on the left and right. Discovery HD is one that does this, hence the small pillar-box black lines in the sides.
None of this is as bad as the History Channel that just stretches everything and gets an F in my book. Smithsonian HD is by far the best of the lot, give em an A.
Snuffy
Snuffy101 is offline
post #380 of 16937 Old 09-26-2007, 04:39 PM
obxdiver's Avatar
Liked: 49
Well I have had time to make an opinion of the initial roll-out
So Far what I see from the 21 channels are:
A&E HD (265) CSI-Miami Appears to be HD but very soft. Nowhere near what I saw on the channel 9300 Monday night.
Animal Planet HD (282) Zoomed 4x3 Material
Big Ten HD (220) Very clean HD
CNN HD (202) Very clean HD when in the right studio
Discovery HD (278) Zoomed 4x3 Material
History Channel HD (269) Zoomed 4x3 Material
TLC HD (280) Zoomed 4x3 Material
NFL Network HD (212) Showing 4x3 in OAR
Science Channel HD (284) Zoomed 4x3 Material
Smithsonian HD (267) Very clean HD
TBS HD (247) Zoomed 4x3 Material
Versus HD / Golf Channel HD (604) Showing 4x3 in OAR
Weather Channel HD (362) 4x3 except for on screen graphics
The Movie Channel HD (544) Not Subscribed...can't comment
SHO Too HD (538) Not Subscribed...can't comment
Showtime HD West (540) Not Subscribed...can't comment
Starz Comedy HD (519) Not Subscribed...can't comment
Starz HD East (520) Not Subscribed...can't comment
Starz HD West (521) Not Subscribed...can't comment
Starz Edge HD (522) Not Subscribed...can't comment
Starz Kids and Family (518) Not Subscribed...can't comment
So if u like 4x3 material zoomed then you are a happy camper tonight....otherwise....I am kinda disappointed.
obxdiver is offline
post #381 of 16937 Old 09-26-2007, 04:39 PM
rad
rad's Avatar
Quoted: 27 Post(s)
Not D*'s fault, they've always said you need 101/110/119 to get those current HD channels and 99/103 for the NEW had channels, they never said that the existing channels would be mirrored on 99/103 at this time. If ESPN and HBO are that important to you why did you go with D* in the first place since they've always been there?
rad is offline
post #382 of 16937 Old 09-26-2007, 04:41 PM
wco81's Avatar
Quoted: 1499 Post(s)
Liked: 556
Wait, aren't they going to add the CW and PBS locals as well as local independent stations?
wco81 is online now
post #383 of 16937 Old 09-26-2007, 04:48 PM
generalpatton78's Avatar
Pbs wants all their sub channels carried and D* doesn't want to.
Fredfa-"I agree with generalpatton78 "
generalpatton78 is offline
post #384 of 16937 Old 09-26-2007, 04:50 PM
ichen's Avatar
Interestingly after the upgrade.. I could not get the HD channels (even tho i could see 480, 481)
but i COULD get 267 (smithsonian HD)... [weird, huh?]
(but not AEHD, TLCHD, TWCHD, etc)
After futzing around for an hour, we figured that the old grandfathered packages (total choice plus, etc) is the problem..
So, if you have those, you have to 'upgrade' to the new choice, choice xtra, plus dvr, plus hd dvt packages..
Now, it all works.
I figure I could get 267 because it really was a 'new channel'.. but tech support nor programming could get the new HD channels to work with the old 'base packages'..
Just to save some headaches, in case people are having that problem..
Perhaps a fact to that can be added to the first page 'sticky'
ichen is offline
post #385 of 16937 Old 09-26-2007, 04:53 PM
vurbano's Avatar
Pretty much what I suspected. Just because they slapped an HD logo on the channel does not mean HD. The good news is now maybe we can get our locals in HD??? If LIN stops being Aholes.
vurbano is offline
post #386 of 16937 Old 09-26-2007, 04:58 PM
vurbano's Avatar
Now, it all works.
Wasnt a problem for me. I have total choice plus and get all the channels.
vurbano is offline
post #387 of 16937 Old 09-26-2007, 05:01 PM
jimqk's Avatar
The best part about all this is that it's is only the beginning. Yeah, while you'd be better off watching some programs on their SD counterparts, it's gonna be nice to watch playoff baseball on TBS in HD.
jimqk is offline
post #388 of 16937 Old 09-26-2007, 05:05 PM
toboggan's Avatar
Not DirecTV's fault? How so. Does the technology dictate that these two extremely popular channels be carried on sats that a large portion of their customer base? No. Do HBO and ESPN require MPEG2? No. It is entirely DirecTVs decision and for the record, I've had two CSRs tell me that these would be transitioned when the new sats go online. If that ends up NOT being their plan, I will change providers.
toboggan is offline
post #389 of 16937 Old 09-26-2007, 05:07 PM
obxdiver's Avatar
Liked: 49
Most of the Zoomed 4x3 channels I listed above are even stretching and zooming the freeking commercials.
This is true indication of a full time zoom they have active because 99% of all commercials are still 4x3.
And their stretch seems to be fully linear making people really look short and fat.
obxdiver is offline
post #390 of 16937 Old 09-26-2007, 05:10 PM
maxman's Avatar
Originally Posted by jambroni View Post
Of course he doesn't.
Ignorant comments like that are the reason I quit hanging around here a looooong time ago.
And yet...
...here you are!
ISF calibrated by Eliab - and lovin' it!
My DVD Profiler
maxman is offline
Closed Thread HDTV Programming
