DirecTV HDTV - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 514Likes
post #721 of 16937 Old 09-28-2007, 05:36 AM - Thread Starter
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
Originally Posted by Maverickster2 View Post
if OAR of 4:3 SD Content is NOT an option
It is an option. An option most are taking.
CPanther95 is offline
post #722 of 16937 Old 09-28-2007, 05:44 AM
j_murdock's Avatar
Anybody in the North East getting these new HD channels? I just get the "Searching for Signal" message. I called D* and they said they are troubleshooting.
--Mike
j_murdock is offline
post #723 of 16937 Old 09-28-2007, 05:49 AM
Neutron_Boy's Avatar
After punching in channel number on remote I get the same message. Then, I channel down, and channel up back to the station I want and the signal comes in. It is a pain in the arse, but it works.
NB
Neutron_Boy is offline
post #724 of 16937 Old 09-28-2007, 05:56 AM
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1489
Has anyone attempted to get any bitrate/broadcast resolution data off these new mpeg4 channels. It would be nice to see what D* is actually spitting out.
D-Nice is offline
post #725 of 16937 Old 09-28-2007, 06:08 AM
thepicman's Avatar
Originally Posted by CPanther95 View Post
There is 4:3 content such as old movies shot on film that can be remastered in HD and presented in 4:3 format. Same as a 2.35:1 movie presented in HD is still HD even though it doesn't "fill the screen".
Rudolph on CBS the last few years for example.
thepicman is offline
post #726 of 16937 Old 09-28-2007, 06:09 AM
SamwisetheBrave's Avatar
Quick qt. before I call D*.
I'm getting 0s, 2 80s, some 50s, 60s, 70s, some 30s on my 103(b)
transponders. Is it the dish...or will D* continue to do stuff that will cause them to improve?
In others words, wait or call and insist on a dish tweak?
SamwisetheBrave is offline
post #727 of 16937 Old 09-28-2007, 06:21 AM
SteveC's Avatar
I just looked at the Recent Activity on my account online and see that they have just today added no charge entries for Cinemax HD access and Sports HD access. I'm a Premier subscriber.
SteveC is offline
post #728 of 16937 Old 09-28-2007, 06:23 AM
morgan1112's Avatar
[quote=SamwisetheBrave;11752762]Quick qt. before I call D*.
QUOTE]
I'd call them. All of my 103b's are over 90 w/ most of them over 95. Looks like your dish might need to be adjusted.
morgan1112 is offline
post #729 of 16937 Old 09-28-2007, 06:51 AM
Sirluckyj's Avatar
I have a HR20 and when swithing to one of the D10 channels, there is slight freeze before action continues. It seems when switching between D10 channels there is no freeze but only when switching from a non D10 to D10. Anyone else see this?
Jim
Sirluckyj is offline
post #730 of 16937 Old 09-28-2007, 07:00 AM
mx6bfast's Avatar
Agreed on the deceptiveness of the practice and agreed on the preference for OAR of 4:3 SD content, but I would like to reiterate that if OAR of 4:3 SD Content is NOT an option (as the guy from the network suggested) and we absolutely MUST live with manipulation of the material at the source/cablenet level, then I MUCH prefer the zoom/crop/mild stretch method that has been employed by the Discovery channels (the one that has the slim bars on the side) than the garbage some of the other cablenets (i.e. A&EHD) are doing.
I do agree that some channels do it much worse than others.
If I want to watch distorted 4:3 SD content I'll watch the non-HD channel.
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #731 of 16937 Old 09-28-2007, 07:10 AM
tonybradley's Avatar
Jim
Same thing happens with me as well. Probably takes a split second to sync up with the other satellite when going back and forth. If you are already syncd to that sat, it won't lag when changing channels. Just a guess as I really don't know.
Tony
tonybradley is offline
post #732 of 16937 Old 09-28-2007, 07:12 AM
mx6bfast's Avatar
If the TV and STB can't stretch - then viewers have the option of switching to the SD channel and manipulating it however they want.
Those that want the best quality with the programming presented in its proper format should be able to get the best the network has to offer on their premium HD channel - not switch back and forth depending on the program.
It's the equivalent of HBO putting a stereo soundtrack on the SD programming on HBO HD and the DD5.1 soundtrack on their SD channel.
