Keep cable box's HDMI output on? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-16-2013, 03:51 AM - Thread Starter
robot1125's Avatar
I have an Optimum Samsung cable box and a PC hooked up to a 27 inch monitor, and I use the monitor's input select to change between them.
My problem seems to be that whenever I use the computer, the cable box thinks the monitor is off so it turns its own output off. Then, if I change inputs to the TV, the monitor doesn't see a signal so it switches back to the PC.
Thus, if I want to watch TV, I have to quickly cycle the cable box and change the input, hoping I get the timing right so they both see each other "on".
Is there any way I can lock the Samsgung's output on all the time like the PC is?
-Robot
robot1125 is offline
post #2 of 5 Old 07-16-2013, 09:16 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Don't have the answer for your problem, but have you tried turning the monitor off after switching to cable box, and then turning it back on?
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #3 of 5 Old 07-16-2013, 09:48 AM
RCbridge's Avatar
Quoted: 16 Post(s)
How long after switching does the cable box turn off?
RCbridge is offline
post #4 of 5 Old 07-16-2013, 10:18 AM
Liked: 61
If it is anywhere and is user accessible, it should be in the settings for the box somewhere. If not, I'd look into getting another box from your provider. My Cisco/SA boxes are always on.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 5 Old 07-18-2013, 09:23 AM
RCbridge's Avatar
Quoted: 16 Post(s)
My .oxes are also always on.
I would ask for another box.
RCbridge is offline
Reply Cable, Digital Cable - Non-HDTV
