Where can I get a low-pass filter approx. 75MHz? - AVS Forum | Home Theater Discussions And Reviews
Old 08-25-2008, 07:37 PM - Thread Starter
HalloweenWeed's Avatar
Entire explanation:
I am trying to combine standard NTSC antenna signal with new DTV converter box output. The DTV has a separate special antenna, gets only UHF (we are in outer fringe area). We cannot get any NTSC channels below 6. The DTV converter boxes puts out chan. 3 & 4. I am combining the outputs using a coax splitter (in reverse). It works good except it ruins channel 8.
So I am looking for:
A Low-pass COAX filter approx. 75MHz to allow only channels below 5 to come in from the DTV converter box, to filter out channel 8 interference. I don't know where I might find one of these, I tried radio shack & Newark electronics. Theoretically, if I added such filter between the NTSC DTV converter box output & the NTSC antenna combiner (splitter in reverse), it would block said interference of any channel above 4.
George Carlin: "IsnÂt it a bit unnerving that doctors call what they do ÂpracticeÂ?"
HalloweenWeed is offline
Old 08-25-2008, 09:18 PM
crkpot's Avatar
Originally Posted by HalloweenWeed View Post
Entire explanation:
So your saying you combined the signals from the output of your new OTA digital converter box with the signals of your VHF/UHF antenna? The digital converter box only outputs it's signal on channel 3/4 so the only thing you should need to do is put a channel 3 or 4 trap on your old antenna line to keep it clear for the converter box to send signal on that frequency.
Here's a ch3 trap:
http://www.weisd.com/store2/ATVMN-3.html
Here's a ch4 trap:
http://www.weisd.com/store2/ATVMN-4.html
If I had to guess I would say the splitter is what's causing problems on CH8, splitters are not made to combine signals like. Maybe something like this would work better.
http://www.solidsignal.com/prod_disp...om=Large#xview
I'm just trying to help so these are my suggestions, hopefully they're close to a solution. You could always use an A/B switch too.
crkpot is offline
Old 08-25-2008, 09:45 PM - Thread Starter
Problem with switch is we are recording multiple channels with 3 recorders, switch would limit channels to record.
Old 08-25-2008, 10:07 PM - Thread Starter
Here's a ch3 trap:
Here's a ch4 trap:
Forgive me if I'm wrong, but don't traps remove a channel? These would only remove ch3 or ch4 from the feed COAX. I am not having problems with ch2, 3, or 4 in the combined signal; they appear perfect.
About the switch, see my separate post (below) dated 8/26 at 11:45p.m.EDT.
As for the antenna combiner: "Always join identical antennas for the best results." And really, I think this is just a splitter relabled & repackaged and sold for more $. I have proven the backwards splitter works, and good signal pass-thru too, I just need to filter out the ch8 interference (from the DTV converter box).
I suppose I could maybe use a ch8 trap to trap the ch8 interference from the DTV box:
http://www.weisd.com/store2/ATVMN-8.html
Unfortunately, this is sold out and no longer available. Any more ideas, anyone else?
Old 08-26-2008, 01:29 AM
crkpot's Avatar
Ok I think I understand your problem now. Even though the converter box is supposed to output on ch 3 or 4 it is bleeding over to ch 8. I have seen this with digital cable boxes now that I think about it. That ch 8 trap probably would work for your situation, but short of having a custom made low pass filter I don't know what else would work for you in that situation.
crkpot is offline
Old 08-26-2008, 08:33 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Entire explanation:
Perfect application for an SC-3.
The SC-3 is a sophisticated multi-filter channel combiner enabling locally originated channels (3 (cable box)) with spurious outputs to be cleaned up and balanced with off-air signals resulting in a clean adjacent channel home distribution system.
CIAO!
Ed N.
egnlsn is offline
Old 08-26-2008, 11:21 AM - Thread Starter
That would work! But for two converter boxes on RF COAX I will need both the SC-3 & SC-4. I plan to have at least 3 converter boxes, one will have to be connected to my DVR via composite (or S-vid cable if CM-7000) to record that channel on that particular recorder only.
If I had a low-pass filter, only 1 unit would have to be installed (might be cheaper). But this may not be feasible as I cannot yet locate such a unit on a low budget. So unless I hear any better suggestions soon, I will order these (Holland Electronics SC-3 & SC-4). Thank you egnlsn.
Old 08-26-2008, 09:23 PM - Thread Starter
I just got my 2nd DTV converter box, and lo & behold, the two interfere with each other on channel 3 no matter what the settings, even with one set to 4. Tried all combinations & pass-thru too, complicated by I need to leave them on constantly for VCR/DVR automatic recording. So egnlsn's solution is the ideal one, hopefully it will end the cross-interference between the two units also. I even tried pass-thru both ways, NOTE: The Digital Stream 9950 only passes NTSC signal thru when the unit is off (pass-thru useless to me)!
If anyone is interested in the results with the SC-3 & 4, post a message here, and I will let you know how it went after I install them.
FYI: the units are Digital Stream 9950 & LG Zenith DTT-901.
I plan on buying the CM-7000 later for my third and final channel (I can't get any more than 3 useful channels where I live presently, in West-"central" Maine). I will then hook up the CM-7000 via S-vid cable to a dedicated DVR.
Thanks egnlsn and AVS forum.
I think we may be done here this thread.
Old 09-06-2008, 02:57 PM - Thread Starter
Moderator: You may lock this thread as this issue has been resolved, and has not been gathering interest.
