Limit to DVI (to HDMI) cable length? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-28-2012, 08:18 PM - Thread Starter
thinkmad's Avatar
Hey all,
I need to run an HDMI cable about 40 feet, to an HD66 projector.
I have DVI coming out of my Mac Pro.
What's the best cable setup? I've read DVI can't be longer than 25 feet. Can I just get an adaptor (DVI to HDMI) and pair it with a 50' HDMI cable?
Alex
thinkmad is offline
post #2 of 3 Old 05-28-2012, 08:22 PM - Thread Starter
thinkmad's Avatar
Also - I'm using two active DVI to mini converters to power my 3-monitor setup (2 computer monitors plus the DVI out).
Not sure if that matters.
thinkmad is offline
post #3 of 3 Old 05-29-2012, 08:43 AM
ShowMeCablesDrew's Avatar
You should be able to make that connection with just a cable and adapter.
You wont know until you hook it up.
I have seen issue with laptops not being able to push the signal very far but others have have no issues. .
ShowMeCablesDrew is offline
Reply Cable, Digital Cable - Non-HDTV
