Enough with all the clutter (graphics) on my HD screen! - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #991 of 3333 Old 09-29-2008, 07:21 PM
mx6bfast's Avatar
Originally Posted by videojanitor View Post
On an unrelated note (but related to this thread), I just finished watching "Dexter" on Showtime and was royally PO'd to see that not only was it polluted with a constant "SHO HD" bug, but it had several snipes pimping the next program. On a premium channel, that is beyond outrageous.
If it wasn't for me getting Showtime and Starz free I'd definitely drop them because of the bugs.
Grit N Grind
Glory Glory Man United
Go Cubs Go
mx6bfast is offline
post #992 of 3333 Old 09-30-2008, 01:11 AM
nickdawg's Avatar
Originally Posted by Jeremy W View Post
Fox is the only one that uses the Splicer. MNTV distributes their feed just like the rest of the networks do, with a high bitrate feed that gets re-encoded at the station.
Originally Posted by mrvideo View Post
Jeremy W pretty much answered your query. Except that MyNetTV doesn't exactly distribute their programming like the other networks. ABC, CBS, CW and NBC have separate SD and HD sat feeds. MNTV has two streams on their single transponder, one for HD and one for SD. Since it is a DVB-S mux, they do not provide as many HD bits as do ABC, CBS and The CW, who only stream one HD channel per mux.
Notice I didn't put NBC in that list. While NBC has separate transponders for their HD and SD feeds, they do not do one HD stream per transponder. On their 8PSK MPEG-2 DVB-S Ku mux, they have 2 HD streams and the stupid weather channel SD stream. They use two muxes. One does East/Central and the other does Mtn/Pacific (IIRC). On their new C-Band MPEG-4 DVB-S2 mux, they have four HD streams. There may be another HD stream, but I'll have to check on that. While they now have more bits because of the DVB-S2 8PSK mux and MPEG-4, they waste it by packing more HD streams into the mux, so they STILL don't meet the 2:1 re-encoding threshold, in some cases. They have a separate SD C-Band mux that also uses MPEG-4, but again, it too is crammed with streams (Telemundo and NBC).
If a MNTV affiliate added a SD sub-channel, then it is quite possible that the PQ could be affected. But, 720p can take more abuse than 1080i. Of course, that depends if MNTV is 720p or 1080i. I really do not know, since we don't have MNTV in HD in my town and the network feed is encrypted.
Do you actually watch MNTV? You must be the only one in the country that does.
Thanks for the info guys!! This came up in the discussion on a local HDTV thread about a weather subchannel currently on the CBS side of a CBS/MNTV(WOIO/WUAB), both owned by Raycom. The PQ on CBS sucks because of this subchannel and the debate was over whether or not PQ would change on WUAB the MNTV station. It was thought that MNTV operated like FOX, where the bandwidth is reduced whether or not a subchannel is used.
So MNTV doesn't have the same "ghost subchannel" as FOX does? The PQ is dependent on the affiliate, since they re-encode it?
nickdawg is offline
post #993 of 3333 Old 09-30-2008, 01:15 AM
Jeremy W's Avatar
Quoted: 14 Post(s)
Exactly.
Jeremy W is offline
post #994 of 3333 Old 10-03-2008, 10:24 AM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
Since this show is the only CBS program I watch, I can expect to have some samples of the horrible snipes that CBS is using and place them on the website.
What is doubly annoying is that the DVD releases of this show are currently only on DVD, no Blu-ray, which is stupid.
I like Big Bang Theory but the time slot conflicts with other stuff to capture, so I haven't seen it in a while and it too is only on DVD.
Horrible snipes and DVD only. Yep, CBS/Paramount's so-called management have their heads up their collective butts.
"You're Sherlock Holmes, wear the damn hat!" - Watson to Sherlock
Sherlock - The Abominable Bride - 1/01/16
Mr. Video
My Geek Images
mrvideo is offline
post #995 of 3333 Old 10-03-2008, 12:38 PM
nickdawg's Avatar
Give CBS hell tonight!!! They deserve every insult and even that's not enough. I did find the latest NBC post a bit harsh though. I WISH CBS had snipes like NBC. CBS should be ashamed. Those snipes are the black eye on the Tiffany network.
nickdawg is offline
post #996 of 3333 Old 10-03-2008, 01:09 PM
videojanitor's Avatar
I know this is somewhat off-topic, but I have to agree with you on that one. Nothing is more annoying than when a TV show that was produced in HD is released on DVD, but not Blu-ray. If it's not HD, my money is staying in my wallet.
videojanitor is offline
post #997 of 3333 Old 10-03-2008, 01:11 PM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
That is my plan, if they indeed still have those A-hole snipes.
