DirecTV HDTV - Page 565 - AVS Forum | Home Theater Discussions And Reviews
 514Likes
Closed Thread
post #16921 of 16937 Old 05-06-2016, 08:03 AM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
Originally Posted by mdram View Post
a genie is a dvr, hr54/hr44/hr34. they each have 5 tuners and do all the work. they will work without any other unit
a mini genie is a slave/client unit that will not work without a genie
it has no tuner, just uses the feeds/dvr/ect from the main genie.
no main genie, and its just a paperweight.
This is right off my Directv order-They call everything a "Genie". They call their HR54 a "Genie HD DVR". The C41W wireless clients are called "Wireless Genie Minis". The C61K is called a "DIRECT 4K Genie Mini".
StevenC56 is offline
post #16922 of 16937 Old 05-06-2016, 08:06 AM
Quoted: 679 Post(s)
Liked: 286
Genie vs Genie Mini
my explanation was the difference
here is how it would work in a single tv setup
for hd a genie would be connected to the tv, easy peasy
for 4k a genie is connected, then a mini genie is connected.
the genie feeds the mini genie which in turn feed the tv
btw, you pay a fee for the mini and for the genie
as i said there is no 4k genie
TV- Samsung 55" UHD (UN55JU6500FXZA)
service - directv
Receiver - Denon AVR-X2100W,
Speakers -F L/R - Infinity Primus P363, C - Infinity Primus PC351
Sub - Klipsch Sub-12HG
(slow build out)
mdram is offline
post #16923 of 16937 Old 05-06-2016, 08:09 AM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
Genie vs Genie Mini
Well I'm confused.
post #16924 of 16937 Old 05-06-2016, 08:10 AM
Quoted: 679 Post(s)
Liked: 286
Well I'm confused.
whats the confusion i will try and clear it up
service - directv
(slow build out)
mdram is offline
post #16925 of 16937 Old 05-06-2016, 08:25 AM
Quoted: 679 Post(s)
Liked: 286
There are 4 types of receivers
1. Receiver - just a signal, has a single tunet (H-25, H-25, ect)
2. DVR - outputs a signal has at 2 tuners (HR-24, HR-21, ect are 2 tuner models)
3. Genie - a special DVR with 5 tuners (HR-34,HR-44, HR-54) also used to feed mini genies
4. mini - client box, no tuners. it must have a genie in order to work. (directv actually calls this a mini genie, but i will just use mini)
each Genie can have up to 8 minis attached to it, but can only feed 3 at a time.
when a mini connects to a genie it uses a tuner, reducing the count of tuners available
to record.
for 4k
an hr-44 can feed on demand 4k to a 4k mini(c61k)
an hr-54 can feed on demand and live 4k to a 4k mini(c61k)
eventually a reverse band lnb will be needed for 4k (when is unknown at this time)
neither and hr-44 or hr-54 can output 4k via hdmi
the only unit that can is the c61k and it must have an hr-44 or hr-54 to feed it the signal
service - directv
(slow build out)
mdram is offline
post #16926 of 16937 Old 05-06-2016, 10:55 AM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
Ok. I think I understand now. Looks like my confusion was due to most all the hardware bring classified as a "Genie".
post #16927 of 16937 Old 05-06-2016, 11:32 AM
jmacari's Avatar
Quoted: 144 Post(s)
Liked: 161
to record.
for 4k
Finally, a ray of light....I now understand this madness; thanks for that post.
I just had a DIRECTV service guy over for another issue (lost playlist/SWM failure on a a newly replaced DVR); in passing conversations, the technician was adamant that i needed an HR-54 (I have an hr-44) for 4K, a reverse LNB (which he showed me), a c61k client....I said i didn't think i needed all that with my Sony XBR 930D...
Anyways, I indicated that I was fine with my present system, and when more content was available, i would think about the 4k upgrade...
he finished the conversation by saying he agreed, and to wait for the next generation of equipment...
