Digital vs. Analog Tuner? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-08-2011, 05:16 PM - Thread Starter
ubiq's Avatar
Hope I'm in the right place for this issue.
My Samsung telly's built in tuner pulls in about 60 channels from my basic cable service. These include OTA's plus several (apparently unencrypted) cable-only channels like FX and TCM. I have no STB, cable connects directly to the TV.
I recently bought an external digital tuner (KWORLD SA290-Q LE) to pipe cable into my slingbox for remote viewing. It appears the tuner pulls in only cable-supplied OTA channels (30 or so); all my other channels are unavailable. I called KWorld but got no sense out of the TS dude. My questions are:
1) How is it that the internal Sammy tuner receives these cable channels and the digital tuner does not?
2) Is there a stand-alone tuner or STB out there that will do what my TV's integrated tuner does? (If only it had output!)
ubiq is offline
post #2 of 5 Old 06-08-2011, 06:39 PM
Tulpa's Avatar
Liked: 61
Who is your cable provider?
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 5 Old 06-09-2011, 12:37 AM
Desert Hawk's Avatar
FX, TCM, and the like are probably being sent unencrypted in analog but encrypted in digital. If the KWORLD is digital only and has no analog tuner then it can't tune the analog channels.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #4 of 5 Old 06-09-2011, 01:09 PM
vickyg2003's Avatar
Tuning in the cable channels with digital equipment seems to be kind of hit or miss. While scanning for OTA signals takes maybe 10 minutes, scanning for Cable takes a good half hour. During that process the tuner tries to eliminate all encrypted signals. Sometimes it can be a bit tricky to determine which of the signals are encrypted and which are not. This can result in missing channels.
Some digital tuners find all the channels, and then go back and eliminates the scrambled channels. Others tuners do this in one pass. The two step tuners like the Samsung find more channels than the one pass tuners, especially if you interupt the removal of the scrambled channels, and then eliminate the channels manually.
Do a factory reset of the tuner, and scan again. Make sure you are set to Cable before you do your scan.
My tuner starts finding cable channels when it reaches channel 68. If I time the scan so that the tuner reaches channel 68 just after the commercials end, I pick up more channels than if I am at the populated channels in the commercial time.
EDIT:
Also Samsung does the cable Analog/Digital all in one pass in one pass. My cable company sends local out in analog and digital for the locals. If you OTA channels are missing, then it could be that your cable company is only doing QAM for some of the channels and the analog channels are not getting passed through.
vickyg2003 is offline
post #5 of 5 Old 06-11-2011, 08:11 AM - Thread Starter
ubiq's Avatar
Thanks, all.
ubiq is offline
Reply Cable, Digital Cable - Non-HDTV
