Need help in finding out the correct cable to connect between reciever and subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-07-2013, 08:19 PM - Thread Starter
vasug2k's Avatar
Hi,
I have "Denon AVR-X2000" receiver and "Mortin Logan MLT-2" 5.1 speaker system with me. I need a cable to connect from my receiver to speaker system. Could somebody please suggest the cable?
vasug2k is offline
post #2 of 4 Old 07-07-2013, 08:50 PM
Liked: 62
Your subwoofer just needs a RCA-ended coaxial cable like this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=2680&seq=1&format=2
Or this, just not as fancy:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023601&p_id=619&seq=1&format=2
in whatever length you need (they have them from 3ft to 100ft.)
Speakers use wire. You can get them at Home Depot cheap, or order online:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2748&seq=1&format=2
Again, you can get it in different lengths. 14 gauge is usually fine. If you have to run the wires fairly long, you might bump up to 12 gauge.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 4 Old 07-07-2013, 09:06 PM - Thread Starter
vasug2k's Avatar
Thanks a lot for your suggestion. Could you please also let me know how to connect the subwoofer cable? From receiver end, I know there is only one connector but at subwoofer end, there are two. L and R. how to connect it and how it works?
vasug2k is offline
post #4 of 4 Old 07-07-2013, 11:15 PM
Liked: 62
You can put it on either the L or R (there are two for certain types of stereo receivers, but yours has just the lone sub out.) The manual on page 10 states that it uses the R input, but I'd be willing to bet the L will work, too.
http://www.martinlogan.com/pdf/manuals/manual_mlt2.pdf
If you want, you can buy a y-splitter with one RCA female and two RCA male connectors (Monoprice has them) and hook to both the L and R, but it's not necessary.
hyghwayman likes this.
Tulpa is offline
Reply Cable, Digital Cable - Non-HDTV
