Which national HD channels distort 4:3 content and which ones don't? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 310 Old 04-03-2008, 11:46 PM
Keenan's Avatar
Quoted: 2205 Post(s)
Liked: 1985
Originally Posted by HiDef Bob View Post
I just noticed this a short while ago on some CBS evening programming. It sort of looks like widescreen, but you can tell it is not by the narrow bands on either side. I agree that it is only going to confuse those new to HDTV. Dumb idea!
Must be something your provider is doing, I've never seen any CBS content stretched or widened like you say.
Keenan is offline
post #182 of 310 Old 04-04-2008, 12:30 AM
HiDef Bob's Avatar
It is coming from CBS Detroit via Star Choice. The program prior to CSI was stretched and zoomed.
Bob
If it is not HDTV it is not worth watching!
HiDef Bob is offline
post #183 of 310 Old 04-04-2008, 12:42 AM
Keenan's Avatar
Liked: 1985
"Survivor"? Don't watch it, but I thought it was shown 4x3 pilarboxed, pretty sure it is here in SF, KPIX(CBS O&O).
Keenan is offline
post #184 of 310 Old 04-04-2008, 12:47 AM
HiDef Bob's Avatar
I will check Bell ExpressVu tomorrow evening ... they pick up CBS Boston.
Bob
post #185 of 310 Old 04-04-2008, 01:20 AM
nickdawg's Avatar
If the odd looking show was "Survivor", then that is a local issue. Many local affiliates stretch 4:3 programming, even network. Luckily Cleveland TV no longer stretches anything. Our CBS(WOIO) sends through the network digital feed in 4:3.
The skinny sidebars sound like an awful local practice. At one time, we had a station that did some local programming in a 14:9 stretch.
nickdawg is offline
post #186 of 310 Old 04-04-2008, 02:30 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
That is done by some CBS affiliates. WWJ in Detroit does this. CBS network programming uses regular 4:3.
Jeremy W is offline
post #187 of 310 Old 04-04-2008, 05:55 AM
Keenan's Avatar
Liked: 1985
So it's local content then, luckily, none of the SF stations do that, it's 16x9 or 4x3 native pillarboxed for all programming.
Keenan is offline
post #188 of 310 Old 04-04-2008, 06:32 AM
pierceive's Avatar
WLAJ (Lansing ABC affiliate) also stretches to 14:9.
pierceive is offline
post #189 of 310 Old 04-04-2008, 07:44 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
Just to make it clear, WWJ actually zooms to 14:9. The top and bottom are cut off, the picture is not deformed at all.
Jeremy W is offline
post #190 of 310 Old 04-04-2008, 08:08 AM
Keenan's Avatar
Liked: 1985
KABC Los Angeles used to do that, haven't looked recently to see if they still do it or not.
Keenan is offline
post #191 of 310 Old 04-04-2008, 08:27 AM
pierceive's Avatar
WLAJ definitely stretches (at least when I flip past it and the nightly news or Kimmel Live is on).
post #192 of 310 Old 04-04-2008, 11:13 AM
Marcus Carr's Avatar
Quoted: 54 Post(s)
Liked: 99
WBAL stopped stretching/zooming this year, and amazingly enough the world didn't end.
YOU ARE READING AVS FORUM
Marcus Carr is offline
post #193 of 310 Old 04-04-2008, 01:44 PM
nickdawg's Avatar
I'm surprised that many still do it. The last hold out in Cleveland was WKYC(NBC), who stopped in December of '06. I believe they used the non-linear stretch b/c they had the awful "funhouse mirror" effect.
nickdawg is offline
post #194 of 310 Old 04-04-2008, 02:22 PM - Thread Starter
mx6bfast's Avatar
I'm confused as to why someone would want to use the non-linear stretch. Stretching is bad but then adding that extra dimension is just retarded.
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #195 of 310 Old 04-04-2008, 04:35 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
Still? WWJ just started doing it last month! They had been OAR since the beginning.
Jeremy W is offline
post #196 of 310 Old 04-04-2008, 07:14 PM
wmcbrine's Avatar
The idea is that the center of the image is relatively less distorted than it would be in a linear stretch, and the most important action tends to take place in the center (a questionable assumption).
