Switching at will from OTA antenna signals to cable w/new HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-08-2010, 10:10 AM - Thread Starter
tomstan's Avatar
A splitter doesn't work, a switcher requires one to re-scan every time. LG informs that one needs two tuners to do this for my new LG-LD550 HDTV. "e-How" recommends using an old VCR as tuner. But as the OTA signal is digital and the VCR processes, & outputs, analogue how is that possible? What is the easiest & most cost-effective way to deal with this conundrum? As my OTA signal (for viewing local channels) is superior to Comcast cable's any input would be greatly appreciated. Thomas.
tomstan is offline
post #2 of 8 Old 09-08-2010, 10:49 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1030
1) a TV with two tuners.
2) an external OTA or QAM tuner.
3) live with one or the other (cable vs. OTA).
Correct, a VCR is only analog and is not a preferable solution as all OTA (for the most part) is digital and many cablco's are migrating to 100% digital.
If you only watch "HD" via OTA, then rent an SD digital tuner from your cable provider and use the TV's RF input for OTA.
Ratman is online now
post #3 of 8 Old 09-13-2010, 12:02 PM - Thread Starter
tomstan's Avatar
Thank you. TGS
tomstan is offline
post #4 of 8 Old 09-13-2010, 01:57 PM
sitlet's Avatar
Does you tv support QAM? If so you can get all the channels you would through OTA.
sitlet is offline
post #5 of 8 Old 09-13-2010, 02:21 PM
Ratman's Avatar
Liked: 1030
Built-In TunerATSC/NTSC/Clear QAM (from the LG website).
I think the OP prefers OTA vs. cable "locals".
He'll have to choose.
post #6 of 8 Old 09-13-2010, 04:04 PM
Desert Hawk's Avatar
I have 2 HDTVs connected to both cable and an antenna. A Vizio and a Samsung. Fortunately both of them have two scan lists, one for cable and one for air. I use mechanical A/B switches from Radio Shack. Flip the switch, go into the tv's set-up menu and switch from cable to air or vice versa and it ts ready to go. I am really glad I don;t have to rescan every time I switch. Over the air I can get KCET in HD, KCET Orange, World, Coastal TV Network, and Daystar, which are not carried by Bright House. There are also a few more which I never watch.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #7 of 8 Old 09-14-2010, 02:36 AM
Jedi Master's Avatar
Quoted: 12 Post(s)
Liked: 31
If you only have SD cable and no cable box use the VCR for the cable tuner and hook it up to the TV with composite (RCA) cables. Them use the TV's tuner for your antenna.
Broadcast TV - a vital national public resource
Jedi Master is offline
post #8 of 8 Old 09-26-2010, 06:12 PM - Thread Starter
tomstan's Avatar
Thank you all. Finally was able to do this without resorting to two tuners by using a variation of Desert Hawk's m.o. A bit tricky to achieve with my LG but eventually I did it. T.
tomstan is offline
Reply Cable, Digital Cable - Non-HDTV