As for NBC, it is because they are still doing snipes and they mask out a portion of the program at the bottom of the screen. In the previous screen shots, they pretty much have the same large snipes, but they do not mask out the screen. I suspect that it was added because the snipes might have been hard to see, depending on the snipe and the background at the point the snipe was placed on the screen. Boo-Hoo!
The better idea, instead of masking out the screen, in order to create the contrast so that the snipe can really be annoying, is to not place the snipes on the screen at all. But, you already know how I feel about snipes
I'm actually surprised that ABC still hasn't placed snipes on their screens. They get tons of Brownie points for resisting joining the rest of the sheep jumping of the cliff to their deaths.
Mr. Video
My Geek Images
mrvideo is offline
post #998 of 3333 Old 10-03-2008, 01:19 PM
mproper's Avatar
If I have to deal with snipes (which I hate), I don't mind NBC using a consistent snipe (i.e. they're all pretty much the same). I find it more annoying when one snipe comes in from the left, then another from the right, and another flies in from the bottom, then someone walks out and pauses the show you're watching, etc...
Of course, no snipe is a good snipe, but if it's an evil we must live with, I prefer NBC's style. Plus, it almost "letterboxes" the screen, which I find easier to ignore.
It also appears that since the olympics, they haven't used the "Coming Next" or "New episode in two days" type bug...unless I haven't been watching the right/wrong shows.
mproper is offline
post #999 of 3333 Old 10-03-2008, 01:49 PM
nickdawg's Avatar
It's coming. I'd say as we get closer to February. ABC seems to be holding out until the last minute, when the SD feed goes away. Just like their stupid bug. The only thing that bothers me about ABC is the bug. Either make it true 4:3 safe or move it over where it was. It's current location is unnatural and screws with my eyes. I actually didn't mind the 4:3 bug during the Emmys. It was in the correct 4:3 location during that broadcast.
nickdawg is offline
post #1000 of 3333 Old 10-03-2008, 02:34 PM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
I'm going to query someone to see if he has heard anything about ABC snipes.
Mr. Video
My Geek Images
mrvideo is offline
post #1001 of 3333 Old 10-03-2008, 02:34 PM
65T500's Avatar
I can't go thru 1000 posts so does anyone have the email address or phone number for the clowns at foxnews? I just tried to watch FoxNewsHD and I lasted 5 minutes. All that crap on the right side of the screen just got me angry. Who can watch like that?
65T500 is offline
post #1002 of 3333 Old 10-03-2008, 03:23 PM
Amnesia's Avatar
I don't know about clowns, but FoxNews.com has a "Contact Us" link at the bottom of their home page.
Amnesia is offline
post #1003 of 3333 Old 10-03-2008, 07:05 PM
65T500's Avatar
Those are useless. I want the email address or # of an executive so I can annoy them EVERY DAY.
65T500 is offline
post #1004 of 3333 Old 10-03-2008, 07:49 PM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
Done! The new images are up. The Swirl snipes are the same, but they added a real annoying Ex-List animated snipe.
Damn, I wished those idiots would sue me so that we could really make them look like ***** in court and on their own news programs (if they were willing to cover it).
Mr. Video
My Geek Images
mrvideo is offline
post #1005 of 3333 Old 10-03-2008, 07:50 PM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
Yep. No Blu-ray HD release, no spend $$$.
Mr. Video
My Geek Images
mrvideo is offline
post #1006 of 3333 Old 10-03-2008, 08:10 PM
nickdawg's Avatar
At 9:00 I immediately flipped the channel as soon as the (S)ex List came on. I never planned on watching it anyway, but once that tramp's picture came on screen not once but twice during GW at 8, my decision was made. Here's to watching the (S)ex List crash and burn, like any other CBS Friday 9pm new show.
Why the HELL did CBS cancel Moonlight for this crap!!!
nickdawg is offline
post #1007 of 3333 Old 10-03-2008, 08:15 PM
nickdawg's Avatar
I love the new post!!! From the Title: "WHAT THE **** IS WRONG WITH CBS?" to the descriptions. One question though, I hate to sound like an ass but who is this "friend who is more tolerant of snipes"? A subliminal reference to one of my comments?
nickdawg is offline
post #1008 of 3333 Old 10-04-2008, 08:34 AM
mproper's Avatar
I really wish you'd get some more sci-fi snipes. Have you not seen the ones for Lost and worse, the one for Destination Truth, which literally takes up over half the screen?
