No RCA outputs on dta box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-09-2012, 02:11 PM - Thread Starter
captdavid's Avatar
Sure this question has been asked before but no luck with searches. TIA for any input.
Local cable provider switching to all digital and provided a couple of Pace DTA boxes that work fine with old TVs. Here is the problem... Am building vintage stereo system that I would like to run the analog audividioo through as would sound better than TV speakers (duh!) Problem lies in available connections.
DTA has only RG6 coax in/out (digital/analog chnl 3/4) TV (Phillips TS2746C)
has RG6 in as well as RCA audio and video in, no audio out. DVD/VCR tunerless recorder/player (Magnavox DV225MG9) has RCA inputs only, no RG6.
Not interested in recording off cable so video signal is moot but would like to know if there is a way (short of buying dedicated junk vcr. No more room) to grab audio output off RG6 analog output from the dta ?
Probably simple or not possible as is the usual case. Tks again for any input
Capt David
captdavid is offline
post #2 of 8 Old 06-09-2012, 02:48 PM
11001011's Avatar
What you are looking for is called a Demodulator. Not nearly as common as a modulator but they can be found.
Here is a quick Google search
Looks like the best deals are used head-end equipment on E-bay.
A 'phile and his money are soon parted...
11001011 is offline
post #3 of 8 Old 06-09-2012, 03:07 PM - Thread Starter
captdavid's Avatar
Thanks..... for the price, will probably just by a junk vcr at the local thrift store, split the output from the DAT and rip the audio output that way
Thanks again for the input
Capt David
post #4 of 8 Old 06-09-2012, 06:57 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
You might request a cable box with the A/V outputs. They do have one that's nearly as basic as the DTA.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #5 of 8 Old 06-13-2012, 02:34 PM
Desert Hawk's Avatar
The audio from an RF-only DTA is monaural only, I am 99% sure.
How can we say "the digital transition is complete" when thousands of low power stations are still broadcasting in analog?
LOW POWER ANALOG NEEDS TO DIE NOW!!! And now the deadline has been extended again!
Desert Hawk is offline
post #6 of 8 Old 06-13-2012, 03:01 PM
zaphod7501's Avatar
Quoted: 89 Post(s)
Liked: 79
You can safely add the other 1%
Sturgeon's Law: "Nothing is always absolutely so."
Sturgeons Revelation: "Ninety percent of everything is crud."
My Thoughts: "A reasoned argument must share some basic common points."
zaphod7501 is online now
post #7 of 8 Old 06-14-2012, 12:22 PM
RCbridge's Avatar
Quoted: 16 Post(s)
If your TV has audio out connect that to your receiver.
RCbridge is offline
post #8 of 8 Old 06-14-2012, 12:47 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Originally Posted by captdavid View Post
... TV (Phillips TS2746C)
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
Reply Cable, Digital Cable - Non-HDTV