57 channels and nothing on
wmcbrine is offline
post #197 of 310 Old 04-04-2008, 07:23 PM
davehancock's Avatar
Quoted: 111 Post(s)
Liked: 60
My (one person's)order of preference:
  • OAR (4:3)
  • Zoom (ala Discovery Networks) (barely acceptable)
  • Non-Linear Stretch (Not Acceptable)
  • Linear Stretch (ABSOLUTELY Not Acceptable)
Dave Hancock
davehancock is offline
post #198 of 310 Old 04-04-2008, 08:19 PM
coyoteaz's Avatar
I strongly prefer linear stretching to zoom or non-linear stretch, but my TV has a 4:3 mode for HD and will unstretch it cleanly. No such luck for non-linear stretches, and there's no way to recover the parts of the picture that get cropped with a 14:9 zoom like Discovery does.
coyoteaz is offline
post #199 of 310 Old 04-04-2008, 08:23 PM
Quoted: 111 Post(s)
Liked: 60
But what would your preference be if your TV didn't have that 4:3 mode for HD? Most sets don't.
Dave Hancock
post #200 of 310 Old 04-04-2008, 08:27 PM
coyoteaz's Avatar
I'll watch the SD digital simulcast. SD channels look no worse than stretched/cropped/otherwise molested upconverts thanks to the low bitrate feeds on most channels combined with Cox's new 3:1 HD channel compression.
coyoteaz is offline
post #201 of 310 Old 04-04-2008, 11:50 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
Originally Posted by davehancock View Post
Zoom (ala A&E) (barely acceptable)
A&E does linear stretching. As far as national channels go, only Discovery Networks does zoom.
Jeremy W is offline
post #202 of 310 Old 04-05-2008, 09:11 AM
Quoted: 111 Post(s)
Liked: 60
Jeremy, You're correct. Thanks for catching that. I've amended my OP.
Dave Hancock
post #203 of 310 Old 04-05-2008, 09:23 AM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
My CBS affliate does a very slight zoom on local SD content (not the network stuff) - maybe 13x9 at the most. There are still pillar bars, but they're slightly smaller. I think they do it to prevent VITC and hide edge damage from older analog video on flat panels with little or no overscan. It's not enough to cut off the bugs, but it shaves maybe 1/4 to 1/3 off the pillars on each side.
I'll forgive them since it actually puts the bugs and fonts closer to the edge of my screen and their HD and SD on the digital channel looks better than any other affiliate.
NetworkTV is offline
post #204 of 310 Old 04-05-2008, 05:19 PM
A_Dude's Avatar
Please differentiate in the original post between stretching and zooming/cropping. Stretching is significantly worse (as pointed out in the posts just above mine).
A_Dude is offline
post #205 of 310 Old 04-10-2008, 11:05 PM
nickdawg's Avatar
Why is "Gangland" in stretchovision AND letterbox on History "HD"? It is listed in the guide as HDTV yet it is still stretched. A&E/History have been pretty honest in what they call HD(compared to Turner/TNT/TBS) but this is just stupid. Back to History SD
nickdawg is offline
post #206 of 310 Old 04-11-2008, 01:43 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
History HD seems to love doing that.
Jeremy W is offline
post #207 of 310 Old 04-14-2008, 08:48 AM
mbyers24's Avatar
History HD would be my #1 favorite channel in a heartbeat. Yet their stretch-game where you never know if the new episodes you record are OAR or stretched makes the channel barely watchable. Painful really. I literally instantly delete half the new episodes of shows that I record to my DVR because they are streteched 16:9...
For a channel seemingly directed towards intellectuals, they certainly have some assclowns running things behind the scenes. TBS level assclowns. We're too smart for this...
mbyers24 is offline
post #208 of 310 Old 04-14-2008, 09:16 AM
aindik's Avatar
The History Channel was Tony Soprano's favorite channel.
Just sayin'.
aindik is offline
post #209 of 310 Old 04-14-2008, 09:25 AM
NetworkTV's Avatar
Quoted: 776 Post(s)
Liked: 1234
Just sayin'.
So, you're saying it's "whack"?
post #210 of 310 Old 04-14-2008, 09:36 AM
nickdawg's Avatar
I think Tony would be for whacking those assclowns. He's got that big HDTV and he's pissed about the stretching. Or maybe he could cut off the stretcher's finger (send 'em a message)
nickdawg is offline
Reply HDTV Programming
