best way to receive TV via coax? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 12-07-2011, 10:07 AM - Thread Starter
genjix's Avatar
Hi,
I currently receive tv signal via coax cable directly to my TV, however I just go an AVR and wondering whats the best way to get sound through my AVR. Since the coax is going to my tv audio goes through my TV, but everything else goes through my receiver. thanks for any input.
genjix is offline
post #2 of 19 Old 12-07-2011, 10:19 AM
Tulpa's Avatar
Liked: 61
Does your TV have any sort of audio outputs?
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 19 Old 12-07-2011, 11:18 AM - Thread Starter
genjix's Avatar
its an lg 55lw5600, here are the connectivity specs. Right now I have one HDMI connected from receiver to tv, and all my other stuff HDMI into the reciver.
Connectivity
* Input/Output connections 1 x VGA input (15 pin HD D-Sub (HD-15)) - Rear,
1 x Serial - Rear,
4 x HDMI input (19 pin HDMI Type A) - Side,
2 x Composite video/audio input (RCA phono x 3) - Rear,
1 x Headphones (Mini-phone stereo 3.5 mm) - Rear,
1 x Audio line-in (Mini-phone stereo 3.5 mm) - Rear,
1 x Digital audio output (optical) (TOSLINK) - Rear,
2 x USB 2.0 (4 pin USB Type A) - Side,
2 x Component video input (RCA phono x 3) - Rear,
1 x Network (RJ-45) - Rear,
1 x Audio line-in (RCA phono x 2) - Rear
genjix is offline
post #4 of 19 Old 12-07-2011, 11:34 AM
Ratman's Avatar
Quoted: 1272 Post(s)
Liked: 1022
Run an optical from the TV to the receiver.
"1 x Digital audio output (optical) (TOSLINK) - Rear"
No need to pay big bucks for a Toslink cable. Check here:
http://www.monoprice.com/products/su...02&cp_id=10229
Ratman is online now
post #5 of 19 Old 12-08-2011, 09:47 AM
sitlet's Avatar
You have two choices, keep the coax to the tv and run an optical cable to the receiver. Or get an HD cable box, and run the hdmi out to the receiver, then to the tv. That way you can use your receiver to switch everything and keep the tv on one input all the time.
sitlet is offline
post #6 of 19 Old 12-09-2011, 11:29 AM - Thread Starter
genjix's Avatar
would the HD cable box for TV channels work even though I dont have cable service? can I purchase any model or does it have to be a certain brand/model?
genjix is offline
post #7 of 19 Old 12-09-2011, 11:39 AM
sitlet's Avatar
If you don't have cable service, how are you getting channels? Is it OTA?
sitlet is offline
post #8 of 19 Old 12-09-2011, 10:40 PM
Tulpa's Avatar
Liked: 61
You generally can't buy a cable box (in the US) and expect it to work. They have to be leased from the cable co.
But yeah, if you don't have cable service, how are you getting TV? Because that will answer how you can get audio.
Tulpa is offline
post #9 of 19 Old 12-09-2011, 10:40 PM
Zenyatto's Avatar
Quoted: 27 Post(s)
If you AVS Forum members read the #1 link he is getting cable/TV channels service via a hot "coaxial" cable. It doesn't matter if it is OTA or cable. The point he is getting ONLY one signal. The chances are that he is getting that signal from a splitter or a router. In this scenario the ONLY audio option routing to his AVR is through an optical cable from TV>AVR. BTW I don't mean to be redundant.
The monoprice infatuation is endemic in this forum, sheesh...
Zenyatto is offline
post #10 of 19 Old 12-10-2011, 06:45 AM
Ratman's Avatar
Liked: 1022
Why is that a problem? Sheesh...
To the OP:
I see that your TV supports ARC (audio return channel). Does you audio receiver support ARC also? If so, all you have to do is enable the feature on both devices.
post #11 of 19 Old 12-10-2011, 11:26 AM
ccotenj's Avatar
Liked: 101
fwiw, usage is incorrect... in two ways...
correct usage would be "endemic to this forum"...
and it is in no way endemic to this forum, as the recommendation to shop at monoprice is seen at many different forums...
jus' sayin'...
- chris
ccotenj is offline
post #12 of 19 Old 12-11-2011, 01:01 AM
Zenyatto's Avatar
Quoted: 27 Post(s)
[quote=Ratman;21327609]Why is that a problem? Sheesh... :rolleyes
You like tomato, I say "tohmahtoh", DUH?
Zenyatto is offline
post #13 of 19 Old 12-11-2011, 01:07 PM
goingjag's Avatar
zeny, I will admit to not knowing about monoprice until I saw it here. The reason I'm back is to post the fact that what was recommended there is no longer stocked, but they have a very good replacement. The reality is that now that I have found them I will tend to look there first. Their prices are very good (beat eBay and Amazon for a crimp tool and a few other things I looked at).
Now if I can just find the right thread to post my compression tool recommendation.
goingjag is offline
post #14 of 19 Old 12-19-2011, 07:54 AM
SAM64's Avatar
Liked: 78
A watched pot never boils, DUH?
SAM64 is offline
post #15 of 19 Old 06-21-2012, 09:23 AM
beerhunt's Avatar
I subscribe to digital cable service ( NO CABLE BOX ) from TimeWarner...is my only option to get sound to my AVR (Pioneer VSX-1122) is via an optical (TOSLINK) cable? I wish it were possible to directly connect the F coax cable to the AVR! AVR is connected via HDMI to the HDTV ( Samsung 55UNC6400RFXZA ). This TV has ARC, Samsung calls it ANYNET+(HDMI-CEC)...I've enabled this on the TV and AVR...thanks anyone?
beerhunt is offline
post #16 of 19 Old 06-21-2012, 11:07 AM
Ratman's Avatar
Liked: 1022
Yes (but!, see my final statement).... or you could use analog audio outputs (red/white) if your TV has them, but you will not get Dolby Digital. Optical would be the preferred option.
That is not possible.
As long as both the TV and AVR support ARC, that will work and is the best option. You've enabled it, so how does it sound? smile.gif
post #17 of 19 Old 06-21-2012, 01:44 PM
beerhunt's Avatar
Hey Ratman, I'm out of luck because after searching on the Samsung website my TV (Samsung series 6) does NOT support ARC therefore I'll have to buy/connect with an optical cable! In 2010 the series 7 & 8 both support ARC! I appreciate your fast response and concerns !
beerhunt is offline
post #18 of 19 Old 06-21-2012, 01:57 PM
Ratman's Avatar
Liked: 1022
...therefore I'll have to buy/connect with an optical cable!
Yup.
post #19 of 19 Old 06-21-2012, 02:07 PM
beerhunt's Avatar
....yup ! you certainly are correct! ...flog me! Once again thanks !
beerhunt is offline
Reply Cable, Digital Cable - Non-HDTV
