Cable Box needed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-16-2010, 10:30 PM - Thread Starter
bigdude01's Avatar
Newbie question here. I just bought an Insginia NS-LDVD19Q-10A for my kitchen. Ran coax into the kitchen, an eletrical outlet and mounted it....Looks great but only picks up 7 channels without a cable box. Do I actually need a cable box or does it have a "cableCARD"? I have comcast and they are telling me I definitely need a box. But putting a box in my kitchen would be unsightly. Thanks
bigdude01 is offline
post #2 of 3 Old 03-16-2010, 11:08 PM
Liked: 62
The TV would need a cableCARD slot to use a card that Comcast would rent to you. I didn't see any slot mentioned when I looked up your TV, so to get more than 7 you're going to have to live with a box of some sort.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 3 Old 03-17-2010, 12:02 AM
Jed1's Avatar
Quoted: 117 Post(s)
Liked: 61
I don't think this tv has a QAM decoder built into it. It only has a 8 VSB decoder for decoding over the air digital signals. So you will definately have to get a HD cable box from comcast and hook it up using a HDMI cable.
"You lose it in here you're in a world of hurt"
Jed1 is online now
Reply Cable, Digital Cable - Non-HDTV
