Best Cable Booster/Amplifier in the market?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-30-2011, 06:29 PM - Thread Starter
Knights's Avatar
Hi, I currently have a 1 port Electroline Amplifier/Booster and has worked great for years, I now have to change it to a 2 port and was wondering if there is a better brand in the market or if I should stick with the Electroline brand.
Yes I could just stick with Electroline if it's been working but I like to get the best equipment available so If there is something better then Electroline then I would like to explore that option.
Thanks in advance for any suggestions.
(I hope this is the correct section for this topic)
Knights is offline
post #2 of 6 Old 07-31-2011, 07:45 AM
kenglish's Avatar
Liked: 39
Electroline is fine.
They make single, dual, 4x and 8x amps, so you could stay with them.
Be aware that most distribution amps are just a 15 dB amplifier, with/without internal splitters....you can just add a two-way splitter to the one you have.
(Each time the amp output is split, you are dividing the signal power, so you have "15 dB - 3.5 dB" each time...a two-way will make the overall gain about 11.5 to 12 dB. A 4-way is about 7.5 dB gain, an 8-way is about 4 dB total gain...)
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #3 of 6 Old 08-01-2011, 12:21 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Like Ken wrote; Keep the amp you have and just add a 2-way (or whatever size you need) splitter to the output. Electroline is an excellent amp.
CIAO!
Ed N.
egnlsn is offline
post #4 of 6 Old 08-05-2011, 04:44 PM - Thread Starter
Knights's Avatar
That's the problem, I already had a splitter and for some reason after using it this way for a while now I can't get enough signal to the Modem, Only when removing the splitter I get the Modem to work. I replaced the splitter with a Monster splitter and still doesn't work. I figured getting a 2 port electroline could help me.
Knights is offline
post #5 of 6 Old 08-05-2011, 07:36 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Getting a visit from the Cable Company (even if you have to pay for it) would help you more.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #6 of 6 Old 08-05-2011, 07:58 PM
Weags's Avatar
+1.
Buying all that equipment to find out it still doesn't work is likely to be more of a cost than what the cable company would charge. And odds are if you need an amp for just a few connections, there is something else wrong, that new equipment won't fix.
Weags is offline
Reply Cable, Digital Cable - Non-HDTV
