How to fit splitters behind wall mounts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-08-2013, 11:37 PM - Thread Starter
MasterNES's Avatar
Hello, we recently moved to an apartment that has the following daisy chain wiring:
source -> living room, splitter -> bedroom 1, splitter -> bedroom 2
The splitters are each inside of the wall outlet (or whatever those boxes are called that are behind the wall plate). For whatever reason, the 2nd output for each splitter was unused, so the wall plates were just holes with nothing coming out of them. We wanted TV in the living room and bedroom 1, so I connected an additional coax cable to each splitter, and things are working fine.
Problem is, the wall plates are currently removed, the splitters and cables are popping out of the walls, and I can't figure out how to fit them behind each wall plate. I can cram the splitters inside the outlets, so I was thinking I could do something like splitter -> short (3 inch?) coax cable -> coax coupler in plate -> long coax cable -> TV. But I can't find any coax cables short enough that would fit inside the outlet.
I guess I could just shorten a longer coax cable to the length that I want, but I've never done that before. How do people normally do this? Is it unusual for the splitters to be directly inside the outlets like this?
MasterNES is offline
post #2 of 9 Old 01-09-2013, 12:55 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
Not normal or even recommended but unfortunately not uncommon. Why not just use a plate with a hole big enough to pass your connector through and and skip the 3" cable and f-81? That eliminates a bunch of connectors. Or, if you shop around you might find splitters that are designed to be used with wall plates where one of the output ports sticks out the side so it will stick through the plate.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is online now
post #3 of 9 Old 01-09-2013, 01:09 AM - Thread Starter
MasterNES's Avatar
Yeah, that was my backup plan. Not quite as attractive as a snug F-81 in the wall plate, but I'm guessing I don't have too many options...just wanted to make sure I'm not missing something obvious. Thanks.
post #4 of 9 Old 01-09-2013, 08:08 AM
gring40's Avatar
Properly, a distribution system would be wired with taps, not splitters, though they might look similar. Sure you've got splitters?
gring40 is offline
post #5 of 9 Old 01-09-2013, 08:54 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
You can get some taps designed to be behind wallplates at http://www.techtoolsupply.com/SearchResults.asp?Cat=398. You can find those splitters at http://www.nsccom.com/ms-2d.aspx.
CIAO!
Ed N.
egnlsn is offline
post #6 of 9 Old 01-09-2013, 09:45 AM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
Knock the in-wall boxes out and replace with an "old work box" http://www.mcmelectronics.com/product/28-6355 I just put the link up as a reference. You can buy these at Home Depot / Lowe's.
Dropkick Murphy is offline
post #7 of 9 Old 01-09-2013, 01:13 PM - Thread Starter
MasterNES's Avatar
Yes - 600MHz ones that looked like they were from the 80's. I replaced them with my own 1GHz splitters.
I already ordered these splitters meant for wall plates: http://www.hometech.com/hts/products/video/splitters/rf/ga-wp.html?item=GA-WPA2. Thanks for cluing me in on taps, though; I'll try those next if I notice any signal problems.
post #8 of 9 Old 01-11-2013, 08:13 AM
AntAltMike's Avatar
Quoted: 129 Post(s)
Liked: 62
I already ordered these splitters meant for wall plates: http://www.hometech.com/hts/products/video/splitters/rf/ga-wp.html?item=GA-WPA2 .
Those are genuinely wierd looking products.
AntAltMike is offline
post #9 of 9 Old 01-11-2013, 08:18 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Yes, they are. But the specs look good and the price is right.
CIAO!
Ed N.
egnlsn is offline
Reply Cable, Digital Cable - Non-HDTV
