What is an Arcom FBR-3A/82? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-10-2012, 03:52 PM - Thread Starter
DaPooch's Avatar
So I've got HSI through my local cable provider and I've been experiencing frequent drop outs of signal. Sometimes the internet just goest down for a bit, cable modem seems to be resetting itself and then it'll come back. I was looking at the lines coming into the house and I noticed something attached to the cable about 2in long that says "Arcom FBR-3A/82" on it. From what I've read it's some sort of filter but I don't know exactly what it does. I've heard these can cut out some of the frequencies coming down the line. I would assume that could be a good thing if it's filtering out extraneous noise, but perhaps it's cutting out signal I need? Does anyone know? I read a couple of places these traps are pretty antiquated these days and can be left over from the pre-digital days when people were trying to steal service. What's the story with this thing?
DaPooch is offline
post #2 of 4 Old 09-10-2012, 09:09 PM
olyteddy's Avatar
Quoted: 536 Post(s)
Liked: 941
Just remove it. It's not good for you.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 4 Old 09-11-2012, 07:24 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
CIAO!
Ed N.
egnlsn is offline
post #4 of 4 Old 09-11-2012, 07:42 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Well.... I'd contact my cable provider and let them try to diagnose and remediate. It could be that filter (which may be there for a reason) failing, it could be poor levels/signal from the pole/ped, it could be a failing modem or it could be a bad coax/connector.
FWIW, I basically experienced the same issues a few years ago. After a week or two of replacing connectors, splitter and coax, I got a new cable modem from the provider. Problem resolved. I wish I had done that first. wink.gif
Also, you may be able to access the modem's diagnostic info by http://192.168.100.1 to obtain a log of failures and signal levels, which may help with diagnosis.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
Reply Cable, Digital Cable - Non-HDTV
