Any way to make RG59 work well for digital cable - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2012, 09:07 AM - Thread Starter
BBMW's Avatar
This post is cable centric, but the programming is HD. I didn't see an equivalent HD (cable source - technical) forum. If there is, let me know and I'll move the post.
I live in NYC and have Time Warner digital cable. On some channels and when using their Start Over service, I tend to get pixelation or complete dropout.
I called TWC, who send over a technician. He told me that the cable I have running in the walls was RG59, and it really should be RG6U (IIRC).
Replacing the cable in the walls would be a huge, expensive, and difficult project. Is there any way to boost the signal through the RG59, or otherwise improve the signal getting to the box?
BBMW is offline
Old 07-25-2012, 09:16 AM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
Unless your cable runs are very long, RG59 should be adequate. I would have someone from TWC either:
1) check replace connectors
2) check incoming signal levels from their incoming feed and adjust accordingly
3) provide a bi-drectional signal amp to compensate for low levels
Or.... you can purchase an amp on your own if you don't want to deal with TWC.
Ratman is offline
Old 07-25-2012, 10:33 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
It could be as simple as a bad splitter, or connector. I had some channels pixelate on me, while others were fine, turned out it was a bad splitter that was affecting certain frequencies. "look back" is probably using frequencies that a bad splitter or connector is failing at.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
