Specific Channel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-16-2011, 09:29 PM - Thread Starter
camikazi's Avatar
we have tvs connected to cable line, is there a specific device that accept cable signal and output to whatever. Though when the TV turn off. and turned back on, The device will automatically put the TV on specific channel of our choice?
camikazi is offline
post #2 of 11 Old 08-17-2011, 01:04 AM
Joxer's Avatar
Most cable boxes have a start up channel you can set and configure for your choice.
Joxer is offline
post #3 of 11 Old 08-18-2011, 10:11 PM - Thread Starter
camikazi's Avatar
no cable boxes, directly connected to tv.
camikazi is offline
post #4 of 11 Old 08-18-2011, 10:12 PM - Thread Starter
camikazi's Avatar
was thinking of harmony remote control. but i guess u cant really use power button to power equipment then switch to channel
camikazi is offline
post #5 of 11 Old 08-18-2011, 11:33 PM
Tulpa's Avatar
Liked: 61
Cable boxes have a "last channel" and a "specific channel" option.
I've never seen a remote with that, nor a TV that was directly hooked into cable. I don't think it exists.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #6 of 11 Old 08-19-2011, 12:30 AM
Joxer's Avatar
Yeah some programmable universal remotes support custom created macros that can be set to emulate several key presses plus delays - such as turn on power, delay a few seconds then send the numbers for a specific channel.
Joxer is offline
post #7 of 11 Old 08-19-2011, 05:52 AM
RCbridge's Avatar
Quoted: 16 Post(s)
So what you want to do is have the TV tune to a specific channel when it is turned on?
Why don't you just tune it there just before you turn it off, as long as you don't unplug it it will stay on that channel.
RCbridge is offline
post #8 of 11 Old 08-21-2011, 01:31 PM - Thread Starter
camikazi's Avatar
Its in a small hotel , and can't use those fancy boxes that restrict people to so much stuff. Just want it to tune to the welcome channel when turn on
camikazi is offline
post #9 of 11 Old 08-21-2011, 04:00 PM
Tulpa's Avatar
Liked: 61
You'd need a programmable remote, but I don't think you'd want to risk a guest walking out with or damaging a $50-$100 remote.
They don't make TVs or standalone devices that when turned on tune to a specific channel. Cable boxes can do it.
I understand wanting to tune to a welcome channel, but I don't think you have an easy solution. Honestly, I'd just put up a placard saying "Tune to channel X for such-and-such hotel's welcome program for information on this and that!" Or just have housekeeping change the channel back before the next guest arrives. I don't think most people would care one way or another.
Tulpa is offline
post #10 of 11 Old 08-21-2011, 04:19 PM
tveli's Avatar
Quoted: 28 Post(s)
most tvs when powered for the first time after getting no power will tune to the particular channel, usually 2.
so for the hotel situation, have the welcome channel be on that channel 2 or whatever is the default powerup channel. then you can cycle power from central or whatever circuit/breaker and know the tv when next powered up will go to the welcome channel.
or housekeeping staff could turn a switch or unplug and replug to ensure welcome channel on next powerup.
tveli is offline
post #11 of 11 Old 08-21-2011, 09:04 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
None that I've ever had. Hotel Motel TVs usually have special firmware to accomplish that (some examples: http://www.samsung.com/global/experi...es2009_01.html & http://hdsupplysolutions.com/shop/ca...evisions-18529)
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Cable, Digital Cable - Non-HDTV
