Grex Stabilizer - video is way too hot - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-04-2011, 07:32 PM - Thread Starter
zaax's Avatar
Received my Grex today and hooked it up. The video appears to be way too hot. Did an A/B compare with it inline and bypassed and with the Grex inline it is almost unwatchable as it is way too bright (over modulated). Is this a common problem and if so is there any way to reduce the signal to an acceptable level? I am using it with a Panasonic DMR-EZ-485V DVD recorder.
BTW I purchased it because Comcast is blocking me from recording a number of channels with my DMR-EZ-485V and the AVS cable forum recommended that the Grex was the best solution to being able to record again.
zaax is offline
Reply Cable, Digital Cable - Non-HDTV
