DirecTV HDTV - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 511Likes
Closed Thread
post #91 of 16937 Old 09-26-2007, 08:26 AM
sleeks's Avatar
Originally Posted by kevbo1861 View Post
OK, what is the deal with all this "error 771 searching for satellite" nonsense I am getting on half these channels?
Don't tell me I have to have a tech guy come out here or even have to swap out my H-20. Anyone else dealing with this?
Do you have your BBC connected? Maybe you have a bad one?
-Brian
sleeks is offline
post #92 of 16937 Old 09-26-2007, 08:27 AM
herb s.'s Avatar
Are the present MPEG-2 HD channels ie HDNET, UHD, etc. being transmitted in the MPEG-4 format as well. If so how does the picture quality compare?
herb s. is offline
post #93 of 16937 Old 09-26-2007, 08:29 AM
mx6bfast's Avatar
I setup a thread for people to post what channels are doing with 4:3 content. Please post your sightings here. http://www.avsforum.com/avs-vb/showthread.php?t=914099
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #94 of 16937 Old 09-26-2007, 08:30 AM
Travis M's Avatar
Quoted: 12 Post(s)
Originally Posted by arhughes View Post
My work has 5 H20s. 4 of them will let me tune to the CNNHD and Weather HD channels, but all say "Channel not purchased". The fifth one won't even tune to the new HD channels.
I was on the phone with a CSR for 50 minutes and she kept telling me that "not all channels broadcast in HD so you won't get HD for every channel". I had to direct her to the DirectTV website where it says CNNHD and Weather Channel HD have just launched.
While on the phone with her, one of the 4 almost-working H20s started showing the 771 message when I tried to tune to CNNHD. She then called technical support and that person told her that there were some problems launching the channels and none of them would be available until October. I asked if that was just for businesses and she said that the tech person only deals with business accounts so they wouldn't know anything about residential accounts.
Is anyone with a commercial account able to get the new HD channels?
I have a commercial account. I'm on call with them right now. I can't get any of the new channels and they are saying it is not avail until Mid October
Travis M is offline
post #95 of 16937 Old 09-26-2007, 08:32 AM
kevbo1861's Avatar
I rebooted my system to see if that would solve my "error 771" problem. Now I am not getting stations that I had before the reboot and getting some that I didn't have before.
kevbo1861 is offline
post #96 of 16937 Old 09-26-2007, 08:32 AM
mp11's Avatar
v
mp11 is offline
post #97 of 16937 Old 09-26-2007, 08:34 AM
richall01's Avatar
Originally Posted by MACKD413 View Post
Not getting the Starz channels, anyone else having this problem? I have the premier package>
Same thing in South Ga.
richall01 is offline
post #98 of 16937 Old 09-26-2007, 08:34 AM
bocktar's Avatar
We are getting Smithsonian HD on our commercial account, but nothing else.
bocktar is offline
post #99 of 16937 Old 09-26-2007, 08:36 AM
tim99's Avatar
Because stretching the content has nothing to do with HDLite.
Originally Posted by Revolutionary View Post
How does your response negate his impression. If most of the "new HD channels" that they are broadcasting are upscaled/stretched SD, then the channels may be mostly unimpressive. That doesn't mean the service is unimpressive, just the content that is available right now. FWIW, just about everybody, since the launch of TNT-HD, has denigrated it as a poor excuse for HD (A&E is even poorer) due to its incredibly low bit-rate and really awful upscaling/stretching. General impressions are that many of these "HD channels" are doing the same thing for the time being (which isn't that big of a surprise).
Also, not good to antagonize the "old farts" with noobish suggestions like "get a new TV if you can't tell the difference."
PVR user since the late 1900's . . .
tim99 is offline
post #100 of 16937 Old 09-26-2007, 08:37 AM
mp11's Avatar
Am I the only one that would like to see these new HD channels grouped togther like the old HD package? Sure would make it easier to surf the HD channels.
mp11 is offline
post #101 of 16937 Old 09-26-2007, 08:38 AM
ehomer's Avatar
Originally Posted by richard korsgren View Post
I am talking ..a channel like A and E..showing a well done Fox program (HD)..'24' and not re-showing it correctly. It is distorted (zoomed)..not that sharp. It is just not pleasant to view it. Some of these channels are showing everything wide screen when they were producted and filmed (taped) in 4 x 3 format. As I mentioned, some programmers have learned how to present HD and some have not. Some even show 4 x 3 commercials in wide screen format. CNNHD seems to be doing things right.
24 and other programs look bad on A&E because A&E takes the 4:3 butchered version that is playing on their SD channel and then stretches it to fit the entire HDTV screen (16:9). You end up with pan&scan + strechorama
The original program might exist in native 16:9 HD format but that doesnt mean that A&E bothered to get the content that way... they would rather stretch the content they allready have (4:3 SD)... after all, why should they be bothered with the cost of aquiring REAL HD programming?
ehomer is offline
post #102 of 16937 Old 09-26-2007, 08:38 AM
mx6bfast's Avatar
But should you still see motion blocking with SD content? I've seen it on a few that I was able to look at.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #103 of 16937 Old 09-26-2007, 08:39 AM
skyehill's Avatar
Liked: 52
Originally Posted by spongebob View Post
Early impressions:
Not impressed. Mostly HD-Lite and typical zoom/strech BS
bob
What an incredibly clownish, uninformed thing to say. None of the MPEG4 channels are "HDLITE", and if you see the "typical" zoom/stretch "BS", it's the fault of the channel provider, not the channel carrier. But I've read your other posts, so I guess THE SKY IS STILL FALLING!
skyehill is offline
post #104 of 16937 Old 09-26-2007, 08:41 AM
arhughes's Avatar
Originally Posted by captdusty View Post
But that fifth receiver sounds like a seperate issue -- check in the menu that it's set for 5-sat dish, confirm it has BBC connected, etc. A restart wouldn't hurt either, I guess.