Great post, keyword premium. Premium means best right? Manipulating 4:3 SD content is the best PQ that can be offered?
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #733 of 16937 Old 09-28-2007, 07:15 AM
Maverickster2's Avatar
Yeah, but that's not the point. I don't mean if it's "not an option" from an objective, fact perspective; I mean if it's "not an option" from a marketing cablenet perspective. That is, if the cablenet has determined (in its infinite wisdom) to not do 4:3 SD content in OAR, and that won't change, I prefer the way Discovery does its manipulation. That's all I'm saying, really.
Maverickster2 is offline
post #734 of 16937 Old 09-28-2007, 07:18 AM
sleeks's Avatar
That is where we must email, write letters, and call and complain. This forum has been able to push change at some networks in the best. We should not "settle" for something that is "not an option" when it is actually an option.
-Brian
sleeks is offline
post #735 of 16937 Old 09-28-2007, 07:25 AM
sleeks's Avatar
Originally Posted by DTTC View Post
Jeremy W is correct. Discovery, Science, TLC and Animal Planet are using very good upconverters. The 4:3 content is zoomed and cropped, and very slightly stretched (linear stretch, not flexed). The attempt has been made to fill as much of the 16:9 screen as possible with the least amount of negative impact. Opinions on how succesful we have been will naturally vary.
HD content airs as 16:9 of course, as does 4:3 SD letterboxed content. This SD content is upconverted and zoomed to fill the 16:9 screen with no loss of content and no distortion.
Your numerous comments about OAR are noted. It's fine for those who understand that HD can include 4:3 content, but there are far more viewers who believe that if it doesn't fill the screen it's not HD. There are even some postings here on the forum complaining about HD channels not filling the screen. As much as we may not like it, upconverted SD will be part of these channels for some time, though the percentage of true HD is rapidly increasing. Prime time is the best time to catch true HD.
Thats a shame. CNN, ESPN and others do just fine showing 4:3 SD content in a 4:3 window with no stretching/zooming.
Even though the public is still largely uneducated with regards to HD, your channels can help. Instead, the public turns on your channel and sees a zoomed/stretched upconverted picture that almost fills their screen. Talk about confusing.
-Brian
sleeks is offline
post #736 of 16937 Old 09-28-2007, 07:28 AM
rlb
rlb's Avatar
Quoted: 1787 Post(s)
Liked: 1458
Originally Posted by bwaldron View Post
Following this argument is confusing. Jeremy's point is correct, 245 is currently in MPEG2 as are the other remapped channels. Take off your BBCs and you will still receive them.
Unless Scobuck or others have inside info that they will be switching TNT-HD on 245 to MPEG4 (or adding an MPEG4 version as 245-1), I am not seeing what the debate is about?
Maybe I'm wrong, but BBCs don't necessarily hold the answer. They are related to frequency band/satellite, not MPEG format.
If D* chose to send MPEG4 signals from one of the old sats (can be done because they just relay anything sent to them), it would still be on that old sat frequency band and the BBCs would not be required.
Samsung 65JS9500 and 65F9000 w/SEK-3500U, Denon AVR X3300 & Outlaw 755
Samsung K8500, OPPO 103-D, PS3, HR44, HR24, and Roku Ultra
rlb is offline
post #737 of 16937 Old 09-28-2007, 07:32 AM - Thread Starter
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
As do virtually all of the 700-800 digital broadcast affiliates. These handful of exceptions aren't at the mercy of public ignorance - they're perpetuating it, and in many cases, causing it.
post #738 of 16937 Old 09-28-2007, 07:32 AM
mx6bfast's Avatar
And to add to this, the list is here that has been reported so far. http://www.avsforum.com/avs-vb/showthread.php?t=914099
Yep. When these first came on there were many many posts saying the HD PQ doesn't look that good. Just imagine what those are thinking who don't visit the boards like avs and dbstalk.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #739 of 16937 Old 09-28-2007, 07:40 AM
rad
rad's Avatar
Quoted: 26 Post(s)
Liked: 27
That is true, the old sats don't care MPEG2/MPEG4 whatever. But think about it for a moment, if D* had the room to add 4 additional channels in MPEG4 along with keeping them in MPEG2 don't you think they would have done that months ago to add some new channels, not just dups of existing channels?
rad is offline
post #740 of 16937 Old 09-28-2007, 07:45 AM
Agreed. I've said my peace about what "brand" of manipulation I prefer (sort of like saying, "I would prefer to be kicked in the face, rather than kicked in the nuts"), but obviously, the "right" answer is for them to do it "right" -- i.e. 4:3 SD content broadcast in OAR (which is saying, "I'd prefer to not be kicked at all, thank you").
