Comcast cable box settings keep resetting - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-20-2008, 04:44 PM - Thread Starter
cdm8808's Avatar
I have my comcast cable box hooked up to my Onkyo S7100 home theater and whenever I turn on the receiver, the settings I have set in the cable box's menu (1080i, 4:3 stretch) are reset to 720p and 4:3 standard. I have to change them back every time I turn the receiver on. Is there any way to fix this?
cdm8808 is offline
post #2 of 3 Old 12-20-2008, 05:04 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Bypass the receiver and run direct to the TV. If problem persists... get the cable box replaced.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 3 Old 12-21-2008, 09:06 PM
bradman's Avatar
Quoted: 69 Post(s)
Liked: 52
All of the cable boxes here(Moto 6412,6416) do it...when connected via HDMI.
Each "handshake" when you change inputs,power on,etc. resets the user menu options to default.
I solved the problem by using component,and digital coax out for sound.
bradman is offline
Reply Cable, Digital Cable - Non-HDTV
