Can I get HD TV through basic Comcast service with QUAM tuner? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-07-2010, 02:58 PM - Thread Starter
inky blacks's Avatar
I may need to get basic cable service in Eugene, Oregon through Comcast because recently, for some unexplained reason, my usually good over-the-air reception has gone to hell.
If I get basic limited cable for about $12 a month, can I tune in all the local free digital channels through my QUAM tuner in my LG HD TV? I have not had cable for about 5 or 6 years, and I use to be able to get local HD programming unscrambled through basic Comcast service. Have they changed the regiment? If all I can get is standard analog signals I will be a very unhappy camper.
inky blacks is offline
post #2 of 10 Old 11-07-2010, 09:03 PM
Desert Hawk's Avatar
The only thing you will get with a "QUAM" tuner is analog AM stereo radio! A "QAM" tuner will receive all the local HD channels!
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #3 of 10 Old 11-07-2010, 09:18 PM - Thread Starter
Sorry, I meant QAM. I hope you are right.
post #4 of 10 Old 11-07-2010, 10:32 PM
Tulpa's Avatar
Liked: 61
AFAIK, they've never changed local HD access through QAM. They may not advertise it, but they're supposed to pass the locals through. Might check the HD reception forum for your area (if there is one). You may also snag Discovery HD and one or two others, but that's totally dependent on your local Comcast office.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 10 Old 11-07-2010, 11:29 PM - Thread Starter
Thanks. That makes me feel better.
If my reception does not improve by December 1st, I will get basic cable. My reception was great of 5 or 6 years, then suddenly it stinks. Must be RF interference from somewhere.
post #6 of 10 Old 11-08-2010, 07:47 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Last month I got a rates and channels card in my bill from ComCast (Olympia, WA) and while it didn't directly state they were there, it said they are available in the most basic line up, with the usual disclaimer 'may require additional equipment' (which they don't here).
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #7 of 10 Old 11-09-2010, 02:33 PM
STEELERSRULE's Avatar
Quoted: 60 Post(s)
Liked: 25
See if you can find your local HDTV Thread located in this forum:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=45
And type in the search box: Eugene, OR Comcast.
I did it already, and here is what I got:
http://www.avsforum.com/avs-vb/searc...rchid=16211705
There may be a thread for it, and people with the same exact service as you will be able to tell you if Comcast in that area sends anything in the "clear" which any TV with a built in QAM tuner can decode. It usually is your local stations(ABC/CBS/NBC/PBS/CW/etc...), and maybe some oddball scatered stations(usually a music channel or two), but usually nothing more.
Good Luck.
STEELERSRULE is offline
post #8 of 10 Old 11-13-2010, 02:37 PM - Thread Starter
Got Comcast and got all the local digital channels through QAM,
post #9 of 10 Old 11-14-2010, 05:32 PM
hmunster2's Avatar
Quoted: 92 Post(s)
Liked: 32
inky, were you using a digital comcast box, or just running the coax directly into the tv?
I want access to my SD programming (extended basic) through my digital (non-HD) box and be able to get the local HD channels. Someone said that I would have to split the incoming cable and runa leg to both the digital box (for SD) and the other to the tv for HD.
Did you have to do this?
hmunster2 is offline
post #10 of 10 Old 11-27-2010, 07:38 PM
AlterEcho's Avatar
At our shop we are using Viewsonic 19-inch HD monitors. We have the coax running straight into the monitor without a box. We are able to get HD as well as SD channels. For example HGTV is on 114-1...this for the Richmond, Va area.
AlterEcho is offline
Reply Cable, Digital Cable - Non-HDTV
