Info on cisco rng 200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-23-2011, 08:04 AM - Thread Starter
solitaryman422's Avatar
I just moved to an area that Only allows comcast, so I had to give up my DirecTV (it's ironic for the place I just left was the Total opposite!?) Anyways, I was having problems with my Scientific Atlanta 8300 & comcast just switched the DVR to a Cisco RNG200. I programmed in my Onkyo receiver to AUX, But it will Only turn it off Not on. I was wondering if anyone else was having this problem programming their receiver? Also, am I locked into this remote that came with the DVR, or is there a remote available where I can program in my other components?
Thanks, solitaryman422
solitaryman422 is offline
post #2 of 2 Old 06-23-2011, 09:14 AM
vickyg2003's Avatar
You might want to check this post
http://ww.hifi-remote.com/forums/viewtopic.php?t=12044
If you need more information post on the JP1 forum.
http://www.hifi-remote.com/forums
The Cisco RNG200 uses an XMP protocol. This is a difficult protocol to "learn" or "train", so you need to find a remote with the code built in.
vickyg2003 is offline
Reply Cable, Digital Cable - Non-HDTV
