DirecTV HDTV - Page 496 - AVS Forum | Home Theater Discussions And Reviews
 511Likes
Old 07-25-2014, 08:27 AM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
Originally Posted by dishrich View Post
Are you sure about 110??? The 110 position (test channel) have been removed from all (D* American) receivers & according to lyngsat, there is nothing even on that bird now...
According to Dr. J's transponder tracking/mapping at DBSTalk, http://www.dbstalk.com/topic/200951-...fresh-7232014/ there's a number of channels on 110:
2 VH1 262 8 D5 @110W 2 COOK 267 8 D5 @110W 2 NIKe 322 10 D5 @110W 2 DXD 326 8 D5 @110W 2 BOOM 336 10 D5 @110W 2 NKJR 337 10 D5 @110W 2 EWTN 350 10 D5 @110W 2 LMN 518 8 D5 @110W 2 HB2 565 10 D5 @110W 2 HBOS 567 12 D5 @110W 2 HBF 568 12 D5 @110W 2 MMAX 572 12 D5 @110W 2 SHO2 578 8 D5 @110W 2 SHO3 580 10 D5 @110W 2 EXTR 581 12 D5 @110W 2 TMCe 582 10 D5 @110W 2 EACT 588 12 D5 @110W 2 ENCe 589 8 D5 @110W 2 ENCFAM 590 12 D5 @110W 2 ESNN 646 12 D5 @110W 2 ESPC 647 10 D5 @110W 2 FS1 655 12 D5 @110W 14 PPV 668 3 SW1 @103W 14 PPV 3 2 HLN 708 8 D5 @110W 2 BTV 710 12 D5 @110W 2 FYI 744 12 D5 @110W 2 BBCA 768 10 D5 @110W
rad is offline
Old 07-25-2014, 11:14 AM
P Smith's Avatar
Quoted: 534 Post(s)
Liked: 290
don't relay to LS site for current detailed info
see Dbstalk's Gary Toma and Dr.J dedicated thread with full info about sat/tpn/channels updating weekly
P Smith is offline
Old 07-25-2014, 01:18 PM
dishrich's Avatar
Quoted: 56 Post(s)
Liked: 39
Thank you gentleman for pointing this out; I always wondered what D* was going to do (or DID) with the 110 slot when it disappeared from our receivers...
dishrich is offline
Old 07-25-2014, 01:55 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
110's three transponders still whow on my receivers, you need the 5LNB in order to see them and 119.
rad is offline
Old 07-25-2014, 01:58 PM
Keenan's Avatar
Quoted: 2205 Post(s)
Liked: 1982
Does the HR44 cost any more per month than the HR24?
Keenan is offline
Old 07-25-2014, 02:02 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
If you don't have the Whole Home DVR monthly fee ($3) on your account already then that would be added, else it's the same monthly charges.
rad is offline
Old 07-25-2014, 02:54 PM
Keenan's Avatar
Liked: 1982
I'm guessing that's added even though I wouldn't be using it? I just want the extra tuners.
Keenan is offline
Old 07-25-2014, 03:05 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
That is correct, get a Genie get the WHDVR fee added.
rad is offline
Old 07-25-2014, 03:09 PM
dishrich's Avatar
Quoted: 56 Post(s)
Liked: 39
I DO have the 5LNB & what I meant (should have said again) is that the 110 test channel is gone...
dishrich is offline
Old 07-25-2014, 04:38 PM
Keenan's Avatar
Liked: 1982
Keenan is offline
Old 07-26-2014, 08:54 AM
joed32's Avatar
Quoted: 70 Post(s)
Liked: 65
It's worth the 3 bucks anyway.
joed32 is offline
Old 07-26-2014, 10:02 AM
Keenan's Avatar
Liked: 1982
Yes, $3 for 3 more tuners is pretty good value.
Keenan is offline
Old 07-29-2014, 09:45 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
Can someone check their guide and tell me if Defiance on Syfy HD is listed as HD in the guide, Thursday 8:00 pm 244(HD)? I was checking my todo list and Defiance wasn't going to record until Saturday at 1:00 am.
rebkell is offline
Old 07-29-2014, 10:02 PM
Keenan's Avatar
Liked: 1982
Nope, and neither does Dominion. MY TDL shows those two shows recording on Friday at 8 and 10 so I'd say it's 50/50 as to whose fault it is as DIRECTV's guide data is crap in general and NBC/Uni channels are known for sloppy guide data as well. It shows as HD on Friday BTW so I'm going with Syfy as the culprit on this one.
Keenan is offline
Old 07-29-2014, 10:57 PM
HDTVChallenged's Avatar
Liked: 215
The guide data has been hosed all season (wrtt "HD" tag.) This is the first week the SM has failed to pick up the two shows automatically ...
