"The Newshour With Jim Lehrer" to go HD on 12/17/07 on PBS-HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 60 Old 12-12-2007, 07:20 AM - Thread Starter
CycloneGT's Avatar
Quoted: 72 Post(s)
Liked: 51
I saw this on http://www.dcrtv.com today.
Lehrer To Go HD - 12/12 - "The Newshour With Jim Lehrer" will go high-def on Monday, 12/17. "The new format will deliver superb video resolution and higher-quality audio, and will result in a richer experience for the increasing number of viewers who watch the program on an HD television set," according to PBS. The public TV news program is produced by Channel 26/ WETA, at its facilities in Shirlington.....
So it looks like we have another news source in HDTV and something new from PBS-HD.
Update: Googling around I see that this news broke on 12/11, but the forum didn't put up a "thread already exists" msg, so I'm gambling that this wasn't already posted. Aside from the Freda thread...
CycloneGT is offline
post #2 of 60 Old 12-12-2007, 08:21 AM
archiguy's Avatar
Quoted: 3868 Post(s)
Liked: 3959
I believe you're looking for this existing thread. It can usually be found on one of the first 2 or 3 pages of the Programming Forum.
archiguy is offline
post #3 of 60 Old 12-12-2007, 08:25 AM - Thread Starter
CycloneGT's Avatar
Quoted: 72 Post(s)
Liked: 51
No, I've seen that one before, but it doesn't have anything about Newshour.
post #4 of 60 Old 12-12-2007, 01:16 PM
jtbell's Avatar
See post #215 in that thread, posted yesterday around 6 pm.
It's also been mentioned in fredfa's "Hot Off the Press" thread in the sticky section at the top of the forum.
jtbell is offline
post #5 of 60 Old 12-12-2007, 01:21 PM
Ken H's Avatar
It's also in the HDTV Programming Synopsis, but it's fine to have a topic of it's own.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #6 of 60 Old 12-14-2007, 03:51 PM
paule123's Avatar
Quoted: 12 Post(s)
Tonight (Friday 12/14) - The final segment of the Newshour is doing a behind the scenes look at the show's transition to HD and a general disussion about the digital TV transition. Check it out.
paule123 is offline
post #7 of 60 Old 12-16-2007, 08:51 PM
BobColby's Avatar
The following info is crossposted from the "Sightings of Truly New HD Programs on PBS?" thread, as a heads-up to those of us who are waiting impatiently for dinnertime tomorrow.
Since news broke on the 11th of this event happening Monday, I've been curious as to why my local station (WGBH) that runs the "PBS HD Channel" had not yet changed its schedule to include the NewsHour broadcast. So I did a little digging, and came up with this article that seems to say (in the comments section, so scroll down) that the NewsHour feeds will be part of a new DT3A feed instead of the usual DT2A (PBS HD) feed. The following quote seems to indicate that local stations will be able to decide between the DT3A and DT2A feeds:
The launch of DT3A will not have an immediate impact on the DT2A schedule - the PBS HD Channel. However, with the addition of NEWSHOUR feeds and other material on DT3A, it will become important for your station to take into account what feeds are on both DT3A and DT2A to determine your local HD service.
That comment (by Keith York) was written back in October, so local stations should have known about this for some time, and adjusted their schedules accordingly.
So since it was now the weekend, I did a bit more digging and checked the schedules of FIFTY Public Television stations. This represents 49 states and the District of Columbia (Delaware seems not to have a PBS station, at least not one in the PBS website schedule database, and I have Arlington, VA's WETA standing in for DC).
Of those 50 stations, 34 run the national (DT2A) "PBS HD Channel" feed (or some rearranged version of it). Of those 34, a total of FIVE have the NewsHour in their HD channel schedules for next week (including, as you'd expect, show producer WETA).
As I said in the other thread (and the blog reference by my sig), I'm hoping that what I've reported here is just one large scheduling bug (the schedulers are presumably used to just putting up the DT2A feed as-is) and that the engineers at the various stations are planning to cut in with the other feed, but I fear otherwise. If so, this means that 45 stations (90% of my sample) will be running the NewsHour only on their digital simulcasts, which may not be available to cable viewers (WGBH-DT - our local simulcast in Boston - is not). From what I've gathered, some but certainly not all simulcasts pass on a true HD signal, many others pass only a straight upconvert of the analog signal (again, that's the case with WGBH-DT).
So, if the schedules are right, I am out of luck when it comes to seeing the NewsHour in HD tomorrow, and many of you may be as well. I would be very interested in hearing what your local schedule says, and whether it turns out to have been right.
BobColby is offline
post #8 of 60 Old 12-17-2007, 06:48 AM
paule123's Avatar
Quoted: 12 Post(s)
Our local PBS station WEAO out of the Akron, OH area has The Newshour (with HD indicator) appearing in my D* guide for the OTA channel 49-2. Their channel 49-1 runs the PBS national feed and will have some other HD programming running at the same time as the Newshour. So it would seem WEAO has it right.
http://www.pbs4549.org/schedule.htm?...3,16085,16087&
paule123 is offline
post #9 of 60 Old 12-17-2007, 07:05 AM
lSunNYl's Avatar
my PBS HD doesn't have it listed ??? (TWC) Schenectady NY .. channel 1811
lSunNYl is offline
post #10 of 60 Old 12-17-2007, 07:55 AM
afiggatt's Avatar
What I find interesting about the PBS Newshour going HD is that PBS is beating the ABC and CBS nightly news programs in going HD. Of course, the Newshour program features a lot of in-studio interviews and discussions, so it does not quite have the amount of same day field reports as the commercial broadcast nets have. Still Jim Lehrer can now go to up Charlie Gibson and Katie Couric and say, nah-nah, I'm in HD and you aren't! Not that I would expect Jim Lehrer to do that sort of thing.
