Bulk RG6 cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-01-2013, 11:06 AM - Thread Starter
Mugenstylus1's Avatar
I have some bulk RG6 cable left over from 1990; I was wondering if it is still good, since i need to re wire my shore house from flooding.
Please let me know if the cable is any good or i should get new bulk cable.
Mugenstylus1 is offline
post #2 of 5 Old 04-01-2013, 11:45 AM
RCbridge's Avatar
Quoted: 16 Post(s)
Do you know if the cable was stored properly ?
How long are your cable runs?
Since you are wiring a whole house I would probably play it safe and use newer cables.
RCbridge is offline
post #3 of 5 Old 04-01-2013, 12:28 PM
kenglish's Avatar
Liked: 39
How does it look?
Is it all still nice and round throughout it's length?
If it is flattened or has noticeable kinks and dents, it will have reflections in the signal, which cause multi-path effects.
Also, be sure it does not have any holes in the outer jacket. Those would let moisture in, and likely already have.
If you're OK so far, cut off a few feet of each end. Carefully cut the outer jacket open (razor blade), and inspect the wire braid shield. There should be no corrosion, or white powdery substance in there, at all. If moisture got inside, the woven braid will wick it up... often spreading through the whole length. If it's nice and clean, you're OK.
Now, remove the braid from that section, and see if the inner insulation looks OK. If it doesn't look all cruddy, it's likely good.
Now, pull off a bit of the inner insulator, and see if the center wire looks pretty clean and un-corroded.
Basically, you need to see if water has, or can, get inside, and you need to be sure the cable is still nice and round (evenly) throughout the length that you want to use.
Ken English, Sr. Engineer, KSL-TV.
"The postings on this site are my own and don't necessarily represent the Company positions, strategies or opinions."
kenglish is offline
post #4 of 5 Old 04-01-2013, 01:31 PM
egnlsn's Avatar
Quoted: 144 Post(s)
Liked: 66
Also, make sure that it doesn't have any "icky-pick" (gooey stuff) in it. If it does, you can't use it indoors.
CIAO!
Ed N.
egnlsn is offline
post #5 of 5 Old 04-01-2013, 02:40 PM - Thread Starter
The good part is the bulk cable was not stored in the flooded house, mostly in storage. I will look into the cable thank you.
Reply Cable, Digital Cable - Non-HDTV