HDTVChallenged is offline
Old 07-30-2014, 11:33 AM
Keenan's Avatar
Liked: 1982
Yup, I'm now convinced it's yet another case of the sloppy/who cares/cheap attitude DIRECTV takes towards guide data as my Comcast-supplied TiVo has the correct recording dates and clearly indicates HD in the description.
Keenan is offline
Old 08-06-2014, 07:09 PM
rebkell's Avatar
Quoted: 413 Post(s)
Liked: 283
Ok, this has happened several times lately, it just happened on TNT-HD ... all of a sudden I lose my buffer, there is like a short blackout and then the video comes back and I check and I have no buffer at all, even though I've been watching the station for a while. No recordings are scheduled or anything like that. Has this been happening to anyone else, it seems to have started happening since they started the automatic rewind thing, I have no proof it just seems that way. Also I've had two recordings 'Major Crimes' and last night 'Rizzoli and Isles' not record at their scheduled time, both failing because of "This episode was canceled because of its recording permissions.(15)"
Anyone else having any problems?? I've got an old HR20-100 receiver, other than these weird things I haven't noticed anything out of the ordinary.
rebkell is offline
Old 08-07-2014, 09:31 AM
Sharp1080's Avatar
Quoted: 557 Post(s)
Liked: 352
Thanks for sharing that information. I lost a show that was set to record that I fortunately found again. I seem to get these long pauses when changing between stations when viewing broadcasts. Not sure if they are even related issues. I am using an HR-22 receiver. I did a reset last week and it still seems to be in the system?
Sharp1080 is offline
Old 08-07-2014, 04:06 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
The long pauses between station changes are normal. Annoying as h*ll, but normal. It seems to be normal for satellite. When I had E*, it did the same thing.
ti-triodes is offline
Old 08-07-2014, 04:17 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
As mentioned in a prior post, make sure that you have native display turned off in the DVR's settings, that will speed up channel changing a bit.
rad is offline
Old 08-07-2014, 09:05 PM
Sharp1080's Avatar
Quoted: 557 Post(s)
Liked: 352
It has after switching it off, thank you.
Old 08-08-2014, 10:09 AM
Redneck_Randy's Avatar
Where is that on the HR34 ?
Redneck_Randy is offline
Old 08-08-2014, 10:40 AM
I WANT MORE's Avatar
Quoted: 399 Post(s)
Liked: 256
Keep in mind that depending on your displays capabilities turning off native may have a negative effect on picture quality.
Perhaps I misremembered.
I WANT MORE is offline
Old 08-08-2014, 11:31 AM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
It's under the settings then display menu.
rad is offline
Old 08-08-2014, 06:46 PM
Wolfie's Avatar
Quoted: 20 Post(s)
I heard the SEC Network will be on 611, but when I go to add 611to my favorites the channel doesn't show up. Has anyone heard anything different on the location of the SEC Network?
Wolfie
Wolfie is offline
Old 08-08-2014, 06:58 PM
rad
rad's Avatar
Quoted: 24 Post(s)
Liked: 24
Wolfie
You have to wait until it's actually in the guide data.
rad is offline
Old 08-08-2014, 08:14 PM
Aliens's Avatar
Quoted: 1310 Post(s)
Liked: 1702
The anal idiot that I am, in my experiments between the two, I'm beginning to think the timing is in the channel selected (please don't ask me to explain why that would be, because I don't know; I can only report what I see). Some channels can be as fast as a second before you see a picture, while others can take as long as 3 seconds, regardless of the display setting. Just my anal observations. YMMV.
As you anal idiots know, a split second can seem like an eternity.
Aliens is online now
Old 08-09-2014, 10:57 AM
Old 08-09-2014, 11:53 AM
Keenan's Avatar
Liked: 1982
Sounds like a reasonable hypothesis in that a different channel may mean a different transponder on a different satellite and the signal selection transition may not be a quick as a different channel on the same transponder/satellite.
It might also be hardware related, I just moved from a HR24 to a HR44-500 and it seems as if those channel changes are smoother and seem quicker though I haven't actually timed it. Another thing I notice is that I don't get the image blocking/breakup when coming to the end of a 30skip sequence, something I did not have on the HR20 but did have on the HR24. The menu/guide navigation on the HR44 is wicked fast though, much faster than any previous DIRECTV DVR I've used, no lag, press a button and it's done. I initially thought it was due to the use of RF but I switched to IR and it was just as quick, very impressive remote/navigation responsiveness.
Anyway, that was my unsolicited mini-review of the HR44 Genie DVR.
joe221 likes this.
Keenan is offline
Old 08-09-2014, 04:35 PM
Wolfie's Avatar
Quoted: 20 Post(s)
What I'm saying is that 611 is not available to add to my channels
Wolfie
Wolfie is offline
