Should I add a Ferrite Core to a HDMI cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 03-04-2013, 02:26 AM - Thread Starter
Tyrone Burton's Avatar
I will be ceiling mounting my projector in about a day or two and will be having one cable coming out of a receiver, a 3metre one. Should I add ferrite core to it? They don't cost a lot to get one but I'm just curious if I should bother.
Tyrone Burton is offline
post #2 of 16 Old 03-04-2013, 07:28 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
Are you suffering the effects of some kind of interference?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #3 of 16 Old 03-04-2013, 11:06 PM
Colm's Avatar
Liked: 94
More precisely, is your HDMI cable acting as an antenna for noise from the connected devices and interferring with something else? If so, ferrites might be useful. Otherwise, no.
Colm is offline
post #4 of 16 Old 03-04-2013, 11:43 PM - Thread Starter
Luckily, no. I havnt been seeing any interference or noise yet, but I intend to buy my first extra long HDMI cable, 3 metre, and maybe thought the ferrite core would help against any image artefacts that might happen.
I'll be routing all my cables into an AV Receiver and all the info will come out through that one cable.
post #5 of 16 Old 03-05-2013, 12:30 AM
Colm's Avatar
Liked: 94
Originally Posted by Tyrone Burton View Post
...ferrite core would help against any image artefacts...
No. A ferrite core reduces common mode noise. The video and audio are transmitted using a differential circuit that essentially cancels out common mode noise. So, a ferrite isn't going to do much for those signals. And research has shown that a ferrite core will actually adversely affect the video and audio signals. IOW not only are ferrites pretty useless as far as HDMI goes, they are to be avoided unless you absolutely have to reduce interference with other devices.
HDMI uses digital signalling. A problem will not show itself as a subtle change in color, brightness, sharpness, contrast, or any of the other artifacts we might be familiar with in an analog environment. The first indication of a problem is sparkles, pixels that are just plain wrong. If you don't see sparkles, the picture is as good as it gets.
Colm is offline
post #6 of 16 Old 03-05-2013, 12:38 AM - Thread Starter
Ah, great, I don't really need one then. Thanks for your help.
post #7 of 16 Old 03-13-2013, 08:10 AM
kenglish's Avatar
Liked: 39
A ferrite doesn't hurt...and it keeps the internal noise from the projector's power supply and internal digital circuits from radiating down the cable and out in to nearby space.
It's a good idea to put a ferrite on any and all cables that may carry digital signals or noise from switch-mode power supplies.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #8 of 16 Old 04-14-2013, 05:51 PM
Vic12345's Avatar
Quoted: 72 Post(s)
Liked: 29
I tried them and it did not reduce the dancing pixels.If you do Try it's better too buy one that has ferrite core built in as your not suppose to bend hdmi cable too much.
Vic12345 is offline
post #9 of 16 Old 04-17-2013, 10:14 AM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
You said "a ferrite", is it recommended to have one ferrite on each cable end or is only one needed per cable?
JRWalker is offline
post #10 of 16 Old 04-21-2013, 09:14 AM
kenglish's Avatar
Liked: 39
One is usually recommended, located as close as possible to the noise source (usually the TV).
I see no problem with putting one (of each kind) at both ends of a cable that ties two devices together, like a TV and a Cable/Satellite box.
The ones that are provided with most consumer stuff are good from about 25 to 250 MHz.. Adding a lower-frequency mix ferrite, designed for below 30 MHz will get rid of RFI on the AM and shortwave/ham bands, as well. They are also a good thing to add to battery chargers and other switched-made power supplies.
Here's a link, which has some information about those power supplies and about interference:
http://www.avsforum.com/t/1468359/new-uk-website-on-radio-tv-interference
kenglish is offline
post #11 of 16 Old 04-21-2013, 02:24 PM
JRWalker's Avatar
Quoted: 40 Post(s)
Liked: 54
Got three ferrites with my new plasma TV. Now I know what to do with them.
Thanks for the information.
JRWalker is offline
post #12 of 16 Old 04-21-2013, 05:15 PM
Colm's Avatar
Liked: 94
Note that Ken recommends ferrites on cables to minimize polution of the airwaves. They won't do a thing for your picture.
Colm is offline
post #13 of 16 Old 04-22-2013, 07:45 AM
kenglish's Avatar
Liked: 39
They can prevent the cables from carrying interference in to the TV and other devices, if you have any nearby sources of RFI, including transmitters and other digital devices. They keep the cables from acting like antennas, both transmitting (radiating interference) and receiving (conducting interference into, or between devices).
kenglish is offline
post #14 of 16 Old 04-22-2013, 07:48 AM
kenglish's Avatar
Liked: 39
Put one on the power cord, as close to the TV as possible. Other ones should go on the RF cable (antenna or Cable TV) or on any other cables (HDMI, audio, video, network, etc) as close to the TV as possible. If you wind up with a spare one, you might put it on the end of the cable that connects the TV and Cable/satellite STB, close to the box.
kenglish is offline
post #15 of 16 Old 02-08-2015, 09:02 AM
Liked: 0
<div class="quote-container" data-huddler-embed="/t/1461496/should-i-add-a-ferrite-core-to-a-hdmi-cable#post_23229266" data-huddler-embed-placeholder="false"><span>Quote:</span>
<div class="quote-block">Originally Posted by <strong>JRWalker</strong> <a href="/t/1461496/should-i-add-a-ferrite-core-to-a-hdmi-cable#post_23229266"><img alt="View Post" class="inlineimg" src="/img/forum/go_quote.gif"></a><br><br>
Got three ferrites with my new plasma TV. Now I know what to do with them.<br><br>
Thanks for the information.</div>
</div>
<br>
Hi Ken,
Can these cables -(HDMI, audio, video, network, etc)- be grouped together with a Ferrite Core?
Chris
cjcpilot1111 is offline
post #16 of 16 Old 02-09-2015, 05:23 AM
kenglish's Avatar
Liked: 39
I'd use separate ones for each cable. Some interference travels as common-mode and some does not.
kenglish is offline
Reply Cable, Digital Cable - Non-HDTV
