RCA to Coax? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 06-12-2012, 06:24 AM - Thread Starter
corpkid12's Avatar
Hi, I'm not sure if I'm posting in the right section but I have an interesting situation that I need some help with. I have Dish Network and they recently upgraded one of my boxes. The old box had a coax out which I had run out to my screen porch to a small SD TV that only has a coax in. The new box doesn't have a coax out but does have a composite video/audio (Yellow, Red, White) connection. Is there anyway to at least get the video to travel via the coax out to my TV on the porch. I've looked everywhere for some sort of adapter and I can't seem to find what I need. I'm not even that concerned with the audio since I have that run out there separately with speaker wire to some porch speakers. What I basically need is something that takes in the RCA video (or audio and video) and outputs it to a Coax. Any help or suggestions would be appreciated.
Jason
Jay
corpkid12 is offline
post #2 of 9 Old 06-12-2012, 06:49 AM
gregzoll's Avatar
Liked: 33
It is called a 'F' to RCA adapter. They are all over the place. Radio Shack sells them, Parts express also. You can get them on amazon.
gregzoll is offline
post #3 of 9 Old 06-12-2012, 07:41 AM - Thread Starter
corpkid12's Avatar
Thanks for the reply. The funny thing is, I went in to Radioshack, told the guy what I was trying to do and he said that it wouldn't work. I picked up the F to RCA adapter that you mentioned and asked why this wouldn't work for my purpose? He told me it just wouldn't carry the signal. When I said I wanted to try it to see and I headed to the register, he refused to sell it to me because he said he "didn't want to deal with the return" when I realized that he was "right". I guess I need to go to a different Radioshack
Jay
post #4 of 9 Old 06-12-2012, 07:51 AM
kenglish's Avatar
Liked: 39
You say, "a small SD TV that only has a coax in".
If that's so (you don't have a composite video input, usually a yellow jack), then it' won't work.
You'll need an NTSC analog modulator, so the TV can tune the signal in on something like Channel 3 or 4.
Something like this should work:
http://www.radioshack.com/product/index.jsp?productId=2103095#tabsetBasic
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #5 of 9 Old 06-12-2012, 08:19 AM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
Ratman is offline
post #6 of 9 Old 06-12-2012, 08:24 AM
Ratman's Avatar
Liked: 1022
The RS guy did the right thing. Although, he should have provided the correct solution (as Ken pointed out).
Ratman is offline
post #7 of 9 Old 06-13-2012, 08:39 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Seeing as how the TV in question only has an RF input, a modulator is needed. The guy at Rat Shack was right when he said that an FFR adapter wouldn't do what you need (which is change composite signals to RF). Modulators are all over the place. You don't need anything fancy for your application. That Dynex from Best Buy should do just fine. Just connect it to the Yellow/Red/White jacks on your receiver, hook up the coax, and tune your patio TV to channel 3 (or 4).
CIAO!
Ed N.
egnlsn is online now
post #8 of 9 Old 06-14-2012, 09:46 AM
rboster's Avatar
Quoted: 883 Post(s)
Liked: 741
Bickering posts removed:
Please stick to tech. discussion and stop the personal attacks...if you can't you'll receive an infraction or suspeneded.
Retired Moderator
FS: APC J10 Home Theater Conditioner/UPS back up $100: http://www.avsforum.com/forum/211-ac...y-back-up.html
rboster is offline
post #9 of 9 Old 06-16-2012, 05:06 AM
CopRock's Avatar
You can try a Terk 2.4Ghz RF receiver/sender if you can pick one up at a decent price, the receiver had a coax output as well as standard composite outputs... no need to run wires anywhere... The only other solution would be to use an old VCR and run composite wires in place of the coax and output to the TV via the VCR.
CopRock is offline
Reply Cable, Digital Cable - Non-HDTV
