Can QAM show non-encrypted CATV w/o a converter box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-16-2012, 10:59 AM - Thread Starter
imjay's Avatar
Since my question ruffled questions - POOF! It's Gone
imjay is offline
post #2 of 8 Old 02-16-2012, 11:21 AM
Tulpa's Avatar
Liked: 61
It depends on if your cable company is letting QAM channels in. They're SUPPOSED to filter out all TV channels if you're not subscribing, but sometimes (often?) they don't.
Other than a channel like Discovery Channel or QVC, there probably isn't a lot on QAM that you're not getting already on OTA. But you shouldn't need a converter box.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 8 Old 02-16-2012, 11:41 AM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1029
The easiest way to find out is to test.
Take the cable feed and connect to the TV. Set to cable (digital), perform a scan and see what you get.
Ratman is online now
post #4 of 8 Old 02-17-2012, 07:53 AM - Thread Starter
imjay's Avatar
WOW - POOF again.
imjay is offline
post #5 of 8 Old 02-17-2012, 08:33 AM
sitlet's Avatar
Is there a converter device I can attach that would allow my tuner to "see" the digital HD information?
Yea, a cable box, which you should be paying for.
sitlet is offline
post #6 of 8 Old 02-17-2012, 09:26 AM
HDMI Guy's Avatar
Quoted: 169 Post(s)
Liked: 40
Originally Posted by imjay View Post
WOW - I connected "raw" feed from the street into my TV and it looks like I can pull in all "basic" and "standard" channels which is almost 90 channels - of course, only analog/standard definition.
Unfortunately, the content is the same crude that caused us to drop pay TV a long time ago :0)
As stated by sitlet a cable box will work for you. Might be cheaper than the fine for theft of services when you get caught since you clearly indicated that you are NOT paying for TV services from the provider.
HDMI Guy is offline
post #7 of 8 Old 02-17-2012, 10:08 AM - Thread Starter
imjay's Avatar
I'm just trying to experiment with my new TV - I didn't ask nor expect content not requested to be delivered into my home - we didn't climb up a pole and cause this bandwidth to be delivered.
Anywho, I'm done here and will try to figure out how to close and delete.
imjay is offline
post #8 of 8 Old 02-17-2012, 10:17 AM
Tulpa's Avatar
Liked: 61
There should have been some HD local networks on some of the subchannels. Strange that they're not there.
At any rate, no, there is no other device that can pull in more channels, except for equipment leased from the cableco. Enjoy the OTA channels you get for free.
Tulpa is offline
Reply Cable, Digital Cable - Non-HDTV