Should not be surprising that a lot of PBS stations won't be ready to carry the show in HD. This is the sort of thing where they will have to upgrade or change their programming schedule for their HD channel. PBS is not centrally organized as are the broadcast nets. May take a few months for the HD version to become widespread.
afiggatt is offline
post #11 of 60 Old 12-17-2007, 09:19 AM
Hormoz's Avatar
Well, you're not the only one. Our local (Portland, OR) broadcaster does not have it either. What is even worse, after calling them it was very clear to me they had no clue about it!
Hormoz is offline
post #12 of 60 Old 12-17-2007, 09:37 AM
Ken H's Avatar
From WTVS-DT PBS Detroit:
They are ready to go with NewsHour in HD tonight.
"PBS will be simulcasting NewHour in SD in letterbox so we expect some complaints from those watching the SD/analog version. This is a good way to steer people to HD. PBS will be doing more of this over the next year or so."
This news also means Canadian HD viewers with ExpressVu, Star Choice, and various cableco's will have HD access.
Ken H is offline
post #13 of 60 Old 12-17-2007, 12:24 PM
Joe3's Avatar
The PBS Newshour going HD had help from a federal grant.
ABC & CBS did not.
Joe3 is offline
post #14 of 60 Old 12-17-2007, 12:53 PM
jefbal99's Avatar
The Lansing PBS WKAR, will not have this in HD until February. They sent out all their December and January scheduling info before the announcement.
The engineer is active in our local thread and says Feb is the target.
It's time to give props to WLNS for the HD crawl generator!!!
Now we need WHTV to go HD and Lansing's CW to get a separate transmitter so it isn't a digital sub.
jefbal99 is offline
post #15 of 60 Old 12-17-2007, 01:11 PM
MeowMeow's Avatar
Here's what WPSU in central PA said to my email:
When the NewsHour HD feed is integrated into the PBS HD schedule, we will begin carrying it -- perhaps sooner. Right now, we are not configured to take this separate feed and switch it into our 15.1 signal. We lack, but are in the process of obtaining, the necessary equipment.
Hmmm. OK.
MeowMeow is offline
post #16 of 60 Old 12-17-2007, 01:24 PM
Mark Vidonic's Avatar
Hmmm. OK.
They are a different situation.
They have multiple towers, not just one and I forget why, but it does make a difference.
Mark Vidonic
mark.vidonic@gmail.com
Mark Vidonic is offline
post #17 of 60 Old 12-17-2007, 03:10 PM
Marcus Carr's Avatar
Quoted: 67 Post(s)
Liked: 118
Looks great - as long as nothing is moving too much.
Some HD field reports.
YOU ARE READING AVS FORUM
Marcus Carr is offline
post #18 of 60 Old 12-17-2007, 03:11 PM
jefbal99's Avatar
Screen shots?
jefbal99 is offline
post #19 of 60 Old 12-17-2007, 03:54 PM
Mike4HDTV's Avatar
Quoted: 36 Post(s)
Liked: 69
Ask and you shall receive:
Mike4HDTV is offline
post #20 of 60 Old 12-17-2007, 03:56 PM
Mike4HDTV's Avatar
Quoted: 36 Post(s)
Liked: 69
post #21 of 60 Old 12-17-2007, 03:57 PM
Mike4HDTV's Avatar
Quoted: 36 Post(s)
Liked: 69
post #22 of 60 Old 12-17-2007, 03:59 PM
MeowMeow's Avatar
Looks sweet.
MeowMeow is offline
post #23 of 60 Old 12-17-2007, 04:13 PM
AAF
AAF's Avatar
No go in Houston, KUHT, but that's no surprise.
When seconds count, the police are only minutes away.
AAF is offline
post #24 of 60 Old 12-17-2007, 04:48 PM
carltonrice's Avatar
Quoted: 39 Post(s)
HD on Maryland Public Television.
carltonrice is offline
post #25 of 60 Old 12-17-2007, 04:52 PM
ReplayJanitor's Avatar
from the screenshots posted, it looks like Newshour is protected for a 4:3 crop. Besides, there will be a lot of pillarboxed stuff on it for years to come. It makes no sense to show the SD version letterboxed, then.
ReplayJanitor is offline
post #26 of 60 Old 12-17-2007, 04:55 PM
Jeremy W's Avatar
Quoted: 14 Post(s)
They specifically said that they're trying to steer people to HD, and that they expect complaints. They did it on purpose. It's nice to see such a refreshing attitude, instead of the trash we get fed from companies like Turner and A&E Networks.
Jeremy W is offline
post #27 of 60 Old 12-17-2007, 05:35 PM
coyoteaz's Avatar
HD on KAET in Phoenix.
coyoteaz is offline
post #28 of 60 Old 12-17-2007, 05:55 PM
kb7oeb's Avatar
There were audio dropouts in one segment, don't know if it was local or not. The new set looks nice
kb7oeb is offline
post #29 of 60 Old 12-17-2007, 06:30 PM
chitchatjf's Avatar
Quoted: 57 Post(s)
Liked: 33
Since news broke on the 11th of this event happening Monday, I've been curious as to why my local station (WGBH) that runs the "PBS HD Channel" had not yet changed its schedule to include the NewsHour broadcast. So I did a little digging, and came up with ...
I did a check of WGBH-SD ! off air - 4:3 letterbox.
chitchatjf is offline
post #30 of 60 Old 12-17-2007, 07:43 PM
jeff2631's Avatar
KPBS-DT in San Diego is HD 1920x1080
Here are a couple of pics of HD and SD to compare.
jeff2631 is offline
Reply HDTV Programming
