Could a VGA port be an indication of 0-255 support? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 04-19-2013, 02:37 PM - Thread Starter
Tyrone Burton's Avatar
Back when I was looking around quite a bit for an AVR, I was trying to make sure it supported 0-255 for most of my gaming equipment (games consoles) as I believe if the games were made in 0-255, you should be outputting 0-255. It's very difficult to find info if a certain device supports 0-255 (PC Levels), but I discovered (If I'm correct) that the VGA cables only support 0-255. I have a projector, the BenQ W1070, which has a VGA port and fully supports 0-255, I can just switch to PC levels when I need to.
So my question then really is, if I'm looking for a piece of equipment such as an AV Receiever, HDTV, projector ect, will it having a VGA port be a indication that it supports 0-255?
Tyrone Burton is offline
Reply Cable, Digital Cable - Non-HDTV