Anthem MRX-720,Outlaw 7500 5ch amp
Oppo BDP-103, Sony XBR-65X930D, Rotel RP-855, Phillips BDP-7501
Paradigm Studio 100 Fronts,Paradigm Studio ADP-590 Surrounds,Martin Logan Motion 2 surrounds
Paradigm Studio cc-590 Center, Martin Logan Dynamo subwoofer, DefTech Supercube 4000
Roku Ultra, DIRECTV Genie DVR, OPPO Sonica DAC
jmacari is offline
post #16928 of 16937 Old 05-06-2016, 11:38 AM
CCsoftball7's Avatar
Quoted: 1341 Post(s)
Liked: 1045
To do linear 4K you WILL need an HR-54. You can substitute an RVU for the C61K as it performs the same functionality. Eventually, you will also need a Reverse Band LNB for 4K. However at this point, you don't need it. I would speculate broadcast 4K will become much more widely available by the end of the year.
Sony XBR75X940C Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #16929 of 16937 Old 05-06-2016, 12:49 PM
jmacari's Avatar
Quoted: 144 Post(s)
Liked: 161
That I knew by what I read in this thread (RE: VOD=hr-44)
The DIRECTV technician also told me that, once he knew the 930D is RVU set
CCsoftball7 likes this.
jmacari is offline
post #16930 of 16937 Old 05-06-2016, 01:06 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
My understanding is when you do any kind of hardware change/update they will start your 24 month contract all over again. That's why I'm trying to get all the right equipment (HR54,C61K, reverse band LNB) that's currently available upfront to avoid that. I'm hoping they'll pull off some 4K Olympics programming, but we'll see.
post #16931 of 16937 Old 05-06-2016, 01:08 PM
Liked: 1045
I updated all my equipment with no contract extension. But, I've been a customer for a long time with the highest package, MLB Extra Innings, and NFL Sunday Ticket.
RDalton and ramcharger1979 like this.
post #16932 of 16937 Old 05-06-2016, 03:23 PM
Quoted: 679 Post(s)
Liked: 286
i started a new thread after talking to @markrubin
Directv II HD/4k
markrubin, DrDon, Keenan and 1 others like this.
service - directv
(slow build out)
mdram is offline
post #16933 of 16937 Old 05-06-2016, 03:45 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
That's good to hear that they now value long time subscribers. I left Directv 7.5 years ago for Uverse because after 12 years of service (started Directv service in 1996-Installed my own dish and cables they were so new) they wouldn't do squat for me to upgrade my equipment to HD. They were offering great deals for new subscribers, but wanted me to pay full price for all the hardware to upgrade.
CCsoftball7 and RDalton like this.
post #16934 of 16937 Old 05-06-2016, 03:46 PM
Quoted: 679 Post(s)
Liked: 286
it varies as to what people are offered.
CSR roulette is the game of the day.
if you dont get something call back and try again
RDalton likes this.
service - directv
(slow build out)
mdram is offline
post #16935 of 16937 Old 05-06-2016, 04:01 PM
StevenC56's Avatar
Quoted: 220 Post(s)
Liked: 80
Believe me, I tried at least 10 times. But that was 7.5 years ago. And moving to Uverse put $400 in my pocket with no contract at all. (They were new at the time and making great deals)
post #16936 of 16937 Old 05-06-2016, 04:05 PM
Quoted: 679 Post(s)
Liked: 286
aaahh, yeah, atm i have 2 choices, dish or directv
used to have dish, may again someday
service - directv
(slow build out)
mdram is offline
post #16937 of 16937 Old 05-07-2016, 03:11 AM
Super Moderator
markrubin's Avatar
Quoted: 1297 Post(s)
Liked: 2787
Directv II HD/4k
please use the new thread: which will be updated with new FAQ etc soon
El_Scorcho likes this.
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess this is a red flag issue
HDCP = Hollywood's Draconian Copy Protection system
Test Reports HDMI Cables that support 18GBPS&HDMI 2.0b
markrubin is offline
Closed Thread HDTV Programming
