Explorer 8300HD powers off on it's own - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-06-2013, 08:38 AM - Thread Starter
Chopper Patrol's Avatar
I have been having a problem with my cable box for over a year now and am quite frustrated with it. The box will power right down on its own requiring me to unplug the power and power back up. To add to this when I reboot I have to turn the tv off at the same time I reboot the pvr. If I just reboot the box it will boot with the time and channel showing but no picture on the tv. After going through the tv settings I can get a signal from the pvr but no picture and a message that there is no time information. I have three prv's and have tried two of them on this tv in this room with the same problem. When I take the pvr out of this room it works fine. I am wondering if it is the cable coming into the box or could it be something wrong with the tv?
TIA
Chopper Patrol is offline
post #2 of 10 Old 02-06-2013, 11:36 PM
Tulpa's Avatar
Liked: 61
Powers down on its own? Sounds like the PVRs are overheating. Is it enclosed in a cabinet or something?
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 10 Old 02-09-2013, 07:52 AM - Thread Starter
It is somewhat enclosed but not real tight. I can try putting it somewhere else and see if it works. I'm not sure why when I reboot it by unplugging it I have to turn the tv on at the same time or I end up with no signal to the tv. The pvr will reboot with time and channel info on its display but no image on the tv. This is why I wonder if there is something wrong with the tv. Do you have any idea why this would be happening?
post #4 of 10 Old 02-09-2013, 11:10 AM
RollTide2011's Avatar
Quoted: 118 Post(s)
Liked: 95
I would swap the box out there is probably a newer model offered by your provider then make sure you get the new box as much ventilation as possible.
I doubt if anything is wrong with your tv.
RollTide2011 is offline
post #5 of 10 Old 02-09-2013, 11:40 AM - Thread Starter
Thanks I will try these thing out.
post #6 of 10 Old 02-11-2013, 11:50 AM
Tulpa's Avatar
Liked: 61
Enclosed is enough to bake an electronics device if it gets little to no airflow.
The TV needing to be power cycled is probably an HDMI handshake issue, assuming you use that connection. It's not unheard of to have to do that.
Tulpa is offline
post #7 of 10 Old 03-06-2013, 09:00 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Yes heat is the enemy of electronics (if you can't dissipate it).
RCbridge is offline
post #8 of 10 Old 03-06-2013, 11:59 AM - Thread Starter
I have it sitting out in the open and it is still shutting down. When changing channel the tv often goes black and at the top corner says no time information, then the picture come in.
post #9 of 10 Old 03-06-2013, 04:47 PM
RCbridge's Avatar
Quoted: 16 Post(s)
Time for a new box!!
RCbridge is offline
post #10 of 10 Old 03-06-2013, 10:34 PM
Tulpa's Avatar
Liked: 61
Yeah, I'd take it in for a replacement. Either it got baked and is now too damaged despite any effort to keep it cool, or it had some other issue that can't be fixed just by moving it. Either way, you should have them replace it. If there are recordings on there you want to watch, watch them now.
Tulpa is offline
Reply Cable, Digital Cable - Non-HDTV
