Cable Signal Flicker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-12-2010, 01:05 AM - Thread Starter
blueleo65's Avatar
Hello,
First time posting.
I recently subscribed to COX cable here in Phoenix and I am having some issues with picture flicker.
My cable box was hooked up using component cable, and I had no issues. I ordered a pair of HDMI cables, one for the cable box and one for the new Denon Blu-Ray player that I recently bought. I was under the impression that HDMI would improve the picture quality.
As soon as I hooked up the HDMI cable, I started seeing the image flicker ever 20 seconds or so on my Plasma Samsung. I hooked up the Blu-Ray player with the same kind of HDMI cable and I have no problems with the Blue-Ray, only the signal coming from the cable box. I tried looking for some form of adjustment in the box, but no such luck. I haven't contacted COX since it's the beginning of the weekend. I'm hoping someone here has had the same issue and what solutions were suggested.
Mike
blueleo65 is offline
post #2 of 4 Old 06-12-2010, 01:44 AM
Roger Dressler's Avatar
Quoted: 1522 Post(s)
Liked: 710
Could try swapping the HDMI cables to see if that makes any difference. It's a long shot, but easy and free.
ARe there any stresses on the HDMI cables? Sometimes they are thick or stiff and get jammed behind the equipment. That can twist them in the sockets and affect the contacts.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #3 of 4 Old 06-12-2010, 02:10 PM
sitlet's Avatar
It's most likely a bad HDMI port on the cable box. Try swapping cables first, and swap inputs on the tv. If that doesnt work, call and get a replacement box. I work for a cable company, and we get tons of bad cable boxes returned every day.
sitlet is offline
post #4 of 4 Old 06-12-2010, 06:28 PM - Thread Starter
blueleo65's Avatar
Thanks for the replies.
I will contact COX on Monday.
Mike
Reply Cable, Digital Cable - Non-HDTV
