DirecTV HDTV - Page 508 - AVS | Home Theater Discussions And Reviews
 34Likes
post #15211 of 15212 Unread Today, 08:33 PM
Liked: 0
Originally Posted by mexican-bum View Post
I do recommend upgrading to the genie, make sure the installer has an HR44, if they bring an HR34 refuse the install as they aren't nearly as good.
Also the genie has 5 recordable tuners. If you add 2 genie mini's and all 3 are used at the same time your genie will only have 2 recordable tuners. I says this because I recommend keeping the DVR and HD receiver you have now. That way you would have 7 total recordable tuners, and your HD receiver could record on either your current DVR or Genie. You would still have one shared playlist. The genie mini's are really just clients that steal a tuner from the genie but still cost $6.50, my point is if your going to pay $6.50 might as well be for a real receiver.
If you really do need the wireless then at least try to keep your current DVR.
Thanks for the feedback. I'm not quite sure I understand the hardware setup you are describing for me. I was under the impression I would have to give up my current equipment when "upgrading". I only have 3 TV's in my home... Two with the current DVR and receiver setup I described. Now I'm looking to add another receiver for a 3rd TV in a bedroom where there's no cable coax connection (hence what I thought was a need for dropping a genie mini at that location). I could be missing something and this may be what you are recommending but I suppose I could keep my current DVR, give up the current receiver (H24-100), add the new Genie DVR and a single mini. It seems that gets me the 7 tuners with only one mini 'stealing' one tuner from the mix.
Thanks again for the feedback on this. I'll likely DirecTV tomorrow and see what this setup will cost me compared to my current monthly bill.
bcaraway is online now
post #15212 of 15212 Unread Today, 08:44 PM
mexican-bum's Avatar
Quoted: 17 Post(s)
When you upgrade you have the option to add or replace, sounds like from what you describe you should replace the h24-100 with a genie and add a wireless mini and keep your current dvr. That way you would not lose your current recordings and have 2 more recordable tuners. I personally use my 2 tuner dvr for the kids to record their stuff and I have all 5 tuners on the genie to myself.
But again it's totally up to you, your original proposed setup would work fine, I just think keeping the extra Dvr is best since it doesn't cost a dime more. Also if the genie ever fails for some reason all the genie mini clients fail also as they are just parasitic clients, have an extra dvr also allows you to keep watching tv until genie is replaced.
mexican-bum is online now
Reply HDTV Programming