I'd take pictures, but I can't capture them digitally.
mproper is offline
post #1009 of 3333 Old 10-04-2008, 09:33 AM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
Nope, a local friend. We meet up Friday nights for Fish Fry. We were talking about the snipes and when I got around to the CBS snipes, that is when he said that even those annoy him.
Mr. Video
My Geek Images
mrvideo is offline
post #1010 of 3333 Old 10-04-2008, 09:37 AM
mrvideo's Avatar
Quoted: 583 Post(s)
Liked: 325
I don't have access to Sci-Fi Channel anymore. They encrypted
Because of all the damn snipes, I won't buy a pizza-pan system for only the two HDNet channels. They've lost my money because of all that crap.
I'll gladly accept full resolution PNG direct capture images to place on my site.
Mr. Video
My Geek Images
mrvideo is offline
post #1011 of 3333 Old 10-05-2008, 03:10 PM
Anifan's Avatar
Nobody's mentioned it yet, but last night Saturday Night Live used the old 16:9 bug. I couldn't believe what I was seeing. I checked the analog broadcast and it was letterboxed. But it appears that E* is centre-cutting my locals from HD now as it was 4:3 SD and bugless over satellite. Watching on WSAZ.
Am I really the only one who noticed this little blessing? What are the chances we'll see more comebacks of the 16:9 bug? NBC has been making some progress this season (no ad bugs, intermittent bug on Leno, etc.) hopefully this wasn't just a fluke.
Anifan is offline
post #1012 of 3333 Old 10-05-2008, 05:39 PM
nickdawg's Avatar
I was watching in SDTV last night. Can't comment on the HD feed, as I didn't see it on the HD channel. But the SD channel looked like s**t. The bug was way to high on the screen. NBC's letterbox presentations used to look OK since the bug was close to the bottom of the frame.
I wish WKYC Cleveland and TWC would start center cutting, I want a bug-free SNL too!!!
I think it was a mistake. The first few episodes had different opening credits and the bug was in the correct location. With the transition a few months away, I doubt NBC would move their bug to where 4:3 viewers cannot see it.
I actually liked the presentation of SNL this season, before last night.
nickdawg is offline
post #1013 of 3333 Old 10-06-2008, 09:43 AM
Knicks_Fan's Avatar
Over the weekend, TNT had the first "self-congratulatory" bug during the 8,888th showing of Titantic (a filler movie to cut away to show beginings of some MLB divisional series games when the previous game runs long on TBS... the home of FRANK TV).
MORE MOVIE
LESS COMMERCIALS
Knicks_Fan is offline
post #1014 of 3333 Old 10-06-2008, 02:09 PM
65T500's Avatar
From another thread: http://www.avsforum.com/avs-vb/showt...95922&page=121
As some of you know, I recently wrote NBC and got them on the phone about the new SciFi HD channel, whose SciFi logo was in bright white. It was blazing away at the lower right corner every second the channel was up there. It made it extremely unsafe to view Battlestar Galactica, esp. since BSG is shot so darkly as it is.
NBC got it. Before the next week's episode, that logo - screen ticker, station emblem, whatever - had been turned down to half intensity, which is the ONLY way a fixed image will not cause uneven phosphor aging, otherwise known as screenburn.
I then turned my attention to Dish Network. If anybody out there uses Dish, you know that whenever you put up the Guide to see what's on, the stylized "Dish" logo appears in the upper left corner, in the brightest white possible.
On my recent trip to MN and Chicago, I witnessed some of the worst screenburn I have ever seen on one of my owner's sets, and that "Dish" logo up in that corner was at its heart. There were other parts of his CRT faces that were screenburned as well, but whenever the screen went to a fade to white, that "Dish" logo was the worst part of the screen. It was awful. I pointed it out to him, and immediately realized that I have been subjecting my new 73" Mit to the same treatment! Not nearly as much as was evidenced there, but I was using that Guide all the time, with no thought as to the consequences!
As soon as I got home I looked for the damage like I had seen there, and to my relief, none has occurred yet. But I now lower my contrast to 0 and my brightness to half of normal, EVERY time I go into that Guide mode, or the DVR mode, or any other mode in those graphics they are using, that are fixed images.
