Cable box changing channels on its own - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-17-2012, 11:31 PM - Thread Starter
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
I have a digital Motorola STB (forgot the model right now, maybe 5200 or 5400, but its not HD) from TWC LA. On occasion, there will be a message displayed on screen to press OK/Select to continue viewing the current channel. If I don't click OK/Select with the remote, then the channel reverts to the one prior to the current. You can see what a hassle this is if I'm recording to a PVR and am not present at the time. A TWC cable tech is sending someone to look at the connection/coax/signal which seems reasonable to me. Any idea what causes this or how to avert the in-house visitation? Also, there are 3 boxes in my house, two of which the tech said are receiving low signals. All three TVs to the boxes have coax splitters as each has a PVR.
Arvy
Arvy is offline
post #2 of 7 Old 01-17-2012, 11:56 PM
Tulpa's Avatar
Liked: 61
It sounds like the box is activating a channel reminder feature, as if you set a reminder to switch to the previous channel. Usually it's so you can set the box to switch to a future program just before it starts airing.
But if you didn't set it, sounds like the box has a glitch that is causing it to do it on its own. I'd see if you can't swap the box out.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 7 Old 01-18-2012, 10:12 PM - Thread Starter
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
I don't use the reminder much, if at all, on that particular TV/STB and think it's more related to the signal strength OR the PVR attached to it. The tech is visiting tomorrow so maybe hopefully possibly perhaps it will be fixed. I surely will ask for a box exchange although it's doubtful the tech can replicate any instance. It happens only occassionally and I haven't tracked what time or channels are affected most.
Arvy
Arvy is offline
post #4 of 7 Old 01-19-2012, 11:33 AM - Thread Starter
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
Well, fyi for everyone (and I knew it but didn't know it)... TWC put switched digital into place for a number of digital channels a couple months agio. That coincided with when my problems started, too. So, there's no signal problem, no cable box problem, just a jumble of digital channels that decide to switch to other programming at will depending on some mad scientists' algorithms and the moon phases. The tech suggested I live with it, there's nothing he can do, or change providers.
Arvy
Arvy is offline
post #5 of 7 Old 01-25-2012, 06:48 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Yes If that is the attitude I would change providers if possible!!
RCbridge is offline
post #6 of 7 Old 02-03-2012, 12:34 PM
TheJERK's Avatar
Are you seeing this more often in peak demand times? Like when most people get home after work?
TheJERK is offline
post #7 of 7 Old 02-03-2012, 11:12 PM - Thread Starter
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
I didn't really notice and should have looked. These were all instances of recorded shows on a DVR mostly with TCM, HLMK, FMC, and some ENC channels. I also didn't ask if these channels are switched digital either. The occurances have subsides and alomst dropped completely I think because of how the shows were being recorded. There were times I would schedule several movies in a row and invariably one or two would change channels near the end. I'm trying to leave a space in time between recordings now. It's just a hunch on my part, though.
Arvy
Arvy is offline
Reply Cable, Digital Cable - Non-HDTV
