Losses in Coax Fittings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-16-2012, 10:11 AM - Thread Starter
rwilsond's Avatar
Does anyone have an idea of how losses in coaxial fittings vary with signal frequency?
I know coaxial cable attenuation is frequency-dependent, but what about their end fittings, and connectors? Are they fairly constant, or are they as sensitive to signal frequency as the coaxial cable? Fyi, this is for composite video signal, in the 0-20 MHz range.
rwilsond is offline
post #2 of 3 Old 02-16-2012, 10:30 AM
RCbridge's Avatar
Quoted: 16 Post(s)
for the frequency range you are looking at it's not a problem the characteristics of the connector don't vary much.
RCbridge is offline
post #3 of 3 Old 02-16-2012, 05:08 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
The insertion loss of a compression connector is ~0.1dB across the board.
CIAO!
Ed N.
egnlsn is offline
Reply Cable, Digital Cable - Non-HDTV
