can comcast put an amp near the pole instead of at the house? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 43 Old 02-24-2013, 05:54 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
forward levels would wind being flat out of the tap in a normal system
Every system I ever set up or swept had a tilt (around 5dB on a 450 MHz system on up to 10dB, 12dB or more on an 860MHz sytem) on the feeder. This was needed back in the 'all analog' day to ensure that adjacent channels ended up within a dB or 2 of each other. As I recall there was also an FCC spec that said peak to valley at the groundblock needed to be less than 5 or 6dB. In fact I've worked with designs that required equalizers near the end of line to attenuate the low channels to keep a positive slope at the taps, so I'd say flat out of the tap is not 'normal'.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #32 of 43 Old 02-24-2013, 06:28 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
I'm running 25dB over at my house.
I think all typical scenarios are out the window when the drop in question is a couple hundred feet.
CIAO!
Ed N.
egnlsn is offline
post #33 of 43 Old 02-25-2013, 02:44 AM - Thread Starter
MikeF15's Avatar
Just wanted to get a few other people's opinion...
If they can't get the drop signal any stronger, is -3db (at around 550mhz) too weak to amp without getting too much noise?
Or would an amp be worse?
MikeF15 is offline
post #34 of 43 Old 02-25-2013, 04:18 AM
ybsane's Avatar
Quoted: 93 Post(s)
Liked: 34
Originally Posted by egnlsn View Post
I'm running 25dB over at my house. Current SCTE spec's for Docsis 3.0 have 18-20 tap over tap value in order to have upstream channel bonding work correctly.
You are correct, but consider that if you start off with 23-value tap off your amp by the time you get to a 14 value it will be flat or it might even have an inline Eq in the system depending how old it is, tap spacing,etc.
All Comments made are my own and not of my employer.
ybsane is offline
post #35 of 43 Old 02-25-2013, 08:36 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Good to know about that DOCSIS spec. And, I believe, the OP is in a DOCSIS 3.0 system.
CIAO!
Ed N.
egnlsn is offline
post #36 of 43 Old 02-25-2013, 09:23 AM
RCbridge's Avatar
Quoted: 16 Post(s)
To the OP
Are all of your splitters rated to 1ghz?
You mentioned a 3 way split is it balanced?
If not is the modem connected to the 3.5db leg?
RCbridge is offline
post #37 of 43 Old 02-25-2013, 05:43 PM - Thread Starter
MikeF15's Avatar
It's balanced
MikeF15 is offline
post #38 of 43 Old 02-26-2013, 05:34 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Is it rated to 1GHZ?
RCbridge is offline
post #39 of 43 Old 02-26-2013, 05:51 AM - Thread Starter
MikeF15's Avatar
5-900mhz, but I tried a 1ghz 2 way splitter and my signal was still -14 at my modem and near that on a random cable box channel...
MikeF15 is offline
post #40 of 43 Old 02-26-2013, 05:55 AM
RCbridge's Avatar
Quoted: 16 Post(s)
From your original post I assume that you are having issues with all of your devices?
Or just some of them if so give more detail.
RCbridge is offline
post #41 of 43 Old 02-26-2013, 06:30 AM - Thread Starter
MikeF15's Avatar
All, my cable boxes range from -13 to -20, my modem usually around -18.
I made a diagram for myself and calculated for loss over distance and everything.
So I've concluded: replacing inside wiring should help 25% and enough for issues to cease. The other 75% is just a weak signal at the house (-2db). So if that's just from a really long drop, and I replace inside wiring, I guess I'll have to put on an amp, I just don't know if amping would be okay with a -2db signal coming into the amp...
MikeF15 is offline
post #42 of 43 Old 02-26-2013, 09:14 AM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Keep in mind that when he posts signal levels, it is the level of the QAM carrier as he reads it off either his cable modem or his STB.
CIAO!
Ed N.
egnlsn is offline
post #43 of 43 Old 02-26-2013, 12:12 PM
RCbridge's Avatar
Quoted: 16 Post(s)
With a -2dbmv at your entry point you can try an amp but make sure you get something that doesn't have much loss on the return path and a decent noise figure.
No promises!!
RCbridge is offline
Reply Cable, Digital Cable - Non-HDTV
