HDMI Problems - flickering/No image - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-30-2012, 07:26 PM - Thread Starter
e485926's Avatar
Hi all -
So i have a Pioneer vsx 53 receiver. I just connected my JBL speakers to them and tried to connect it to the PS3 and WD Live player. After everything was hooked on, i tried my new 35 ft long HDMI wire to connect the receiver to the TV ( i plan on using the receiver with the TV and the Projector - thus i need a 35 ft hdmi wire), there were lines and spots on the TV. I used the 2nd HDMI and i couldnt even see anything. So i thought my receiver had a problem, so brought it close to my TV and used the normal HDMI and it worked well. Here is what i bought -
I bought 2 35 ft wires - here is the link
BlueRigger HDMI Cable (35 feet) - CL3 Rated for In-wall Installation
http://www.amazon.com/gp/product/B005LJQM3Y/ref=oh_details_o05_s00_i00
What do you guys recommend i use? i plan on returning the ones i bought but i dont know which brand and type will work in my setup. Can you suggest what i get?
Your help is greatly appreciated.
e485926 is offline
Reply Cable, Digital Cable - Non-HDTV
