Cable Divider - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 01-10-2010, 11:12 PM - Thread Starter
BasieTech's Avatar
My provider is Time Warner Cable and I have both TV and Internet. They are using a two way splitter and my question is I want to add another TV. What
would be the best option? If I split it three ways would there be a degradation
in signal quality?
BasieTech is offline
post #2 of 8 Old 01-11-2010, 04:39 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
There should be enough incoming signal levels for a three-way split without degradation to picture quality.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #3 of 8 Old 01-11-2010, 04:42 AM
RCbridge's Avatar
Quoted: 16 Post(s)
If you want to know the power levels at present just access the cable modem diagnostic screen and see what the up and downstream powers are at this time.
What type of modem do you have (manufacturer)?
RCbridge is offline
post #4 of 8 Old 01-11-2010, 05:14 PM - Thread Starter
BasieTech's Avatar
Thanks for the help. It's a Arris TM502G. There is no screen. I also use Time Warner Phone service and this
modem connects the telephone as well. I saw a Motorola signal booster for about 35 bucks on Amazon and it got good reviews. Would that be worth a try?
post #5 of 8 Old 01-12-2010, 04:41 AM
RCbridge's Avatar
Quoted: 16 Post(s)
With the modem working.
go to 192.168.100.1 and you will see a diagnostic screen pop up and look for a tab to see the power levels, note the Downstream and Upstream power levels and SNR (signal to noise ratio).
Write them down and post them here.
RCbridge is offline
post #6 of 8 Old 01-12-2010, 10:13 AM - Thread Starter
BasieTech's Avatar
I copied these directly from the Arris Touchstone Status
Downstream
Freq/Power: 699.000 MHz -2 dBmV
Signal to Noise Ratio: 36 dB
Modulation: QAM256
Upstream
Freq/Power: 21.000 MHz 38 dBmV
Channel Type: DOCSIS 1.x (TDMA)
Symbol Rate: 2560 kSym/sec
Modulation: QAM16
post #7 of 8 Old 01-12-2010, 11:04 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Now knowing these numbers any additional splitting will decrease those numbers by 3.5db for each 2 way split.
I would probably leave that 2 way in place and take the other leg and split that again and feed your 2 TV's.
You will be hitting the TV's with about -6dbmv which normally is enough to work without problems if that level drops a few more db you may have issues.
The easiest and cheapest solution is to add another 2 way splitter.
RCbridge is offline
post #8 of 8 Old 01-12-2010, 09:56 PM - Thread Starter
BasieTech's Avatar
Thanks for the advice and help.
Reply Cable, Digital Cable - Non-HDTV
