how to place a satellite dish on a balcony without mounting it - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 03-14-2010, 09:11 AM - Thread Starter
phish368's Avatar
I am moving to an apartment building that does not allow satellite dishes to be mounted or attached to the building. I have a balcony that faces the south but I cannot mount or attach the satellite dish to it either. What are my options to add a dish onto my balcony? Can i cement a pipe into a 5 gallon bucket and attach the dish onto it? Would that be safe? Is there a better option that people use to do this? Oh I live in Orlando Florida.
Post No Bills
phish368 is offline
post #2 of 12 Old 03-14-2010, 09:21 AM
Quoted: 303 Post(s)
Liked: 43
cant u put it on the floor or something?
lamonsasa is offline
post #3 of 12 Old 03-14-2010, 10:37 AM
Ratman's Avatar
Quoted: 1275 Post(s)
Liked: 1024
Can i cement a pipe into a 5 gallon bucket and attach the dish onto it? Would that be safe? .
Yes.
Yes.
Ratman is online now
post #4 of 12 Old 03-14-2010, 11:16 AM
kenglish's Avatar
Liked: 39
The pipe for most DBS dishes is a 1-1/2 inch ID (inner diameter), 1.66" OD (outer diameter) steel pipe, and is the same size as what is commonly used as the top rail of a cyclone fence ("chain link fence"). You can get that at most home improvement stores. Have them cut it to length for you.
You can install that...being sure it is perfectly plumb/vertical...in a bucket of cement, or you can mount it with a small antenna tripod mount (which has two sets of three bolts that allow you to plumb it up after you set the tripod in place). You'll need the pipe plumb for anything beyond a single-satellite dish, or aiming becomes a pain. A safety line is always a good precaution, so it won't blow over, or away (Florida, right ?)
The bigger problem is getting the wires inside the building.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #5 of 12 Old 03-14-2010, 11:51 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Which is easily solved by GooglinG 'flat coax jumper'....
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 12 Old 03-14-2010, 12:35 PM
prospect60's Avatar
A large bucket with cement is often used. You need to know what dish you are mounting as well -- most of DirecTv's high def dishes require a 2inch OD pipe.
You can also get a non penetrating mount if you want something more stable than a bucket. The NPM often are used on flat roofs and are designed to be weighed down with standard concrete blocks.
http://search.solidsignal.com/?q=Non...earch=1&cart=0
prospect60 is offline
post #7 of 12 Old 03-14-2010, 01:19 PM - Thread Starter
phish368's Avatar
That's exactly what I'd like to use... Thanks to everyone!
Maybe the easiest way would be to beg my apartment complex to let me mount it on the balcony,...lol
Post No Bills
phish368 is offline
post #8 of 12 Old 03-15-2010, 08:02 AM
kenglish's Avatar
Liked: 39
I bought a couple of those to test, but never got to it yet. I'm always a bit skeptical about such things.
I made a nice "pass-thru", PVC pipe in my wall. The landlord OK'ed it after I broke the glass in the outside door, trying to wedge another cable thru the crack . It's all watertight, with nice wall plates, and everything.
kenglish is offline
post #9 of 12 Old 03-18-2010, 04:09 AM
pixie4cables's Avatar
My practical take on this is that the flat governing body does not want dishes scattered all over the flat, which creates a bit of an eye-sore. So even a dish that is mounted in something else, but visible when looking at the flat will become an issue for them. Which I imagine just about any dish on a balcony will be visible.
But if you can get away with it, I would go for the cement bucket with a pole in it - with paint markings to indicate the correct position for the signal.
pixie4cables is offline
post #10 of 12 Old 03-21-2010, 09:46 AM
kenglish's Avatar
Liked: 39
Maybe they should consider allowing an MATV system in the buildings. One dish (or set or dishes) and antennas can feed all the units in a building...even in adjacent buildings.
That way, the management has control over where the outside equipment is placed. Of course, they have to provide for whatever channels you want, so it would require (in most cases) OTA, DirecTV and DISH. In some cases, people mght want their own Globecast dish or something similar, but it prevents a lot of hassles in most cases.
I saw an article in a Building Management type magazine a while back....the photo showed ten DISH Network dishes, all facing the same way, lined up down the side of a twelve unit apartment building (same sales guy, same installer). The owner wanted to know how to stop it.
Duh!
kenglish is offline
post #11 of 12 Old 03-26-2010, 03:17 AM
@phish368 What was the outcome, what did you use and how friendly are the building governing body towards you now!?
post #12 of 12 Old 03-27-2010, 08:19 AM
kenglish's Avatar
Liked: 39
I just saw where DISH Network launched it's fifteenth operational satellite.
Sounds like it would take about twenty or more dishes on a "fully pimped-out balcony". Wow!
kenglish is offline
Reply Cable, Digital Cable - Non-HDTV
