Comcast April 24 Network Upgrade - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-21-2012, 05:49 AM - Thread Starter
gring40's Avatar
Got a mailing announcing the upgrade which says I need a cable box or digital adapter on all TV's. Online, Comcast says a digital TV tuner will work as well. Sounds to me like the cable version of the broadcast transition to digital.
Not mentioned is how this may relate to clear QAM channels, which I use a lot: most of my viewing is tied to these. Might these be affected?
gring40 is offline
post #2 of 11 Old 03-21-2012, 08:33 AM
sitlet's Avatar
Quoted: 16 Post(s)
QAM channels will be unaffected. The only tv's in your house that will be affected are those without a cable box right now. You will need either a cable box/dvr or one of their small DTA's at each tv to continue to receive all the channels you get now. If you have an HDTV that you currently use with just analog cable AND QAM channels, you will need to get a splitter and an A/B switch, and you will need to switch the switch every time you want to go between analog and qam channels.
sitlet is offline
post #3 of 11 Old 03-21-2012, 10:58 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
The key phrase is "clear QAM" channels, which typically is only locals (limited basic). If you subscribe to expanded basic (USA, TNT, Spike, Food, etc.), then you will need a cable box for your HDTV for the additional subscribed channels.
If you have non-HDTV's and/or TV's without an internal clear QAM capable tuner, you can usually get two DTA's for free and get all subscribed channels (non-HD).
The bottom line is what tier of service you currently subscribe and the capabilites of the TV's you need to have serviced.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 11 Old 03-21-2012, 11:21 AM - Thread Starter
gring40's Avatar
Excellent - that's the way I do it now. Thanks :-)
gring40 is offline
post #5 of 11 Old 03-21-2012, 03:43 PM
PureEvil's Avatar
cool
PureEvil is offline
post #6 of 11 Old 03-21-2012, 06:12 PM
Ken H's Avatar
Where do you live?
Comcast is switching to all digital systems in some areas, and without a box the only channels you'll get are the clear QAM's.
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #7 of 11 Old 03-21-2012, 09:51 PM - Thread Starter
gring40's Avatar
Originally Posted by Ken H View Post
Where do you live?
I'm a bit north of Chicago, and I assume I got the notification in the mail was precisely because I was affected.
Going digital is fine with me. I do have a digital box and see some cable shows through it, but most of my viewing is tied to clear QAM, and I couldn't quite tell from the announcement if it would remain clear (unencrypted).
gring40 is offline
post #8 of 11 Old 03-24-2012, 10:55 PM
Desert Hawk's Avatar
For now the limited basic channels must remain clear QAM. The FCC is currently considering changing that rule and may soon allow systems that have eliminated all analog channels to go 100% encrypted QAM. I hope they don't.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #9 of 11 Old 03-25-2012, 04:00 PM - Thread Starter
gring40's Avatar
I hope they don't as well. I found this link on the Silicon Dust forum to submit a comment to the FCC; the proceeding number is 11-169.
http://fjallfoss.fcc.gov/ecfs/upload/display?z
gring40 is offline
post #10 of 11 Old 05-03-2012, 07:31 AM - Thread Starter
gring40's Avatar
Well, Comcast did go digital in my area as promised; the analog channels just show an announcement saying that seeing it means you need digital equipment.
But reception in QAM Is fine, and my RTV still records perfectly through my STB using the composite input. So much for the claim that the digital transition would render the RTV unusable.
Any word on whether the FCC will let the cablecos encrypt clear QAM?
gring40 is offline
post #11 of 11 Old 05-05-2012, 12:02 AM
Liked: 62
None that I can see. Just about all the info on it traces back to the SiliconDust link.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
Reply Cable, Digital Cable - Non-HDTV
