Any interference with electrical lines? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-14-2013, 03:48 AM - Thread Starter
bobsled34's Avatar
I hope this isn't going to be a big mistake, but I just rewired an entire house with new coax and ethernet CAT 6 cables. There is a long run of coax and CAT 6 cables running alongside some very old electrical lines. Are there any interference issues running cables alongside electrical lines?
bobsled34 is offline
post #2 of 9 Old 03-14-2013, 07:47 AM
egnlsn's Avatar
Quoted: 153 Post(s)
Liked: 66
Potentially, yes, it's called inductive coupling. The magnetic field created by current running through the electrical wires can cause interference in communications wires.
CIAO!
Ed N.
egnlsn is offline
post #3 of 9 Old 03-14-2013, 11:05 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
It's probably a good practice to keep A/V and Catx cables away from AC feeds.
If you hook everything and don't have issues.... no worries.
If you have issues, you'll have to re-route A/V cables.
Better to have asked before running the new A/V cables. Would have saved you any expense/inconvenviece if there is an issue. smile.gif
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #4 of 9 Old 03-15-2013, 09:20 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If your data cables or the power cables are in a grounded metal conduit (not together), then there are no issues. Metal conduit will prevent one from interfiering with the other.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 9 Old 03-15-2013, 12:44 PM
Ratman's Avatar
Liked: 1191
I'd be willing to bet that there's not a pair of grounded metal conduits separating power and data cable runs. It's a "re-wire", not a new install. tongue.gif
Ratman is offline
post #6 of 9 Old 03-20-2013, 08:25 AM
SAM64's Avatar
Liked: 78
Can you back this up?
SAM64 is offline
post #7 of 9 Old 03-20-2013, 09:01 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Can you quote properly so that I get an alert?
Publicaiton 1
Publication 2
More publications here
post #8 of 9 Old 03-20-2013, 11:20 AM
Ratman's Avatar
Liked: 1191
Before tossing cow pies, let's wait for the OP to respond since he/she hasn't been back since starting the thread.
Ratman is offline
post #9 of 9 Old 03-20-2013, 01:19 PM
SAM64's Avatar
Liked: 78
Do you actually understand what you linked to?
SAM64 is offline
Reply Cable, Digital Cable - Non-HDTV