You were right, that receiver wasn't setup correctly. I reran the satellite setup and set it to 5-sat and now it will tune to the new HD channels. Though they all still show "Channel not purchased (721)".
arhughes is offline
post #105 of 16937 Old 09-26-2007, 08:43 AM
beatles6's Avatar
I also have the premier. All Starz HD channels have 721 message. Spoke to a D* CSR who said they have to send the report to a supervior who will add the "Starz HD pacakge" to the account. Should be on sometime today. We'll see.
beatles6 is offline
post #106 of 16937 Old 09-26-2007, 08:46 AM
markom911's Avatar
I have all the channels....I think. Are we supposed to be getting extra HBO HD channels? I have all th starz/showtime/movie channel but no extra HBO HD channels. Is there an accurate list of all the new HD channels that were added today?
markom911 is offline
post #107 of 16937 Old 09-26-2007, 08:47 AM
retromzc's Avatar
Quoted: 13 Post(s)
No problems here, all channels coming in fine, including Starz. FWIW they all look great, the only thing that bothers me is the zoom and stretch programming. Using two H20-600 receivers. Yes sd channels come in first then channel up to the HD versions.
R. B.
retromzc is offline
post #108 of 16937 Old 09-26-2007, 08:48 AM
tim99's Avatar
Really? I haven't noticed that but I haven't looked at much of the SD content yet.
tim99 is offline
post #109 of 16937 Old 09-26-2007, 08:48 AM
Brian26339's Avatar
Channel 77 had a list with all channel numbers a little while ago. I suppose it's still there.
Brian26339 is offline
post #110 of 16937 Old 09-26-2007, 08:50 AM
tim99's Avatar
Also first post of this thread!
tim99 is offline
post #111 of 16937 Old 09-26-2007, 08:50 AM
markom911's Avatar
Never mind guys....here's the offical list from D* These are the exact channels that are available. If you don't have one of these channels then you are missing some.
post #112 of 16937 Old 09-26-2007, 08:51 AM
RAVEN56706's Avatar
Early impressions:
bob
time to upgrade your tv.
2011 SUPERBOWL CHAMPIONS- New York Giants!!!
Gamertag: GENERAL CUPKAKE
RAVEN56706 is offline
post #113 of 16937 Old 09-26-2007, 08:51 AM
spongebob's Avatar
Quoted: 38 Post(s)
Originally Posted by Utahred1981 View Post
Bob, you will never be satisfied will you?
I will when HD is really HD. Do you even have an HD set?? Prescription glasses need updating?
bob
spongebob is offline
post #114 of 16937 Old 09-26-2007, 08:52 AM
spongebob's Avatar
Quoted: 38 Post(s)
My $7000 plasma is just fine, than you
bob
post #115 of 16937 Old 09-26-2007, 08:53 AM
TulsaCoker's Avatar
I love the way D* did the new channels. To me that's whats irritating about E* and cable. The HD are completely seperate from the SD. If you really just want the HD choose that in your guide.
TulsaCoker is offline
post #116 of 16937 Old 09-26-2007, 08:54 AM
dgcaste's Avatar
I think he's trying to give his opinion on the overall experience of D* HD, and not placing blame on any particular party. I think he wants D* to provide purely/mostly MPEG4, and if they're feeding us zoom/stretch channels, D* should hold off on the broadcast. The fact that they're relaying these signals to their customers means that they're being condescending and in a way manipulative.
Attacking immaturity with immaturity? "Rolleyes" hardly gets the point across.
dgcaste is offline
post #117 of 16937 Old 09-26-2007, 08:54 AM
mx6bfast's Avatar
I posted in the closed thread.
The 6:30 and 7 programs on Smithsonian, ESPN channels 73 and 206 when the graphics came flying in, and also on DHD during testing mode (which might not count). That's all I had the time to check this morning, my son had control on the tv.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #118 of 16937 Old 09-26-2007, 08:55 AM
richard korsgren's Avatar
...and, I agree. Directv is now doing a very good job of bringing us HD. It is now up to the programmers (channels such as A and E and TVT, etc.) to wake up and start doing HD correctly. If they have to do a 4 x 3 program, that is ok..just do it correctly. When others are doing it correctly, I see no valid reason why a few channels are not showing a HD (16 x 9) program correctly. So, let us begin to write to these programmers who need to do HD correctly.
richard korsgren is offline
post #119 of 16937 Old 09-26-2007, 08:56 AM
RAVEN56706's Avatar
bob
lol....
post #120 of 16937 Old 09-26-2007, 08:57 AM
Mozvz's Avatar
Don't tell me I have to have a tech guy come out here or even have to swap out my HR-20. Anyone else dealing with this?
Own two H20's. Slim line dish. Northeast PA resident. Latest software upgrade. Gone through setup more times then I can count.
I've had the 771 error since this entire implementation of these new HD channels. Cold boots, warm boots, reseating the BBC's, spent an hour with D*'s tech support and nothing but that searching for satellite 771 error. HD lite subscriber since the dino's roamed the earth. Patience will prevail unless someone has a silver bullet.
"Man plans, God laughs"
Mozvz is offline
Closed Thread HDTV Programming
