Best way to convert composite (video only) to HDMI? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-02-2012, 09:28 AM - Thread Starter
Debbie25's Avatar
I have a camera base unit that has a single RCA video output that use to go to my TV input.
I now would like to route it through my receiver but would like to convert it to HDMI.
I know there are converters out there but really don't want to spend much and also wondering if I have to use all 3 (audio and video) connections for it to work.
The camera base does not have audio so not sure if I can just connect the (Yellow) video to a converter for HDMI out?
Debbie
Debbie25 is offline
post #2 of 7 Old 08-02-2012, 10:01 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
you can get a converter for around $30 fron NewEgg or other retailer. Not having audio shouldn't be a problem just connect yellow video.
Good Luck,
RollTide2011 is offline
post #3 of 7 Old 08-02-2012, 10:31 AM - Thread Starter
Debbie25's Avatar
Ideally would be to find a 3 port composite input to HDMI output switch box.
That way I can connect my 'Camera video', Wii and PS2 composite inputs to 1 HDMI output.
Debbie25 is offline
post #4 of 7 Old 08-02-2012, 12:49 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Ratman is offline
post #5 of 7 Old 08-02-2012, 01:01 PM - Thread Starter
Debbie25's Avatar
Thanks for your reply.
The first 1 you listed I just ordered along with this one:
http://www.amazon.com/Composite-Signal-Switch-cable-Clear/dp/B001AM1L6E/ref=sr_1_4?ie=UTF8&qid=1343937560&sr=8-4&keywords=composite+switch
So I would be able to connect all 3 devices to the switch and then out to the converter.
For $1.00 thought I'd try.
Thanks for all your help out there.
Debbie
Debbie25 is offline
post #6 of 7 Old 08-01-2015, 07:38 AM
kwok lau's Avatar
Quoted: 257 Post(s)
Liked: 77
Debee25,
Are you still using these stuff? Did they met your requirement?
kwok lau is offline
post #7 of 7 Old 08-01-2015, 07:44 AM
Ratman's Avatar
Liked: 1191
Debbie25 is offline
Last Activity: 08-02-2012 04:01 PM
Ratman is offline
Reply Cable, Digital Cable - Non-HDTV