Dish is running their fully fixed image graphics at full tilt boogie on their light level at all times, most in bright white and others with different colors as well, also at full tilt boogie. Different colors at full tilt while fixed can also ruin CRTs - not just the one color involved, but also the 2 colors that have to go silent - black - to allow the one color to show as a color rather than as white. A space on the face of a CRT going full BLACK for extended periods is just as bad as going full tilt WHITE for extended periods. Each scenario will cause UNEVEN PHOSPHOR AGING. The definition of screenburn. Once unevenly aged, those phosphors will show their damage from then on with EVERY fade to white you'll ever see again, on EVERY soccer game you will ever watch again. On EVERY white ice figure skating event and EVERY white snow skiing event you will watch in the upcoming Olympics.
I don't think I will be able to prevail on this crusade alone. I called them more than a month ago, and nothing has been done. I just called again, and the person I talked to said he would get the info to a different set of ears, in an attempt to get something done.
You know what will get something done? YOU GUYS calling them! EVERYONE reading this - if you value your CRT or plasma set and are a Dish subscriber, go to your phone, call them up, ask for Tech Assist and get a supervisor on there, and say you're mad as hell and you're not going to take it anymore!
Well, find your own words, of course...
Bottom line, they probably won't do anything if only ONE person has complained. The NBC guy wasn't listening until I asked what kind of a set he had. Plasma. So I said, "Then you're next." You could hear a pin drop. I got immediate attention after that, including the direct number of someone in their legal dept.
PLEASE. Call them. 800-333-3474. Tell them you have a phosphor based set - plasmas are phosphor based too and HIGHLY susceptible to screenburn - and that they are causing it damage. Refer to me, if you wish, I did start the ball rolling, but please recognize how these things work. They may not listen to just one person. If they start hearing from a new set of people every day, who are taking the names of whom they are talking to on that call - and their Dish badge/operator/ID numbers and extensions if possible, for 100% trackability later - THEN we have a fighting chance to get them to TURN DOWN THEIR GRAPHICS! Before one more set gets damaged beyond repair. Look in your upper left hand corner, with a white screen up there. See if your set's been damaged permanently yet, by that stylized Dish logo.
Thanks, hope you owners care for your CRT sets as much as I do. Once screenburn has happened, forget it. Nobody springs for regunning a CRT set these days. And DEFINITELY nobody pays to have a plasma panel replaced! Such units are totalled, once screenburn has gotten noticeable.
If you value your set, PLEASE hop on the phone right now. They are open 24/7.
Mr Bob
__________________
Robert P. Jones
Image Perfection
SF Bay Area, Ca. USA
510-278-4247
(spambot aversive, please reconsititute) bob at imageperfection dot com, bdclick at hotmail dot com
www.imageperfection.com
65T500 is offline
post #1015 of 3333 Old 10-07-2008, 06:22 AM
8traxrule's Avatar
If you value your set, you won't subscribe to or watch channels that do this in the first place!
8traxrule is offline
post #1016 of 3333 Old 10-09-2008, 12:47 PM
mx6bfast's Avatar
Same here. Saw the huge snipe for CSI Miami this past week and it was about 40% up on the screen.
Because of it I have deleted 2 season passes from CBS, Cold Case and Without A Trace. Now all I have left are CSI's, and getting real close to deleting Miami.
Grit N Grind
Go Cubs Go
mx6bfast is offline
post #1017 of 3333 Old 10-09-2008, 01:37 PM
nickdawg's Avatar
I could never stop watching the Monday sitcoms or CSI:NY or Ghost Whisperer. Although I haven't watched CSI Miami at all this year since Boston Legal is on ABC on Mondays now. Not worth wasting recording space on a show assassinated with snipes, that will be rebroadcast soon enough, once again assassinated with snipes.
nickdawg is offline
post #1018 of 3333 Old 10-10-2008, 04:41 PM
hdtvjunkie247's Avatar
Anyone go past CMT lately? I know that its mostly reality programming like its sister stations MTV & VH1, but there's currently huge static text over the CMT bug promoting Hulk Hogan's Celebrity Wrestling which doesn't debut until 10/18. Completely annoying. I wish that this practice of screen clutter would cease.
hdtvjunkie247 is offline
post #1019 of 3333 Old 10-10-2008, 04:56 PM
dennispap's Avatar
Exactly, i do not watch any show that is promoted that way. I know i am in the minority, but it works for me.
dennispap is offline
post #1020 of 3333 Old 10-11-2008, 04:14 AM
petey1287's Avatar
Its really annoying on MTV especially during new episodes! I watch The Island on MTV and that big crap "MTV premiere" logo was getting on my nerves. Also during The Hills, sometimes they displays subtitles during loud scenes and I cant read parts of the subtitles because that big logo was in the way.
petey1287 is offline
Reply HDTV Programming
