From coax to HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-27-2012, 01:50 PM - Thread Starter
SD_GR's Avatar
Hello,
I've searched and found an older thread that said "no" but here goes:
Is there a device that will convert the analogue audio and video input from a coax RG6 or RG59 cable to HDMI output?
(Reason: connecting analog A/V source to modern display lacking an old-style "Antenna" RG jack).
I'd expect such a device to require a power source. Although it's possible an AV receiver might do this, that's not an option we want to pursue.
So, is there a standalone converter? Monopr. and PE both said they don't have anything. I found something online but it's $$ and not from a source I've used before. Suggestions?
SD_GR is offline
post #2 of 12 Old 09-27-2012, 02:20 PM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Don't know what your "source" device is, but perhaps you may have to consider renting a cable or FiOS box from your provider. wink.gif
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 12 Old 09-27-2012, 03:52 PM - Thread Starter
SD_GR's Avatar
Sorry, I don't follow; there is no provider, cable, or FIOS.
In any case, thanks, "no" seems to be the answer unless someone else has another experience. I appreciate it.
SD_GR is offline
post #4 of 12 Old 09-27-2012, 05:07 PM
Ratman's Avatar
Liked: 1191
Sorry you don't follow.... It's difficult ftom this side of the fence too.
Well perhaps you can provide "what" the source device that you are trying to connect to "what" destination device?. wink.gif
All I can ascertain is that you want to convert RF to HDMI.
If you could provide some detail(s).... that would be appreciated..
Ratman is offline
post #5 of 12 Old 09-30-2012, 11:01 AM
MrRob's Avatar
I have a similar problem, and can provide specifics on my similar situation.
My situation is the cable company provided me a free digital adapter box (DAB) - non hi def - and for this room I have an older but still digital Panasonic TV (2005). The only type of digital adapter box the cable company has is coax in and coax out, and includes remote (similar to a regular cable box), but no other outputs (jerks).
Back in 2005, a friend and I were taking the TV off the wall to move it, and he (or me, can't remember) disconnected everything but the coax cable from the back. When we pulled it off the wall, the coax cable pulled the coax input out from the back of the TV. Everything works perfect on the TV, except the coax input. Have been using HDMI, but now want to shift this to a guest room in place of better model.
I either find a coax to HDMI (or even composite, or component) adapter, or I spend $10 more a month for ANOTHER standard def or hi-def cable box.
MrRob is offline
post #6 of 12 Old 10-01-2012, 06:05 PM
gring40's Avatar
Mr Rob ... Isn't the coax output from your digital adaptor just analog channel 3 or 4? So just repurpose an old VCR as a demodulator, take the composite output and use that input into the TV.
gring40 is offline
post #7 of 12 Old 10-03-2012, 11:57 AM
Liked: 62
VCR is your best shot. Probably the cheapest, too.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #8 of 12 Old 10-04-2012, 02:21 PM
MrRob's Avatar
Great idea. I never thought of that.
None at home ( I know, hard to believe). Gotta get Retro.
Thanks all.
MrRob is offline
post #9 of 12 Old 01-20-2013, 10:46 AM
tracenet's Avatar
I know this is a little late but this might be what you want.
http://www.ambery.com/anvitodvcowi.html
tracenet is offline
post #10 of 12 Old 07-31-2013, 12:39 PM
hammerman3127's Avatar
So I had this same problem
I have a comcast DTA box that has Coax in > Coax out.....
I needed something that would plug into my Home theaetre system but the theatre system only accepts HDMI or optical...
There is this (http://www.bhphotovideo.com/c/product/830196-REG/EverFocus_EHA_CRX_HD_Repeater_HDMI.html)
But $150 is a lot for a converter box when you can just buy a used HD set top box on ebay for $50
I contacted comcast today and told them my situation....they told me they can swap the standard Coax in > Coax out box for an HD STB for no charage....they did try to selll me the extra $10/month for HD accees, but I told them I dont need the content....i need the hdmni output only to watch my digital content.
They finally allowed me to walk away with the HD box and told me that my service will have the HD content displayed for that box...
whew!
price: free!
Good luck!
hammerman3127 is offline
post #11 of 12 Old 08-01-2013, 08:53 AM
Liked: 62
For use on an American cable system? What box is this?
Tulpa is offline
post #12 of 12 Old 08-01-2013, 11:06 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
whew!
price: free!
Good luck!
You can certainly buy an STB, but good luck getting it provisioned.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Reply Cable, Digital Cable - Non-HDTV