Where do I sign my petition?
--Mav
post #741 of 16937 Old 09-28-2007, 07:56 AM
mx6bfast's Avatar
Originally Posted by plgh View Post
My channel guide lists all the new HD channels but in spite of multiple soft/hard reboots, sat. resetups etc. on H20 and HR20 I get the dreaded "searching for signal #711". All other HD/SD same as it ever was. Cust. service said the sats. aren't up and running but since everyone else is getting reception that must mean Dallas gets its own satellite. Any other N. Texas Customers with similar probs? (sorry for the length)
Pete
I'd call back and get another csr. All of these new channels are coming from the same sat.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #742 of 16937 Old 09-28-2007, 07:58 AM
plgh's Avatar
Quoted: 13 Post(s)
Same prob in N. Texas
Pete
plgh is offline
post #743 of 16937 Old 09-28-2007, 08:00 AM
D-Nice's Avatar
Quoted: 694 Post(s)
Liked: 1489
Anyone?
D-Nice is offline
post #744 of 16937 Old 09-28-2007, 08:23 AM
mx6bfast's Avatar
Anyone?
no
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #745 of 16937 Old 09-28-2007, 08:38 AM
aviators99's Avatar
Originally Posted by aviators99 View Post
Related, but opposite question:
What about those (very few) of us who have the HD package, but not any basic tier? Will we get the channels? I can't test it, because I don't have an Mpeg4 receiver yet.
Originally Posted by richard korsgren View Post
You will only get the newer MPEG4 HD channels with the newer MPEG4 H20 receiver, 5 lnb dish and subscription to HD channels. You will then get the newest HD channels if they are in your tier of SD programming.
Are you sure? This is the opposite of the MPEG2 situation, where for example I am receiving ESPN and ESPN2 even though they are not in my tier of SD programming.
aviators99 is offline
post #746 of 16937 Old 09-28-2007, 08:43 AM - Thread Starter
CPanther95's Avatar
Quoted: 72 Post(s)
Liked: 94
You are in a very select few.
You'll be the one telling us definitively how they handle your situation, we can only speculate.
post #747 of 16937 Old 09-28-2007, 08:47 AM
Utahred1981's Avatar
Has anybody else noticed that they have their HD Extra Package available now on the D* site?
Utahred1981 is offline
post #748 of 16937 Old 09-28-2007, 09:02 AM
bwaldron's Avatar
I understand that there is no technical relationship b/t band and compression scheme -- hence people can receive their HD Locals without the BBCs (or the SWM module, which incorporates the BBC functionality). There is a practical relationship, though: the new MPEG4 channels from D10 require the BBCs.
bwaldron is offline
post #749 of 16937 Old 09-28-2007, 09:31 AM
Ken Ross's Avatar
Quoted: 6590 Post(s)
Liked: 7299
Originally Posted by mp11 View Post
That dream wont come true until 1080P. Then you'll be blown away.
A well done 1080i broadcast (full rez) on a digital display capable of good deinterlacing, is 1080p.
Ken Ross is offline
post #750 of 16937 Old 09-28-2007, 09:44 AM
ernie's Avatar
Originally Posted by squidboy View Post
You are correct. The satellites just take an uplinked signal and send it back down. They don't care what it is.
Theoretically, D* could upgrade everyone to MPEG-4 capable STBs (including SD only users) and then change all of their signals on all of their satellites to MPEG-4 and greatly increase their overall channel capacity (and/or increase quality). I doubt they will any time soon, due to the cost of replacing the millions of boxes out there.
The manufacturing cost on STBs is coming down fast enough that replacing them might be cheaper (better return-on-investment) than building and launching new satellites. It is a logistic nightmare though.
Ernie
ernie is offline
Closed Thread HDTV Programming
