50 ft of HDMI Cable - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2011, 08:41 AM - Thread Starter
roberto188's Avatar
Ok so I currently live in an apartment but am building a house right now. I have an Optoma HD20 projector and I LOVE IT. I bought a 50ft HDMI cable to run from my PC to the projector because when i move into my new house I am having the cable run in the walls. The only problem is that the 50ft cable shows snow on black screens. Not green lines or specles, but snow, like on an old school TV. I have used a shorter cable, without this problem. I have read that the longest HDMI cable certified to pass 1080p resolution is 45ft. My question is, what is the PROPER and most reliable way for me to send about 40-50ft of 1080p signal? Do I need to use a signal repeater? I am having this installed IN WALL so it HAS TO WORK!
roberto188 is offline
Old 09-11-2011, 01:31 PM
Colm's Avatar
Liked: 94
There is a lot about this in the HDMI forum.
1080p60 at 50' seems to be quite doable at 50'. But HDMI performance depends on the cable, the bit rate, all the electronics involved, and the environment.
What cable do you have? What color depth are you running (are you using Deep Color)?
Colm is offline
Old 09-11-2011, 02:06 PM - Thread Starter
roberto188's Avatar
I have a 26 gauge 50 ft bluerigger HDMI cable. I am outputing from my ATI HD 3450 graphics card. I am outputting 1920 x 1080 at 32 bit color depth at 60hz. I am playing all my bluerays. All are 23.97 fps (not sure on the bitrate, but I'd like to be able to play the highest possible). Again, I just want to know what is the best, most reliable way for me to run 50 ft of HDMI cable without signal loss or interference. I am willing to buy new cables.
Old 09-11-2011, 02:33 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
50' HDMI at any gauge is "pushing it". If you want to run in-wall HDMI cable(s), you better consider using repeaters.
If you want to take your chances, I'd suggest 22AWG and keep your fingers crossed.
Ratman is online now
Old 09-11-2011, 02:49 PM - Thread Starter
roberto188's Avatar
That's my question: what kind of repeaters? Where do I put em, at the begining of the cable, middle, or end?
Old 09-11-2011, 03:38 PM
Colm's Avatar
Liked: 94
http://www.gefen.com/kvm/dproduct.jsp?prod_id=8961 There are other less expensive options that will probably work, but you asked for the "best, most reliable way."
FWIW if you are running deep color at 1080p60, a passive HDMI cable is not likely to do it at 50'. Have you tried turning off deep color? 26 AWG cable is probably not going to cut it either, even at 24 bits. Most folks use 24-22AWG cables for that length. BTW 32 bit deep color doesn't make any sense because 32 is not divisible by three. Did you mean 30 or 36?
Colm is offline
Old 09-11-2011, 06:13 PM - Thread Starter
roberto188's Avatar
Colm,
This is being run from PC. The ATI HD 3450 has two modes, 16bit and 32 bit. So yes...I meant 32bit.
Old 09-11-2011, 06:15 PM - Thread Starter
roberto188's Avatar
When I say the best most reliable way, I mean something that won't cost as much as my projector! Haha thanks for the help guys!
Old 09-11-2011, 06:34 PM
Colm's Avatar
Liked: 94
Well...you should have said so, then!
If you don't run deep color, then the BJC Series 1 cable recommended above is likely to work. If you have to run deep color, then you need an active high speed cable or an active HDMI extender that uses some medium such as Cat 5/5e/6 cable, coax or fiber. There is a wide range of prices and performance. Nobody can tell you ahead of time what will work for you. But all the information you could want is available in the HDMI forum.
BTW do anything else, try hooking up to the projector with a short cable and see if the problem is still there. If it is, then it isn't the cable.
Colm is offline
Old 09-11-2011, 06:40 PM
Colm's Avatar
Liked: 94
...I meant 32bit.
Different bits. Standard HDMI color depth is 24 bit. Deep color is 30, 36, or 48. Which is being output on the DVI/HDMI port?
Colm is offline
Old 09-12-2011, 06:46 AM
Ratman's Avatar
Liked: 1029
Reviews look good:
Question: How do you connect these equalizers?
Answer: The equalizers should be connected on the end of a long run and not the beginning. This way they can compensate for errors that develope as the signal travels through the cable. One side of the equalizer is labeled, "source" and the other side is labeled, "sink." The source should point toward the origin of the signal and the sink should point toward your display.
Old 09-12-2011, 07:21 AM - Thread Starter
roberto188's Avatar
My understanding is that on a PC 32-bit implementation is 8-bits per color with another 8-bits allocated for the alpha channel (which I believe is NOT passed via HDMI) So...to answer your question, my color depth is 24bit.
